Question about Dito Dean Food Prep B2000-350 Bermixer Handheld Blender
Stripped Drive shaft Gears on a Dito B2000 Bermixer- Parts?
Where might I source the parts for this mixer?
The plastic gears on both the detachable drive shaft and from the motor are stripped out.
I m also uhsure on how to replace either of the geasrs.
How can I find a new Bamix old model spice blender/chopper
Bar mix products made millions for world wide sales
kitchen aids that change design so often
they cant support a large parts division
(R&D is geared to sell the next better barmix product )
if you cannot find a new old part
or super ceeded shaft from the next model up
or used drive shaft for sale online
look for a complete used bar mix spice blender/chopper
some people collect barmix units for a hobby or collection
and sell double ups
when you say old model
if the shaft is plastic ....... its .unfix able
its a heat molded construction process
Vintage Bamix M122 2-Speed Hand Held Food Blender Mixer-Chopper
Sep 16, 2016 | Bamix Blenders
Kitchenaid mixing shaft falls out w/ use
If it is model 5KPM5 then there is a pin through the shaft inside the planetary that engages the pinion gear. There is a circlip above the gear clipped to the shaft that holds the gear into engagement with the pin. I've not seen one drop the shaft out in my life, the circlip would need to pop off & the gear would need to jump up and then the pin would need to slide out. All the bits would be there inside the planetary waiting for you to discover them.
Nov 16, 2012 | KitchenAid Professional 600 6 Qt. Stand...
1.6 hp blender not blending blade is not turning
a lot of times depending on the mixer brand. they have plastis gears on inside that gets stripped. i think its time to buy a new mixer! good-day !
Aug 22, 2011 | Blenders
The chopping mechanism, which should turn freely, is "frozen" & won't turn. not even manually.
I'm assuming that this isn't happening on an model in which the bowl can be detached - otherwise the plastic bushing has melted and glued the shaft to the base of the mechanism - it will have to be replaced. You can find one on the Breville site
http://www.brevilleusa.com/blending.html
select yours and you will find it in the Parts &Accessories tab.
The mixer has an plastic bushing on the shaft of the chopping mechanism that is there to connect it to the shaft of the motor. If that bushing or the bearing of the shaft got damaged in any way the entire mechanism will lock out.
To find out what exactly happened you will need to dismantle the mixer - take out the 4 screws on the bottom, unclip the power wire, remove the supports of the motor and pull it out for inspection. Parts from older models can be obtained only from a dealer, you will have to contact one and order it .
Jul 30, 2011 | Breville Blenders
The gear at the base of my waring bb 180s blender is stripped
You can try the sears online parts store for help they may be able to get the parts you need as they are pretty much the same. iF YOUdon't find it let me know and I will resurch it for you and find the part it is eather the druve nut has come loose or the teeth on the plastic shaft has worn off, it is possible to super glue it to hold if you cant find the part.
Nov 12, 2009 | Waring BB180 Work Top Blender
<span
Lo siento si mi español es malo - Yo uso un traductor. Contacto Dito Dean y debe ser capaz de conseguir un manual. Número de teléfono Dito Dean debe estar en la propia máquina. Por lo general, será sellado en la parte posterior o inferior. Buena suerte! :)
Aug 27, 2009 | Dito Dean Food Prep BKP-350 Bermixer...
Plasic gears
Not usually is the short answer. If you can find a Sharp repairer who may have that part in, they can repair it. Or contact Sharp customer support services (google the company where you are).
In the UK Sharp have more or less closed down most of their Household Appliances other than their microwaves and it is difficult to source parts generally.
Jun 27, 2009 | Sharp EJ-12GDW Work Top Blender
Broken gear on BFP-703 base
The drive is replacable and available from Cuisinart, you will have to sign a waver to get the part. the drive is screwed onto the motor shaft with reverse threads. the plastic drive will have to be completely broken off of the unit to expose a brass"nut" which was internal to the drive. depending upon your model you may have to remove the lower half of the base unit to access the lower part of the motor shaft. there will be a slot in the end of the shaft for a large flat blade screwdriver. this is used to hold the shaft still while turning the drive "nut" with a vice grip pliar or similar. the new drive is just threaded onto the shaft and normal operation tightens it.
Feb 14, 2007 | Cuisinart BFP-703 Blender
Dito Dean Food Prep B2000-350 Bermixer Handheld Blender Logo
178 people viewed this question
Top Dito Dean Food Prep Blenders Experts
eyecam
Are you a Dito Dean Food Prep Blender Expert? Answer questions, earn points and help others
