Question about Texas Instruments TI-84 Plus Silver Edition Graphic Calculator
Calc problems The problem is that the calc is not receptive to data being sent to calc HELP!!!
    Problem Solver:
  • 11 Answers
I think when you are sending the data that the cables might not be put in the wrong way with the sending to be B and the receiving to be S or your calculator might have a bug.
Posted on Mar 02, 2009
My Compaq Presario CQ56 has calculator that keeps popping up when I press the arrow keys or the numerical keys. Please help!!
Well what I really wanted to know the most is if it pops up while you\'re not even touching your mouse or keyboard...
If you changed your .exe to .com like I said and it came back, then it\'s normal... ... Just delete the calc.com file. Don\'t worry, calc.exe came back on its own so the calc.com we made is now useless. That\'s why you can now delete calc.com. It\'s also just to reset what was in your old calc.exe, in case it has a keyboard shortcut and other hidden stuff integrated.
Still gotta make sure though... Can you right-click on calc.exe and choose "Properties" to see if there\'s any keyboard shortcut? The field (shortcut key) should be left blank in case there\'s something in there. Or to "None".
IF the calc.exe still pops up while you\'re not doing anything, then it\'s time for some hijackthis.
Get it here:
http://www.download.com/Trend-Micro-Hijack...4-10227353.html
Do a system scan and save a logfile.
After the scan is over, copy all what\'s in the list (notepad), and post it here.
Let\'s take a look at what\'s running.
Sep 11, 2014 | Compaq Presario CQ56-115DX Laptop
Why does my t- 84 give a data type error when I ask it to write 9/(2+3i) as a fraction
For a moment I was puzzled by you question. After trying several configuration changes I finally figured out what the problem is.
You get the DATA type ERROR if you use the MathPrint templates (the two stacked squares).
In Math or Classic IO you can display complex fractions as fractions, just do not enter them through the template you access through the ALPHA F1 key combination. You can do that even for the older OS's (1.12 ). and with the number type set to REAL. Use the usual linear way. You do not need to set the calculator to CLASSIC..
Nov 29, 2011 | Texas Instruments TI-84 Plus Calculator
Where is the sinreg function or key?
  1. Enter the data using the [STAT][EDIT].
  2. Once you finish populating your lists, press [STAT] button.
  3. Three menu options are displayed EDIT, CALC, TESTS
  4. Use right arrow to highlight CALC Menu.
  5. Use DownArrow to scroll down the list to reach [C:SINEREG] or press Press [ALPHA][C:SineREG].
  6. The command will echo on main screen.
  7. Specify the lists to be used for the 2-var data and Press[ENTER] to execute command.
Sep 29, 2010 | Texas Instruments TI-84 Plus Calculator
Lost CALCULATOR application
  • Scientific
  • Statistical
  • Financial
  • Programmable
  • Graphing
  • Complex arithmetic
  • Matrix/vector arithmetic
  • Unit arithmetic
  • RPN
Download You can download Calc into your phone or MIDP device using one of these links:
Calculator 1
http://midp-calc.sf.net/Calc.jad, or
http://midp-calc.sf.net/Calc.jar
click her for calculator 2
transfer both the files to your mobile and then install them by just clicking on open install
Mar 31, 2010 | Nokia 5220 XpressMusic Cellular Phone
When I type a list of numbers into L1 and then hit Stat, calc, 1-var stats L1. i get invalid dim
  1. Press [STAT][5:SetUpEditor][ENTER].
  2. Press [STAT][1:Edit..]
  3. Enter your data in L1.
  4. Press [STAT][CALC][1:1-Var Stats].
  5. Command echoes on main screen.
  6. If ONLY one list contains data, it must be L1.
  7. When you do not specify the list in the command line it will take L1 by default.
  8. If L1 is empty and the data is in L2, or another but L1, the name of list must be specified.
Feb 19, 2010 | Texas Instruments TI-84 Plus Calculator
How to use the calc-clean button
Calc-Clean function
The Calc-Clean function removes scale and impurities.
To do so, set the steam control to position '0', set the temperature dial to 'MAX', and fill water tank up to the 'MAX' level. Then heat up the iron until the pilot light on the handgrip goes out.
Remove the mains plug from the wall socket and hold the iron horizontally over the sink. Then press and hold down the 'CALC CLEAN' button.
Move the iron forwards and backwards while boiling water/steam squirt from the holes in the soleplate to wash away impurities/scales.
When the water tank is empty, heat up the iron to dry it.
Finally move the iron to and fro on a piece of cloth to dry the soleplate. Repeat the process if necessary
May 05, 2009 | Philips HI-296 Iron
Dell Calculator Hotkey
Verify if multiple calc works if you launch it from windows, without using the hot-key. if that does not work, its a windows issue - might need a full repair / install. If windows is able to launch it - you can fix the issue by reinstalling any drivers for your kbd.
Nov 06, 2008 | Dell 0Y3740 Keyboard
Casio Fx-82TL calc display problem
it seems the problem is on the lcd. technicians usually use soldering iron to apply heat to the cable connecting the lcd to its mainboard.
Sep 16, 2008 | Casio FX-115ES Scientific Calculator
Could you help me
make sure your stat plots are off. you can just reset your calc. second + 7 1 2. or you can hit second y= and make sure that the stat plots are off. have any more questions. just send me a another request.
Jul 17, 2008 | Texas Instruments TI-84 Plus Silver...
Darken screen!!!
reset your calc, press 2nd left right on simultaneously. it should work.
Apr 25, 2008 | Texas Instruments TI-89 Calculator
Texas Instruments TI-84 Plus Silver Edition Graphic Calculator Logo
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
