SOURCE: FI light glows red above speedo on CBR Fs Sport 600
The F(uel) I(njection) comes on when the ECU locates a malfunctioning sensor.You must go to a dealer's workshop to read the ECU's fail report and check the injection components.Perhaps is just a shortcut in your harness but first check the diagnose to eliminate the fact of a sensor or an injector.
SOURCE: WHat kind of Oil and Oil Filter is best used on a
Use the weight your manual suggests. As long as it does not say EC (energy conserving) on the label it will be fine. Pay attention to your expected temperature, the weight of oil suggested changes based on your local temperatures.
SOURCE: FI light comes on. Honda CBR 600
FL stands for Fuel Injecton. Your fuel injection sensors have found a problem and the onboard computer chip is telling you. You must have a dealer read the computer code to find out what the problem is.
SOURCE: 02 cbr 600 f4i, red fi light flashes and bike
you have a fi fault revmove the seat cowl on the left hand sise you will see the cdi unit (black box with wires going to it) you should see a black conector with two wires going to it bridge the wires with a pice of wire or split pin turn the igntion switch on and count the blinks one long one means ten recored the the blinks and phone a dealer and ask them for the fault code.to reset the the light pull out the bridge and the light should stay on or blink repeted turn off the switch make sure the kill switch is set to run hope this helps
SOURCE: FI ligth blinks twice CBR 600RR 2008
take it to a honda dealer the bike is still under warrenty
