Question about Mtd Garden
Starter engages flywheel for a slow crank
New starter,new silonoid,new battery
  • 1 more comment
  • kbartkowiak4 Feb 18, 2009
    starter turns flywheel then stops then turns then stops
    There is not a solenoid on the carb to check.Still have the same problem starter engages flywheel turn then stops turn then stops .And it kills the battery.pos. cable get hot.mtd ride mower.
Hi Kbart did you manage to solve the problem. I'm suffering the same.
Posted on Jun 17, 2010
Starter works but will not turn crank
If the starter is operational and won't crank then it has to be a battery or wiring issue. The starter may work but it might not be engaging the flywheel teeth. Is this a new starter? Is this a new problem with the engine not cranking?
Feb 15, 2011 | Chrysler PT Cruiser Cars & Trucks
My starter keep turning on my 1986 crown vic
ur silonoid on ur starter is going out it engages the apendex that spins ur flywheel etc.
Sep 24, 2010 | 1986 Ford Crown Victoria
Wont turn over
check the conections of the wires at the starter and silonoid disconect battery first as to not short anything out by bumping the engine wich is grounded if all conections are good then the bendex in the silonoid is not engaging all the way to operate the starter or the broshes in the starter ar woren out eather way just replace the starter a new one comes with the silonoid on it and they are only about 45-65 bucks at schucks and have a 1 year warranty. i dont recomend just replacing the silonoid on the starter cause adventuly you will have to replace the starter any ways. or if you are on a budget then u can remove the silonoid from the starter and sand the bendex in the silonoid with some fine grit sand paper and use air to blow any debres out of it and reinstall silonoid and it will get u by for a short time.
Aug 01, 2009 | 1998 Dodge Caravan
Car will not crank
Check battery voltage should be 12v. Have battery load tested. If good recharge, then with a voltmeter across battery terminals try to start engine. If battery voltage drops below 9.5v starter has failed.
Jun 08, 2009 | 1998 Pontiac Grand Am
Starter runs but won't engage flywheel
Hello, I would make sure that your car is not one of those half year cars becuase two differn't starters may be offered for the same year of car. Also, I would check and see if your battery has enough CCA's to power your system. The only other thing is to turn your crankshaft with a breaker bar to turn your flywheel to possibly get a fresh area of teeth on it. If none of this fails it's as simple as just replacing the flywheel. If you did a bench test on the starter and the bendix engaged that is good. Buying parts from an Auto parts store does not gurantee the part is good and that the bendix engages the full distance to turn the flywheel. I would try to find a mechanic who rebuilds starters to make sure that the bendix is engaging fully. I hope this helps you!
May 20, 2009 | 1986 Ford Ranger 2WD
Cranks fine, won't "catch"
From what u describe, I believe u have a starter and possibly a flywheel problem. When u turn the key to start the car, the starter gear engages w/ the flywheel, turning the flywheel, which turns the engine over. It sounds like the teeth of the flywheel and starter are worn, (they should mesh together smoothly) which would make the grinding noise u describe. If this is the case, the flywheel and starter would need to be replaced, and its a labor intensive job, as engine and trans. have to be separated to remove/install the flywheel. The rrrrrrr sound could be the starter gear spinning but not engaging. The starter gear extends on a shaft, then engages the flywheel. It is possible the gear isn't moving forward on the shaft, just spinning w/out engaging, making the rrr sound. So, I would recommend u remove the starter and have it tested (many parts stores will do this for free) and check the teeth on the gear to see if they are worn or broken. U will also be able to see a portion of the flywheel after the starter is removed, and u should check the teeth on it also. Let me know what u find, hopefully it's just a starter problem, and the flywheel is ok.
Dec 30, 2008 | 1991 Buick Skylark
engine crank thrusts worn and crank moved back enough to not engage ,with a manual the clutch would push it forewards.or the flex plate on the back of the torque converter damaged and broke in teh centre where bolts to the crank
Dec 01, 2008 | 1996 Lincoln Town Car
Starter won't engage or turn over
its the silonoid that bolts to the starter.the brushes inside the silonoid are not making good enough contact with the copper probe inside. solution buy a new starter or check the voltage going to the starter by checking the hot from the battery and the hot going from the starter to the alternator.
Nov 24, 2008 | 1993 Jeep Cherokee Country
Garden Logo
268 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
