Question about Hampton Bay 44 In. White Carousel II with Multicolor Blades Fan
Wiring the replacement 3 speed switch (fan motor)
I have 2 questions: 1) What is the correct wiring for the 3 speed switch that controls the fan motor. The old switch fell apart and the wires came out before I could mark it down. There is a white, a black, a blue, and a yellow wire. Here is how I wired it: L white 1 black 2 blue 3 yellow. I get nothing on all but 1 speed (not sure which one) where the motor hums but the fan does not turn. It does rotate freely by hand. This leads me to my next question: 2) Is my problem in the capacitor? Or could this result (motor "humming" on 1 speed but not others) still be a result of the wiring being wrong? Any help would be immensely appreciated.
  • carmensanabr Feb 26, 2009
    Update: I ended up ordering the switch and the capacitor from King of Fans. I installed them and the fan is working beautifully. I spent about $18 whereas a new fan would have cost anywhwere from $79 to $99 so I was happy. Anyone else with the same issue with this model fan I HIGHLY recommend you call King of Fans and order from them. FYI: The above wiring is correct for the switch.
I called King of Fans and the rep that I spoke with gave me the correct wiring for the 3 speed switch:
L White
1 Yellow
2 Blue
3 Black
The problem is that after I wired it this way I am getting the same result (off on 3 settings and a motor hum on 1 setting). So, either the Westinghouse switch that I bought at Home Depot is not compatible or it is the capacitor. The saga continues.
Posted on Feb 19, 2009
Hunter ceiling fan, replacing speed switch, what wire goes to the L, 1, 2, and 3?
I can only guess since I don't know what model or what color wires you have. Here's wiring for single stack switch on some Hunters;
L- black
1 - grey
2 - brown
3 - green
Hope this helps.
Feb 06, 2016 | Hunter Ceiling Fan Control Switch
Tip
Fan speed switch wiring
If your are replacing the fan speed switch on the Hampton Bay San Marino mfg # 67353, this is the correct wiring pattern...L-white, 1-yellow, 2- blue, 3-black. I have been searching for this answer for 2 days. Thought I'd post for others with the same problem.
on Jun 01, 2008 | Hampton Bay 36 In. San Marino in Brushed...
I have 2 wires plus ground going from switch to fan at fan there are several wires I can not figure out a hook up
if single speed fan you have 3 wires and ground
if 3 speed fan you have 5 wires
if 1 speed 2 wires are are the power and the other one is a capacitor wire at 1.3uF 1.5uF 330v you need to have the wiring chart for the motor or you could work it out with a ohm meter or seek the help of a sparky
Dec 29, 2015 | Dryers
20 year old Hampton Bay fan requires new 3-speed pull chain fan switch replacement. I did not copy the wiring pattern for the L, 1, 2 and 3 positions. There are 3-wires: black, white and blue.
Typically AC wire protocol designated black = line voltage (means \'death\') and white is neutral (cold).
The blue one will be a switched line to the motor and a meter capable of checking continuity should allow you to determine the proper wiring.
Oct 14, 2014 | Hampton Bay Dryers
I have a 3 speed fan with a red, blue, black an white wires, how are the supposed to be wired with power. the wires go to a little black box that appears to just be wires with no circuit board
The BOX is a GE splicer - with 6 wires - 2 grey power wires, then the red, blue, black, and white from the fan motor. I have the same problem and cannot find another GE SPLICER 3 SPEED SWITCH for the fan. All switches that I have tried have 4 connections.........so a WIRING DIAGRAM would be GREAT!
Can anyone offer any help? I have tried every electrical store in the area!
Thanks
May 29, 2011 | Patton U2-1887HO Floor / Box Fan
MY HUNTER ORIGINAL RUNS THRU AN ORDINARY WALL SWITCH. IT HAS HI AND LO SPEEDS ON THE HOUSING, BUT EVEN LO SPEED IS A BIT TOO FAST AT TIMES... HOW CAN I CONTROL THE SPEED THRU FULL RANGE... A RHEOSTAT...
Jim,
You have a special fan there. Hunter Originals are my specialty.
There are two ways to accomplish a slower speed with this fan.
1. A wall variable speed control, solid state, rated for 3 or more amps, regular fan controls will not work as your fan draws 2.5amps on high, not even new ones that are labeled for the Original.
2. Retrofit the fan to make it a three speed. If you're good with wiring, it's really simple. What you need is, a standard 3 speed pull chain switch, not a double pole one like cheaper/new fans have that use capacitor speed control, we are using cap. speed control, but not the same way they do. So you want an "SP3T" switch. You also need an 9 10 or 11 or 12 MFD capacitor (depending on how fast you want your low to be 8 is 20rpm, 11 is 75 approximately). You will remove the switch cap to your fan, and you will find your switch has a black, blue and red wire connected to it. Remove all wires, attach the black to L on your new switch, attach blue to 1, then you need 2 extra pieces of wire. Stick one wire in 2 and the second wire in 3. Now, get your capacitor and hook one side of it to the red wire and position 2, then hook the other side to the wire you put in position three.
Remember to get the Single pole switch for non capacitor speed control fans, if you get the double pole, both winding sets in your fan will be activated, which will draw double current and burn your motor out.
2speedorignial.png?t=1296263478
Also, are you aware that your fan uses oil (like an engine) ? and is not permanently lubricated?
Jan 08, 2011 | Hunter Ceiling Fan Control Switch
I was trying to install a fan control switch on my Patton floor fan and took the 3 speed switch out and disconnected the wires and cannot figure out what wires (too many colored wires) to connect to the 2...
Thr issue you are having you need to look on the motor and see if there is a diagram but you have to use the grey and white for a capacitor because i have an older fan that has no capacitor. and use the red for high
Dec 28, 2010 | Patton U2-1487 Floor / Box Fan
I found my Hunter Original fan's switch to be frozen, so I went in search of a replacement. I bought a 3-speed switch with similar wiring (red, blue, and black wires). I wired it up and turned it on. ...
I think you have the power wire mixed up. Your power supply to the switch should be black. And in most cases goes the the L-1 labeled on the switch. If you have trouble finding the power just plug the wires in and use a simple light or voltage tester. Once you have the power wire just touch each wire 1 at a time and you can tell the speeds. Once you have the speeds hook them up to low being 1 med.2 high 3. Then your done
Sep 11, 2010 | Hunter 23852 Classic Original Ceiling Fan
Wiring diagram for a 3 way ceiling pull switch.
These fans are manufactured by a number of overseas companies and sold exclusively by Home Depot. They do not have a standard color code for the fan switch. What you can do is turn off the power, keep the white neutral connected. Then using the black power wire fro the ceiling, take one of the switch wires and connect to that black, turn the power on and observe the speed .. low mark it 1, medium mark it 2, high mark it 3. Repeat untill you have identified all the speed wires. Then connect these wires to the 1,2,3, terminations of your new switch
Questions?
Please Vote !
May 29, 2010 | Hampton Bay 24750 Huntington III Ceiling...
WIRING OF 3-WAY SPEED SWITCH FOR HAMPTON FAN
1 - Red/Pink
2 - Purple
3 - Yellow
L - Black
Mar 11, 2008 | Oasis Hunter 54' Ceiling Fan
Hampton Bay 44 In. White Carousel II with Multicolor Blades Fan Logo
1,877 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Fan Fair Of Boca
Fan Fair Of Boca
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
