Question about Kenmore 79383 Dual Fuel (Electric and Gas) Kitchen Range
I have a Kenmore elite range 790 and the front right center element does not heat up. The two outside elements work fine.
  • daniellediro Mar 20, 2009
    the single element feature of my triple burner will not work...not sure for how long this has been going on, but I was wondering if this was something we could repair at home without an expensive technician?
  • ecanderson1 Mar 22, 2009
    We just notice the same thing on our Kenmore Elite. Inner section of the front right burner does not heat up. Outer 2 work fine.
    Wonder how much this is going to cost. Have only owned this appliance for less than 3 years.
  • 15,935 Answers
It appears your element or clock has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 30, 2010
Kenmore c970-440935. Why does one element overheat?
Kenmore Elite C970 440935 Replace heating element range
www.fixya.com > ... > Ovens > Kenmore > Kenmore Elite C970 440935
Kenmore Elite C970 440935, replace heating element range related issues. Get free help, solutions & advice from top Kenmore experts. ... Kenmore 40494 / 40495 / 40499 Electric Single Oven. 793 Questions ..
Aug 05, 2015 | Kitchen Ranges
Kenmore 790 oven won't heat after self clean
Did you fully disconnect the wires when you checked continuity? If not you are checking continuity in the whole circuit. For what its worth, the self clean feature superheats the oven and often burns out elements. We see it all the time. It is one feature to never use!
The broiler element is not part of the oven temperature, it is a broiler. The oven works on the bottom element alone. If it only gets to 300'F, wither the bottom element is faulty or the thermostat is failing. As I mentioned self clean is a great way to cause problems.
Nov 16, 2017 | Kitchen Ranges
KENMORE ELECTRIC RANGE 95032. EVERYTHING WORKS BUT OVEN DOES NOT HEAT.
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Nov 25, 2010 | Kenmore 95032 / 95034 Electric Kitchen...
Kenmore electric range 790. Both the broil and
Kenmore oven 790.91072601, bake & broil not working, relays are cycling but no heat... Sounds like I have the same problem but its the night before Thanksgiving and Iam in panic mode... I've orderd a new Temp Probe part # 316233902. did you ever get yours fixed
Jul 13, 2009 | Kenmore Kitchen Ranges
Leaky heating element
their is a nut right in center of heating element. loosen it and push heating element a little in and tighten bolt. that should work.
May 17, 2009 | Kenmore Elite 45986 Front Load Washer
I have a Sears bought Kenmore Elite Electric Range 790.9912 with a glass top. The right front burner has a middle, center and outside element. The center element stopped working tonight....the middle and...
the burner must be replaced . easy job, open oven look under lip of stovetop there are two 1/4 inch drive nuts , remove them then you can lift the cooktop you will see the underside of the burner . its held in with two screws , carefull of the clips,there easy to loose . let the old burner hang by its wires . when you get the new one in move the wires one by one to the new burner ... you will need two people one to hold the top up and one to do the work . dont forget to turn power off to stove . part will cost around 100.00 should take no longer than 15 mins to do the job . have fun and good luck ........ please rate this answer i need votes to stay here , thanks
Feb 01, 2009 | Kitchen Ranges
The inner right front element will not heat up on our Kenmore Elite ceramic stove top. The middle and outer elements on the right front work fine. Why is this happening?
inner element burned out. Either burner needs replacing or control switch is bad. Take out burner and see if coil has a break in it. IF not, then switch is bad. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Nov 28, 2008 | Kenmore Kitchen Ranges
Kenmore Elite 790 Range
I can't believe I found this today. Today, my Elite 790 inner coil also stopped working! A little too coincidental.
When I turn on the burner, I can hear like a relay click on, but it does not heat. The middle and outer burners are fine.
Dec 20, 2007 | Kitchen Ranges
Kenmore 79383 Dual Fuel (Electric and Gas) Kitchen Range Logo
242 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
