Question about HP PSC 2355 All-In-One InkJet Printer
Turns on and then turns off
Hp printer nopower
  • 979 Answers
Check your power cable first. Your power switch could be bad, Try holding the power on switch down and see if it stays on then. If it does, then it is the switch. You may be better off replacing the whole thing esp. at the costs of printers today. Your issue will be finding a switch for it. Let me know how you do.
Posted on Feb 24, 2009
Lincoln sp-150 idealarc will not arc any more ground output checked ok fuses checked ok incoming power 230v ok output term for + voltage to wire on spool nopower when trigger pressed.continuity from
There is a temperature activated switch near the transformer that will turn off control voltage until the transformer cools. There is also a fuse for the control voltage. That would explain why the motor won't run. There's a possibility that the trigger switch in the handle is bad too.
Oct 15, 2014 | Welding Tools
Scanner error 52 turn off and turn on
Sir/Madam
Unfortunately there's no troubleshoot with a 52 error. As it implies it's usually the scanner bad. It sits up top- under the top cover. It connects to the Formatted Board on the left side. and there's 2 connector s at the scanner itself.
So if Your HP Printer is Under warranty ( 12 Months ) Then I Suggest You Go To Official authorized HP shop for your HP Printer Problem and Troubleshoot or Go To Official HP Printer Website To Update HP Printer Software and Driver,Or You Update It From Official Below URL Link:
http://h30499.www3.hp.com/t5/Printers-LaserJet/HP-Laserjet-P2055d-error-message-quot-52-Scanner-Error-Turn-off/m-p/5905671#M207987
or
Or
In Case You Having Still Problem Then Follow Us On:
HP Printer Support
Feb 13, 2014 | HP LaserJet 3055 All-In-One Printer
Turn on key ,nothing no power
Check Battery cables to see if they're loose.
Check fuses if it's just lights.
Jan 16, 2014 | ATVs
FSP194-3F01 NOPOWER 5V OK NO 16V OR 24V
The 5 volts is the standby voltage that should always be present, the other voltages should be there when you try to turn the LCD ON.
If the 5 volts standby are not steady when connected to the main board, Q7 might be defective.
Check all the capacitors in the secondary circuitry for bulging or leaking conditions.
Aug 28, 2010 | Protron PLTV3250 32 in. LCD Television
Wont start wont crank
YOUR PROBLEM is either Battery lower than 12volts or Starter Motor Jamed in or burnt out ,or battery lead loose on battery, or on the engine block (Black wire is earth) bolt could have come loose on engine,,
To try ,turn on lights, turn to start if lights go out then Battery flat or no good ,,if lights stay on when key turned on nopower to starter .
Let me know the out come of it Ron
Oct 05, 2009 | 2007 Buick Century
Nopower to radio on my suzuki grand vitara. any
if you connected it right, I mean red to red, yellow to yellow and black to black. check the fuse thats leading to the radio, and check the fuse in the fuse box in the car, if thats ok then just put the yellow and red from the radio together with the red one from the car, the only problem with that is that you'll have to turn your radio off every time you leave your car. don't forget, it will drain your battery
Jun 20, 2009 | Car Audio & Video
Nopower after pluging in here and at shop
What the Computer shop guy for your issue is right.We can isolate the issue this way: Try turning on the laptop without the adaptor connected and then see whether it turns on.If it does,then plug the adaptor now and check for the issue again.If it goes now,it mostly a case of the Motherboard.Only other way is to check with a known-good-adapter and see whether it works.If you are reffering to the system itself not turning both at work and here,then i would suggest disconnecting the battery and try only with the adapter.In some cases the battery also causes this partticular issue.Please let us know whether this helps
Mar 16, 2009 | HP Pavilion dv6000z Notebook
Power on password problem
Hi
To remove a bios password, you will need to disconnect the the cmosbattery (located under the system board) for 5 minutes with nopower attached to the laptop.
here is a manual how to find your CMOS battery.
Jul 10, 2008 | HP Compaq nx6310 Notebook
Printer has no Power
how long has the printer been in your family? sounds like it's starting to let you know it's on it's final episode.
Feb 19, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
HP PSC 2355 All-In-One InkJet Printer Logo
48 people viewed this question
Ben Johnson
