Question about Tappan TGF320 Gas Kitchen Range
I have a Tappan gas range. The oven is malfunctioning. The oven starts to heat up, but will not reach preset warming temperature.Then it shuts itself off.I do not physically see a temperature sencor in the oven. Can any one help me with this problems solution?
How do you replace igniter?
Posted on Nov 25, 2009
It is quite obviouse to me that your service is not free. You misrepresented your service on line like many websights do.There fore my solution to this problem is to never get you involved with anything in the future.You cannot be trusted to solve a problem, all you did was delay my repair problem with falce hope of supplying me with a solution.Your service may be a good one but I will never deal with people that market their services in the manner that you do.Remember that first impressions are lasting ones, and you have made a bad one.
Posted on Feb 18, 2009
    Problem Solver:
  • 6 Answers
THE IGNITER IS BAD--AND CLOSES YOUR GAS VALVE
Posted on Mar 14, 2009
The burners and pilot light work but the oven will not light. We need to figure out which part to replace. It is a unit converted for propane and has no electric parts.
Ovens generally have a couple of safety devices fitted meaning no gas gets to the oven unless there is sufficient gas pressure. There is also a valve controlled by a thermocouple. The valve prevents gas passing. There is a bypass operated by either a button or pressing in the oven control knob which allows gas to flow to the pilot light (and sometimes the burners). When the pilot light is lighted and has been burning for about half a minute with the flame correctly set to heat the thermocouple bulb the valve will switch on the gas supply and the knob or button can be released. The burners will initially be at maximum until the oven thermostat reduces the flow to maintain the temperature at a preset level.
If gas isn't reaching the oven and the pipework, oven control and thermostat is ok then the safety thermocouple is either defective or wrongly fitted.
Apr 24, 2016 | Kitchen Ranges
Hi i own a tappan tgf328 gas range and I'm trying to heat up the oven and its beeping and giving me an F31 code. Can you help me?
Tamppan Range/Stove/Oven Fault Codes
Failure
Code
Condition Check/Repair F0 & F1 EOC (Electronic Oven Control) failure Replace Electronic Oven Control F2 Oven too hot Check Bake function, if OK, replace oven temperature sensor F3 Oven temperature sensor open Check oven temperature sensor, should be ~1100 ohms at room temperature. If too high or low, replace oven temperature sensor F4 Oven temperature sensor shorted Replace oven temperature sensor F5, 6, 7 EOC (Electronic Oven Control) failure Replace Electronic Oven Control F8 Lock switches Check switches and replace if necessary
Apr 07, 2011 | Tappan TGF320 Gas Kitchen Range
My Tappan gas oven will heat up to temperature when first started but will not maintain temperature after that. The burner will not re-ignite. If I lower the temperature to the off position then put back...
thermo couple may be defective. Disconnect oven, look inside oven it will be a 2-4 inch tube looking brass type metal. use ohm meter check continuity if non then most likely its defective. other then that it may be the control board.
Sep 11, 2017 | Tappan Kitchen Range
Gas oven not heating up.It will only warm to 150 degree's. It is a Tappan gas range/stove 110 series.
The problem is usually the ignitor not reaching the correct amp draw .When the ignitor does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The ignitor is inexpensive and easy to replace. There is a video at www.appliancehelponline.com/servicemanual.html this will walk you thru the correct procedure for performing this test. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available.
Apr 07, 2010 | Tappan Ovens
My gas oven overheats and burns my baking. With one temperature test it was set at 300 and within thirty minutes the temperature was reaching 400 and leveling off. However, the next test with the oven at...
bad thermostat.....buy new at lowes .....its inside the oven.....usually at the top of oven..looks like copper rod with copper wire ....easy to change...buy at lowes or homedepot
Nov 16, 2009 | Tappan TGF320 Gas Kitchen Range
My gas oven won't heat up over 250 degrees
thats going to be the temperature probe
Mar 15, 2009 | Tappan TGF303BW Gas Range
Tappan oven does not heat
hi thanks for the question all these oven gas not igniting mostly hase to do with igniter thanks the appliance doc
Aug 18, 2008 | Tappan TGF320 Gas Kitchen Range
Magic Chef Oven lights and shuts off
This could be caused by a lack of air within the oven cavity, once the air is used up the flame will go out, it will then work again once it is relite, but will probably do the same again, this could be dangerous and requires on site proffesional attention. Regards Engineer
Jun 10, 2007 | Magic Chef CGR1415AD Gas Kitchen Range
Oven not working
Per this page (http://www.repairclinic.com/0078.asp#Tappan), it sounds like you need to replace your oven temperature sensor.
Feb 23, 2007 | Tappan TGF363 Gas Kitchen Range
Tappan TGF320 Gas Kitchen Range Logo
332 people viewed this question
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Sal De
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
