Question about Whirlpool GS6NBEXR Side by Side Refrigerator
Refrigerator leaks water
My refrigerator leaks water every couple of days. i have turned off the water line and it still leaks water from the bottom left front corner. where could this water come from
  • 410 Answers
Most likely you have a plugged drain int he freezer compartment. if yo will look under and behind the lower basket in your freezer you will most likely see a bunch of ice build up. clear this ice out then you will see a drain hole in the center section behind the metal cover in the rear try to get some hot water into this hole to clear ice and to clear the drain then u shoul be good to go. thanks for using Fix Ya Peyton
Posted on Feb 18, 2009
Whirlpool refrigerator is leaking cold water from the lower left hand corner.
Behind the refigerator are valves and water hoses going to the water dispensor and the ice maker. Anyone of these hose could have a leak either at the connection or the hose. I would not attempt at repairing this unless you are real familar with this problem or appliance repair man.
Feb 16, 2013 | Refrigerators
Water leak on floor under refrigerator
The line going into the dispenser is a 5/16 line. You'll have to remove the front of the dispenser on the door to get access to the line to unclip it. Once you have that done you can pull the line out from the bottom. At this point there are a variety of different unions, compression fittings, etc. to splice the line. After that you just feed the line back through the bottom of the door, clip it back in place, put the dispenser back together and your done.
Jun 15, 2012 | GE Refrigerators
Water dispesner does not work but ice maker does
This happened to me a couple of times, when I didn't use the dispenser for a few days while on vacation. What happened to my water tanks is that they froze between the dispenser and the filter. pull out the bottom drawers and remove the tank covers on the left side. This is all the way in the lower left corner of the fridge compartment. The lines seem to freeze back there, so get a hair dryer and thaw them out!
Feb 16, 2011 | Samsung RFG297AARS (285 cu ft) Bottom...
I have a jenn air side by side and water seems to be leaking near the front left corner area at random times and when it does leak it is a slow drip.... thoughts?
Look in the freezer floor to see if you have ice built up and over flowing into the floor. If so you have a clogged drain line which is located in the freezer behind the lower basket in the litttle gap at the bottom of the back wall. If you don't have that, the water line that runs to the water in the door is located at the front left side as well and you can get to that by pulling off the bottom piece of plastic that runs along the bottom of the whole machine.
Oct 31, 2010 | Jenn-Air JCD2389G Side by Side...
It's leaking
Mine was leaking from the front left freezer side. I removed the tray at the bottom and saw that there is a drain hole in the back. I removed the sheet of ice that was covering the drain hole and poured vinegar and hot water to unclog it. That was the problem all along! The drain hole was clogged causing the water to drip out of the front. Whew!
Jul 02, 2010 | Hotpoint HSS25GFP Side by Side...
Frigidaire leaking water out the bottom
it comes from freezer. remove back cover of freezer and unclog hole where water collects
Feb 13, 2010 | Frigidaire GLRS234ZA Side by Side...
Have a TFX26ZPDA that occassionally leaks from front freezer corner. notice of leak anywhere, but find water under the fridge on the floor (facing fridge left bottom)..........why is this
I would check the bottom of the freezer. If its a solid block of ice then you have a frozen drain line. You may have to remove the back panel to access the drain or on some models there is a gap there its located in the back. If you take a turnkey baster and fill it with hot water and keep shooting it down the drain line it should eventually thaw out. The water is coming from your evaporator coils when they defrost.
Hope this helps _MJ_
Feb 07, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Hotpoint csx22bc 21.7 cu. ft. leaking water on freezer side
Look for obstruction at the drain tray for the freezer. Common to have plastic wrap sucked into that area.Or gunk in the drain line. Blow through line to insure the gunk is not an issue.
Mar 01, 2009 | Whirlpool 21.7 cu. ft. Side-by-Side...
How to locate the water filter
Be sure to turn off the water valve before you start.
The water tube is probably kinked at the front lower left corner. Take the front lower grill off of the refrigerator and open the left door (freezer) and see if the translucent plastic tube is kinked where it comes from the bottom of the refrigerator and goes up into the door.
If it is, there is plenty of tubing to allow you to pull it out of the connector at the corner and cut off the kinked part and re-insert the tube.
Turn the water valve back on.
(This was the problem with my fridge and I had to show the Sears technician.  He had already told me to call a plumber and get a dedicated water line due to low water pressure!  Imagine the cost if I had believed him.  Works great - good flow and no leaks.)
Hope this helps.
Nov 23, 2008 | Kenmore 57029 Side by Side Refrigerator
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
327 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
