Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
I have a diferent problem, i have sound and picture, but the picture is kinda gray, i can see pretty good but something is wrong.. i dont know how to fix it
    Genius:
  • 1,139 Answers
Hello marcosviperz,
Please check your cables from your antenna into your TV or from your cable box into your TV. Make sure they are connected properly. If this does not clear up the problem then check to see if any of your other inputs cause the same issue to occur. Now if that does not help, you may have a problem with your video processor, or more to the point a problem with the chroma section in that processor, in which case you will either have to replace the processor or the board on which the processor is located. If you do not have a background in electronics I would suggest having a TV technician troubleshoot the problem and offer you a course of action.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Posted on Feb 25, 2009
I have a 94 grand marquis with a power lock issue.
Sounds like signal loss at the master switch.
Jan 09, 2014 | Cars & Trucks
I have 2000 Chrysler Voyager 2,5 TD. 4 days ago i exchanged at home my valve cover gasket.I was cleaning old gasket remains and washed cover.There wasnt anymore oil leaks.I did it slowly and cearfuly.Was...
check to see if oil is gray that is a good indicator of blown headgasket also check for moistor at tail pipe by holding your hand at it for a few seconds. if moister is and hand that is a good indicator of bad head gasket. also is it going through water
Jun 27, 2011 | 2000 Chrysler Grand Voyager
I have another boring probleM0! my computer is running pretty well (all beeps and jeeps r included) but my monitor shows a blank screen! After showing ASUS (my motherboard) and beep about 3 times, the...
those beeps are actually codes telling you HEY something is wrong with me and that particular beep means there is something wrong with the display card so you should try to re seat your graphics card or maybe even check to make sure that you ram is good and in working condition
Dec 28, 2009 | XFX GeForce FX 6800 (256 MB) Graphic Card
Infocus X2 projector shows picture in black and white only...
that little glass square broke off of the colorwheel, and it needs to be replaced. that yellow/gray line is from the light tunnel collapsing. both parts can be purchased and replaced by you. if you don't feel comfortable doing it, you can send it in to an authorized service center. try av solutions. they're pretty good. you can purchase infocus parts from them, too.
Oct 27, 2009 | InFocus Office Equipment & Supplies
My kz 650 sr smokes gray what do you thik the problem is and has loss of power and doesn't idle right
re-set the Air/Fuel screws, or the engine may be rode pretty hard burning the rings out, if carb adjustments dont help, then dosent sound good based on what I know
Oct 04, 2009 | 1979 kawasaki Z 650 SR
Clunking noise
Have you checked your struts? Sounds like either lose or failing. Also recheck lower ball joint and control arms, although that will also be felt in steering. Good luck and have a good day.
Mar 24, 2009 | 1996 Subaru Legacy
Will not start
if you feel pretty confident that it is the starter a quick test to do which may sound kind of scary and wrong would be to have someone go under the car with a hammer...yes a hammer...and have another person in the drivers seat and when both people are ready (assuming that the person under the vehicle really knows where and what the starter looks like) try cranking and hitting the starter at the same time... ya gotta hit it pretty hard too... i know this sounds crazy but what it does is knock the magnatized solenoid in the starter and gets it rotating to start and crank the engine over...
if the engine starts you can pretty much guess you need a new starter.
get it checked out for sure
and maybe ask some of ur friends if they've ever done this method
Please dont do it if you dont know where the starter is or feel comfortable
hope that kinda maybe helps
Aug 08, 2008 | 2000 Volvo S80
Distorted Sound on Laptop after drink was spilt
try to open up your keyboard and try to clean some part of of your keyboard maybe grounded
Mar 24, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
