Question about Ricoh 4506 Copier
ERROR SC410 ON AFICIO 4506.. ANY HELP APPRECIATED adanquah@gmail.com
  • ALBERT
    ALBERT Feb 18, 2009
    thANKS A LOT. WILL KEEP SEARCHING..
  • 541 Answers
You need to change the transfer before you do anything else this will cause this code
Posted on Oct 11, 2009
  • Ricoh Master
  • 2,794 Answers
I know an SC 411 means this:
SC411: Separation bias leak error
-Definition- [B]
A separation bias leak signal is detected.
- Possible causes -
• High voltage supply board defective
• Poor connection of the PCU
• Discharge plate defective
Usually a 410 would be in the same ballpark on a Ricoh computer. Unfortunately I don't have the service manuals for 4500 series machines. If you can get a hold of a Ricoh tech in your area, it would be a good idea to rest the power supply and check the pcu as well.
Posted on Feb 18, 2009
What is error code 4506
Google search your manufacturer make and model and the words error code 4506. If info is available, you can find it in the search results.
Mar 18, 2015 | Office Equipment & Supplies
Tip
Trouble Shoot and Bullitens
SC120 Displayed instead of SC122 when the scanner home position was initialized 001b BICU engine firmware Install new BICU engine firmware
SC142 Intermittent or continuous 025 Defective CCD (vapour from adhesive) Replace the lens block assembly with one that is not defective.
SC280 In color mode (2C or more) with LT LEF and duplex, SC280 occurs falsely if 5 or more originals are scanned during machine warm-up. 001b BICU engine firmware Install new BICU engine firmware (ver. 1.242.01 or later)
SC280 False detection when the main motor direction changes from backwards to forwards 001i BICU (Engine) firmware
Install new BICU (Engine) firmware (ver. 1.31:01 or later)
SC305 008e Toner drops from the dev. unit, between the charge corona cleaner slider and cleaner driving screw
Clean the screw and slider with a damp cloth.
SC410 Unnecessary SC410 generation 001d BICU (Engine) firmware
Install new BICU (Engine) firmware (ver. 1.262:01 or later)
SC420 Unnecessary SC420 generation 001e BICU (Engine) firmware
Install new BICU (Engine) firmware (ver. 1.275:01 or later)
SC481 022 Torn image transfer belt Install a new PCU.
on Aug 14, 2010 | Ricoh Aficio 1232C Color Copier
Hi sir Ihave aficio 4506 the problem with cod no: 303 looking for ward to hear good news
sounds like that the charge wire broke,bit that seats above drum unit (black handle) 1 screw
Nov 01, 2010 | Ricoh 4506 Copier
Ricoh aficio 4506 error code sc422
SC411 Separation bias error SC422 Main motor lock
Jan 15, 2010 | Office Equipment & Supplies
SC 400
Hello sir; The error code you post out, it's means "transfer belt bias problem" that you have go to high voltage board ,I/O board or main board, before we go, why don't try make a reset;
1, press "clear mode" key, then enter 107 then press and hold down "clear/stop"..
2, turn power off and on.
Jan 11, 2009 | Ricoh Aficio 450 Copier
Print problem With Ricoh 4506.
First of all E-310-285522 is not an error code.It is the Fiery printer number.
Looks like you have enabled password for this copier and ticked accidentally the "password for printing".
May 01, 2008 | Ricoh 4506 Copier
Error sc 422
I HAVE THE LASER C522 AND I HAVE PROBLEM TELL ME REPLACE WASTE TONER
Feb 10, 2008 | Ricoh Aficio CL2000N Laser Printer
Error code sc 422
422 D PCC leak
- Timing & Condition -
When the current leak is detected
for 2 seconds, leak detection
starts 1 second after the PCC
turns on. The leak signal is
monitored twice at 1-second
intervals. When the leak condition
is detected twice continuously,
this SC is displayed.
1. Check if the PCC unit is properly installed.
2. Replace the corona wire if it is broken.
3. Check if the connectors on the terminal and
high voltage supply board (T1, PCC)
are
properly connected and if the cables are
damaged.
4. Clean the receptacle.
5. Replace the high voltage supply board (T1,
PCC)
6. Replace the I/O control board.
7. Replace the main control board.
- Signals to Check -
[A258/A259/A260]
Leak Detection:
CN227-B1 on I/O control
Board
[B017/B018]
Leak Detection:
CN221-B1 on I/O control
Feb 10, 2008 | Ricoh Aficio 450 Copier
Ricoh 4506 Copier Logo
558 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
