I'm not sure where to connect pink camera wire.
SOURCE: CONNECTING AN AMP
Amp is powered by a main power wire to the battery, ground to metal chassis, and a remote wire (usually blue) from the D player to the remote in on amp. RCA's from CD player to amp as well. Not sure what you mean by "no amp wire on harness". Let me know so I can give you a more definitive answer.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
SOURCE: Can some1 please tell me how to connect all the
red-power(keyed), yellow-power(constant), black-ground. If you're having problems installing it, try powering it on with your'e car battery, if that works you have a blown fuse in the system.
SOURCE: the brown parking brake wire for the dvd tv for a
usually it goes to the cold side of the foot brake switch.
SOURCE: how do i wire up my amp to the pld70bt there are
The specific unit has a mono sub woofer output. It is the Grey coulerd RCA output. Buy a male to female Y-Splitter( it is a RCA connector that has one male RCA plug on one side and two female RCAs' on the other side.Now just connect that to the rca that is going to the amplifier. As this is the dedicated sub woofer output use it.
dreamsystems.
FOR
MORE HELP GO TO: ---
Car repair guide?
http://technoanswers.blogspot.in/2012/03/car-repair-guide.html
I would like to update this question I connected the pink wire which is my back up camera to my acc now my camera works only in reverse while my radio,aux, BT etc. all get a blue screen my radio works but its all a blue screen also the touch screen doesn't come up tried connecting brake wire to ground but didn't help
