Harman Kardon AVR 120 Receiver Logo
Posted on Feb 24, 2013
How to hook up harmon kardon arv 120 to cable box and sony wega tv
5 Related Answers
Anonymous
  • 440 Answers
  • Posted on Feb 11, 2008
SOURCE: hooking up an amp
plug eash units sound in red whites from dvd tv main out the set speaker wires in place front ch a ok turn it on make sure ch a speakers on only select corect video input dvd ect turn it up
Anonymous
  • 71 Answers
  • Posted on May 05, 2009
SOURCE: No audio from TV on Harmon Kardon AVR35 Receiver
I am attaching some pictures that will show a couple of wiring schemes based on the type of home theater you have. If you have questions with the set up of your HK receiver, please reply with those questions prior to rating your help.
lykohavi
  • 5 Answers
  • Posted on Aug 23, 2010
SOURCE: i have my harmon kardon avr 35 hooked to my tv.
Hi kjlennon,
If you using antenna tv most likly the AVR gives you RF interference into your tv.
Using ferrite choke on your AVR power cord can help you reduce it.
lykohavi
Anonymous
  • 41 Answers
  • Posted on Jan 06, 2011
SOURCE: I have a harmon kardon
Check that the player's Dolby / DTS is enabled. Sometimes it is defaulted in the player to 2.0 / Stereo PCM. What model Samsung? Those Harman receivers are old favorites of mine...
Anonymous
  • 9 Answers
  • Posted on Jan 31, 2011
SOURCE: Just bought a Sharp LED TV and there is a slight
Hi if there is an optical out on the television i would use that direct to your Harmon Kardon AVR 125, the sound would be in sync with picture, as the source is the same.
I have a harmon kardon and I cant hook up sound to my tv
you can alternatively hook RCA cables to the cable box/satellite receiver or to the dvd/Blueray player
Just bought a Sharp LED TV and there is a slight delay between hearing sound and seeing lips move. Have cable box hooked up to tv by HDMI and have cable box hooked to AVR (Harmon Kardon AVR125) by optical...
I have a harmon kardon avr 120 and a samsung blu ray player.the audio is connected through the optical cable. the receiver however is only playing 2 channel audio. but my direct tv, which is also...
Flat screen tv stopped working suddenly hooked up thru HK230
Hi there bud , Are you sure you are using the RCA cables correctly? and not just connecting the speakers into the T.V?
When plugged into my tv they are not very loud, why please
Probably because your TV does not have a built in speaker amplifier. You'll need to hook up a small amplifier to your speakers. Hook up audio cables to the TV AUDIO OUTPUT and then to the INPUT of the amplifier. Hook the speakers up to the AUDIO OUT or SPEAKERS OUT on the amplifier. Probaly have to take a trip to a place like Radio Shack to get the correct cables.... Good Luck.
Problems with setting up Harmon Kardon AVR 146????
in what display i need to put reciver when i use the optical digetal
1helpful
I have a Vizio 42' and a cable box and there's a constant humming
I think I had the same problem. This is how I fixed it.
I have my vizio 42 hooked up to a Harmon Kardon surround sound, and the digital cable box. Essentially, I can adjust the volume 3 ways - through the tv, cable box or av receiver. The humming sound happens when you have the volume maxed out on the av receiver and not the cable box.
For example, the sound level on my Harmon Kardon goes from -10 (lowest) to 10 (loudest), with 0 being the middle ground. The buzzing was happening when the Harmon Kardon was set to 10, and I was using the cable box volume to adjust the sound. To fix it, I turned down the volume on my receiver to 0, which may be about 50% max volume of the receiver. Then, I switched devices and used the volume on my cable box. This got rid of the static I was getting. Hope that helps.
Best picture and sound
connect coaxial cable connector from your cable service company to cable box-----in jack.
2-using coaxial cable connect cable box out to tv-vhf/uhf jack.
connect projection tv audio out (var-fix)jacks to avr 230 line in.
Top Harman Kardon Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Sean Wright
Sean Wright
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
