Question about Refrigerators
Refrigerator no water dispensing or ice
After pluging refrigerator for a few weeks with the water filter on, I finally installed the ice maker water supply but water doesn't flow to the water dispenser and there is air in the hose. I tried turning off the refrigerator to se if its a freezed filter. Please help.
  • 410 Answers
Have you tried just running the dispenser to give the water reservoir time to fill up with water. depending on water supply pressure it cant ake as long as 1-2 minutes to purge all the air and for the reservoir to fill. thanks Peyton
Posted on Feb 18, 2009
Why is my GE (ZFSB23D SS) side by side refrigerator leaking at the back corner, near the rear wheel where the plastic water line goes in?
If the tubing is plastic it could have cracked when you moved the tubing to install the filter. If the tubing is OK then possinly the filter isn't all the way in or is leaking.
Jul 31, 2014 | Refrigerators
My new refrigerator's ice maker and water dispenser doesnt work
Since this is a brand new unit, I wouldn't waste the time or money troubleshooting it yourself; contact the place you purchased it from and exchange it.
Jul 14, 2008 | LG LSC26905TT Side by Side Refrigerator
Ice machine isn't working
Two things come to mind.
First, the water valve at the bottom rear of the refrigerator may have failed. You didn't mention if there is a water dispenser and whether or not this is still working. This valve pumps water to the icemaker and water dispenser when the control unit of the icemaker calls for water. Also, there could be a blockage in the line which brings the water to the icemaker.
The other possibility is that the part of the icemaker controls which calls for water from the valve has failed. If this has happened, it would likely be more cost effective to replace the icemaker unit.
Oct 19, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
I get water from the dispenser but no ice
As you open the freezer door you will se a wire on the side of the ice maker. It is there to stop the machine from making ice like a float in the toilet. It may have been bumped move it up or down until it clicks. it should go to work making ice now if not the valve in the back of the frig is pluged or bad. If you do not have a water filter it is pluged. The filter is cheep and easy to replace so I would turn the water off to it and replace the filter any way most are neglected.
Aug 12, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Ice maker not making ice
Try changing the filter; our refrigerator did the same thing.
Jul 17, 2009 | Frigidaire FRS6R5EMB Side by Side...
Freezer does not make ice
You need to check and see if ice maker has any water init. if not check the fill tube that goes thru the back wall for stoppage while you have it out rin the maker thru a harvest mode and listen for the sounds of the solonoid opening. If tube is full you'll need to replace the slow leaking valve a common problem. for parts call 704-819-6557
Mar 14, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker
new icemaker,wont fill up with water when it calls
Jan 24, 2009 | Frigidaire FRS26R4A Side by Side...
Ice maker won't make ice after replacing water filter -plugged
I've had the discolored water before when replacing the filter. It normally means that there was gunk in the water line.
Do you still hear the ice maker trying to draw water in?
If not, the water pump might be burnt out.
If so, see below.
The water lines that feed the dispencer and the ice maker split after a certain point.
It's possible that the line that feeds the ice maker might be clogged. You should be able to get to it by removing a few screws and pulling off the back panel of the fridge. Then you can check them out and remove the clog.
Comment on the post if more helps is needed.
Jan 19, 2009 | Admiral 26 cu. ft. Side-By-Side...
Refrigerator Ice maker not working
my ge refrigerator stop making ice a week ago, water dispenser still works.
May 15, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Side by side refrigerator
The ice maker is not producing ice or not enough ice
 Refrigerator connected to a water supply and the supply
shutoff valve turned on?
Connect refrigerator to water
supply and turn water shutoff valve fully open.
 Kink in the water source line? A kink in the line can reduce
water flow. Straighten the water source line.
 Ice maker turned on? Make sure wire shutoff arm or switch
(depending on model) is in the ON position.
 New installation? Wait 24 hours after ice maker installation
for ice production to begin. Wait 72 hours for full ice
production.
 Large amount of ice recently removed? Allow 24 hours for
ice maker to produce more ice.
 Ice cube jammed in the ice maker ejector arm?
Remove ice from the ejector arm with a plastic utensil.
 Reverse osmosis water filtration system connected to
your cold water supply?
This can decrease water pressure
OR
The water dispenser will not operate properly
 Freezer door closed completely? Close the door firmly. If it
does not close completely, see “The doors will not close
completely.”
 Is the water pressure at least 30 psi? The water pressure to
the home determines the flow from the dispenser. See “Water
Supply Requirements.”
 Kink in the home water source line? Straighten the water
source line.
 New installation? Flush and fill the water system.
 Water filter installed on the refrigerator? The filter may be
clogged or incorrectly installed.
 Is a reverse osmosis water filtration system connected to
GOOD LUCK TO YOU!!! LET ME KNOW IF THIS SOLVED YOUR PROBLEM
Jan 31, 2008 | Whirlpool ED2FHEXN Side by Side...
Refrigerators Logo
142 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
