Question about Brother BRTPT65 PT-65 Label Maker Printer
How and where do I feed new labels
How does one "feed" the label into the label maker???? Where exactly do I "feed" it? I have a P-Touch 65 Home and Hobby
    Problem Solver:
  • 7 Answers
Press and hold the code button and press the "space button" this will feed the tape
Posted on Apr 09, 2009
P-Touch Model PT-65 Home and Hobby Label Maker - Loaded a new cartridge and it will not feed through
Sir/Madam
Its Very Easy To Fix This Issue,Just Follow Few Simple Step and You Solve Your Problem By Your Own,
Read Below Instruction,
1Turn off the label maker before installing the tape.
2Press the part marked as "<<" and lift the cassette cover.
3 Position the tape into the slot. Make sure to feed the end of the tape under the tape guides.
4Check that the lever is up before closing the cover; the cover will not close if the lever is pressed down.
5Close the cassette cover.
6 Press the power key to turn on the device. If using an AC adapter, plug the adapter into the wall then press the power key.
7Type a sample to test if your installation was successful.
Read more: http://www.ehow.com/how_7526530_install-tape-ptouch-label-maker.html#ixzz2pMqUU0oU
Jan 02, 2014 | Brother BRTPT65 PT-65 Label Maker Printer
"no tape" error
I found 2 helpful manuals from brother that you may want to checkout. they explain exactly how to install the cartridge:
http://www.ptouchdirect.com/ptouch/manual/PT1000.pdf
http://www.ptouchdirect.com/ptouch/manual/PT85.pdf
Feb 18, 2013 | Brother P-Touch PT-2400 Label Tape OEM...
I have an "old" p
When labels print i get back ground i do not want
Mar 04, 2011 | Brother BRTPT65 PT-65 Label Maker Printer
Cant find label refills
Hi there, Go to Find.com and key in Brother BRTPT65 P-touch Model PT-65 home and hobby label refills. It will take you to a varitey of different labels showing the prices. Make sure you click on the labels and make sure they are the ones compatable with your machine. Hope this helps!
Jan 15, 2011 | Brother BRTPT65 PT-65 Label Maker Printer
Tape on Brother PT-65 wraps on roller
If the end is already messed up you may need a new cartridge, if you can remove the tape and feed the end under the guide on the cartridge and re-install it should work properly again.
Sep 15, 2009 | Brother PT-65 Personal P-Touch Electronic...
I have a Brothers home and hobby PT110 labelmaker. It has new batteries. I can type the words but the tape won't feed even though the labelmaker is making a sound as if it is about to print.
You have to make sure the new tape is snapped in and then put the back back on it. After its reassembled press CODE SPACE. This will feed through the tape. If the back of the P-touch is not on it will not work... Crazy but true :)
Dec 28, 2008 | Brother BRTPT65 PT-65 Label Maker Printer
Ink will not print
www.ptouchdirect.com/ptouch/umpt65.html
this is a web page with the manual should help
Dec 09, 2008 | Brother BRTPT65 PT-65 Label Maker Printer
Need help loading cartridge for brother label maker
when you have the label maker upside down...
place the cartridge so the WHITE 12mm ect sign is on top.
pull the tape out a bit and pull it up so that it stick out where the tape would print out of.
place the cover back on tightly and turn on..
push CODE, SPACE, it will feed though and you'll be all set.
Dec 08, 2008 | Brother BRTPT65 PT-65 Label Maker Printer
Change cartridge Problem - Brother BRTPT65 P-Touch Model PT-65 Home and Hobby Label Maker Printer
Once you snap in the catridge you have to put the back of the p-touch back on. After that you can feed through the tape by pressing Code Space. If the back of your P-touch is not on it will not advance through.... I learned the hard way :) Hope it helps you all.
Jul 11, 2008 | Brother BRTPT65 PT-65 Label Maker Printer
Loading cartridge
You can download the manual from the link below: http://pub.brother.com/pub/com/ptouch-pdf/UM_PT65.pdf More information with FAQ etc on this link: http://welcome.solutions.brother.com/bsc/public/us/us/en/model_top/p-touch/65eus.html?reg=us&c=us&lang=en&prod=65eus Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 21, 2007 | Brother BRTPT65 PT-65 Label Maker Printer
Brother BRTPT65 PT-65 Label Maker Printer Logo
288 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
