Question about Mitsubishi Televison & Video
How do I set the correct input channel for S-video from laptop
I have a 48" Mitsubishi projection TV, model #48311. I need to use the S-video cable input on the front of the set to connect to my Compaq laptop computer, in order to display a PowerPoint presentation. It appears from reading the TV owner's guide that the front input is referred to as Input 3. I have used the menu system to "turn on" Input 3 as far as I know, by selecting one of the various names. (The TV menu shows a variety of input names, such as AUX, DVD, etc.) I have tried several of them, with no luck.
  • dandydon1 Feb 18, 2009
    Thanks very much, I'm sure that will fix the problem. I was too dumb to come up with it myself. Now that I think about it, I was only turning Input 3 on, I was not doing the next step of setting the TV input to that input.
    Dandydon
Press the video/tv button on your remote control until it gets to video or input 3
Posted on Feb 18, 2009
Mitsubishi rear projection tv, model WS-48311 - Lost audio after moving tv and re-hooking up cables. How do I get it back?
It sounds like this TV is being used only for the PS3. We'll need to troubleshoot this through a process of elimination.
If you're using Component Input 1 and audio, try using Component Input 2 and audio instead. If this set of inputs provides working audio and video - you can stop. Or, try going back to Input 1 once more. If Input 1 now works - you may have simply made a better connection. If it doesn't - then there's probably an issue with input 1 on the TV.
If moving to Input 2 above still didn't solve the problem, you should try using a different set of audio cables between the HDFury and the TV. If it now works, the original audio cables are faulty.
You can check the HDfury setup on another HDTV with component inputs with it connected to an HDMI cable. if the HDFury wors, you know the device and all the cables work. If you do this test and it works with your PS3, then you know that the PS3 is providing good video and audio signals via HDMI. If the problem follows the PS3 - then it's the PS3 at fault. If everything works perfectly on the second TV, then there is some issue with the audio amplifier / inputs / speakers of the Mitsu TV. You could get a cheapo stereo amp and speakers - or a set of computer speakers for audio - it all depends on how much you want to spend for sound.
Good lcuk!
May 07, 2015 | Mitsubishi Televison & Video
Tv remote codes free
IF YOU DONT HAVE THE MANUAL, LOCATE THE MANUFACTURERS NAME AND FIND THEIR INFO ONLINE AND CONTACT THEM FOR THE CODES FOR YOUR MITSUBISHI
Feb 03, 2014 | Mitsubishi WS-48311 48" Rear Projection...
Red-white-yellow inputs don't work
what model of computer do you have, what video outputs do you have on your computer, if you have an s-video out on your computer, I would use that with the tv
Mar 02, 2013 | Mitsubishi WS-48311 48" Rear Projection...
My WS-48311 has a pink screen for all imputs. Ive tried everthing and still wont go away. It does show it is in 480i in upper left corner and I cannot change that to 1080i. Any ideas?
You can't change the resolution higher if that's what the broadcast is sending. You can try the RGB component inputs, that will leave it wide open for what ever they send and max resolution your set can handle.
Nov 10, 2009 | Mitsubishi WS-48311 48" Rear Projection...
Mitsubishi WS-48311 No image, but audio
This sounds like the flyback voltage converter burnt out! (part is around 70.00) but labor will be from 2,00,00 to 5.00.00! Hope this helps
Please rate! this keeps this site free!
Thank you!
Dec 13, 2008 | Mitsubishi WS-48311 48" Rear Projection...
Need to sell working parts from a Mitsubishi WS-48311
Hi, I seen your Post. I would like to buy parts off from you. How can I get in contact with you.
Dec 02, 2008 | Mitsubishi WS-48311 48" Rear Projection...
Mitsubishi WS 48311 48'' HD 1080
There no longer available from mitsubishi, but the following link may have them or can get them. leave them an email with the model number of your set and what youre looking for.
http://servicemanuals.vstore.ca/
Jun 08, 2008 | Mitsubishi WS-48311 48" Rear Projection...
No sound
I suppose you have a surround sound system that is now not functioning? They must have disconnected your audio out cables from your television to your surround sound system. Make sure your main audio out channel on your television is connected to AV1 in on your surround sound system. It is probably an RCA cable (red and white). Then when you play your TV, make sure the audio is set on AV1 for your surround sound system by pressing the function button until AV1 is on the display. Let me know if this helps.
Dec 26, 2007 | Mitsubishi WS-48311 48" Rear Projection...
S-Video on the blue screen
menu has input selection to turn on/off or name video inputs.....T.
Oct 24, 2007 | Mitsubishi WS-48311 48" Rear Projection...
Televison & Video Logo
151 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
