Question about Sony Playstation 3 (PS3) Console
Starting menu problem
The screen is black and i have tryed everything and it wont work what do i do
    President:
  • 2,653 Answers
If you've already tried the video reset the problem is most likely related the RSX chip on your motherboard. I would call Sony for repair service. You can reach them @ 1-800-345-SONY
They charge a flat rate of $150.
Posted on Feb 20, 2009
MY TOUCH SCREEN ZTE GROOVE MUSIC DOES EVERYTHING BUT THE SCREEN WONT WORK HOW DO I FIX IT
Mine Does The Same Thing I Am Trying Everything Letting Get Air And All It Still Wont Work I Really Need this Phone And My Screen in Black CANT SEE ANYTHING its a ZTE GROOVE PHONE
Jan 18, 2013 | Cricket Wireless Cricket - Zte X501 Groove...
Please help me recover months of hard work saved on PC. Will not load past Windows page then re-starts its self.
ok it's ok Start your pc once you get to the ASUS screen tap the button to get into your bios or "Setup menu" most likely F2 once done you should get a menu goto SATA DRIVE or SATA TYPE or just SATA either (achi or IDE modes) change from (IDE to ACHI) or from (achi to IDE) ok if that does not work please feel free to reply
Jun 15, 2012 | ASUS Eee PC 900HA Notebook
Zte model x500 touch screen wont work
No solution but Im having the same exact problem. Cannot reset either due to non responsive screen. Please let me know if u found a solution. Ty
Mar 11, 2012 | ZTE Score
I deleted everything and now it goes to a black screen
Start the computer, and watch for the screen at the bottom to indicate to press F11 or to run setup. Once here, You'll see a file menu. Press F9 on each one and save the defaults. Once you reach the last, Exit Menu, press F9 and press yes to save defaults.
Press Exit again, and exit saving settings.
The computer will restart again. If the OS (operating system) does not load still, restart the computer again, and press F1, or the indicated F command shown at bottom of screen to go into Loading List.
This list will allow you to start the computer and operate in "Safe Mode". NOTE: some programs will not operate or run in safe mode,however you should be able to downlaod the appropriate driver.
If this does not work, insert the Operating System CD and re-install from the start - if you are prompted for repair or install, select Install.
Please let me know if you need further assistance.
carsandcomps,
Guru, Premium Expert @ Fixya.com
Jun 14, 2010 | Dell Dimension 3000 PC Desktop
Gateway w350a when turned on wont get past the black screen
gateway w350a T-series HDMI power on but screen stays blank...Its just a black screen. Is there a fix for this?
Mar 31, 2009 | Gateway M305CRV Notebook
Lcd screen broke external monitor wont work
Sounds like you resolution is too high or vista doesn't recognise your driver.
Try starting in Safe Mode by powering up your PC and tapping the F8 key until you see a menu. Select Safe Mode from the menu. Once in safe mode change the resolution to 800x600 then restart in normal mode.
If that doesn't work then download and install the correct drivers for your display card here;
ftp://ftp.work.acer-euro.com/notebook/aspire_3680/
Once downloaded, you may need to install it in safe made once again.
Thanks
C
Mar 28, 2009 | Acer Aspire 3680 Laptop
Monitor stuck on black, menu buttons not responding
It's sort of a solution, but I work in a computer shop and got this screen in yesterday. I looked at it closely and it's actually the backlight that died. I pulled it apart and found that three of the 820uF/20V capacitors had swollen up. If you replace them then you should be fine, but I went for a different approach and took the inverter board from a laptop and put the in the screen and used an external power supply. It's a bit dark but it works fine now.
Aug 08, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
New songs= black screen
try to remove the battery, wait 30 seconds and replace it
this should reset your sansa,
a real hard reset isn't possible,
you can format it though
warning, this removes everything
To format your Sansa E200 series MP3 player:
1. Open "My Computer."
2. With the player plugged into the USB port, right-click on the player (if in MTP mode) or the drive letter for your player (if in MSC mode) and select "Format" from the right-click menu.
3. Press "Start."
4. You will receive a warning that the format process will erase all data on your device.
IMPORTANT: Make sure you have backed up all of your data from the device before continuing with the format. Procedure will erase everything off the player. Agree to the warning.
5. The format will complete. Close the format window and your player should be ready to use.
After the format, please install the latest firmware update for your player. Please visit the following link to download and upload the Firmware on your Sansa E200:
http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00...
PLEASE NOTE: All files will be deleted. Backup your files. Your MP3 player must be in MSC mode before installing the Firmware update.
To set your player in MSC mode, please do the following:
1. When the player is turned on, press the “Menu” button.
2. Navigate to the “Settings” menu.
3. Navigate to “USB”.
4. Under the “USB” menu, go to “MSC”.
After changing the player to MSC mode, reconnect it to your computer. The screen on the MP3 player should read “USB Connected” and "MSC”
You can now complete the Firmware update download from SanDisk.com on your device.
Installation Instructions:
1. Unplug any other USB flash drives that's connected to any of your USB ports.
2. Download the firmware to your PC
3. Plug in your e200
4. Double-click on the downloaded firmware (e200fw01.00.12.exe) and follow instructions
5. Unplug your e200
6. Device will do it's own update process and will restart.
The device should be ready to be used again.
Dec 16, 2007 | Audio Players & Recorders
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
