Question about Philips Magnavox 27MS343S 27" TV
A certain channel will not show up on my TV.
AMC ( channel 57) will not show up on my TV. There is only ''snow'' and a weird noise. I have a relatively old TV, and i would like to fix it quickly, for a movie is coming on shortly and I would love to watch it.
  • 55 Answers
If the TV works for all the other channels it's not the TV. Check with you're cable provider.
Posted on Feb 18, 2009
What TV shows are free on Roku?
Roku gives more free classic channels to the Roku users, in that way Roku giving you the classic TV show "OFF THE MAP". Roku activation code link will help you to get free channels. Grey's Anatomy is the writer of "Off the map" TV show. This story is about medical cases, casting done by the great actors Jason George, Zach Gliford, Martin Henderson, Rachelel Lefevre, MamieGummer and co actors.
If you want to watch this show on Roku first you need to activate your Roku device, after that, you can get more channels and TV shows on Roku by free of cost. Why I suggest Roku means you can get noise free streaming and good quality.
If you want to watch OFF THE MATCH show on free of cost call this toll-free number 1-844-965-4357 and get your Roku device.
Sep 15, 2017 | Televison & Video
Mitubishi wd-73738 turns off after 1 min
Weird noise is high pitched or even grinding sound? Sounds like a fan but is not?
Dec 14, 2012 | Mitsubishi WD-57833 57" HDTV
Interment or no volume on certain channels.
make sure set not set to sap mode as this can blank audio on certain channels
Sep 03, 2012 | Panasonic TC-P42X1 41.6 in. Plasma HDTV
My tv sanyo cm21kf81A, chassis number FC3-G221 has snow noise on all tv channels, but AV1 and AV2 play good sound
First check cable wire or whatever is connected to set for channels--the leads are connected and wiggle them with set on to see if it clears up--could be a connection where cable wire is connected at end--loose connection there etc.
If tuner is bad causing this and you use a box for signal--most have rear audio/video outputs you can connect to a unused video/audio input on rear of set---bypass the tuner in the set and operate set that way changing channels on box instead of set.
let me know if you have questions or have more information.
Mar 21, 2012 | Televison & Video
Scheduled a timer recording of a program on a DVD+R and when I went to play it back all I got on the screen was noise and snow. I now realize that I used the wrong disc (should have used only DVD-R). ...
Hi,During timer recording adjustment you must have selected what ever you want to record..i.e: Tuner Channel , or ,Video1 input ,or Video 2 input etc..This problem is related with Source selection but not with - + type Disc..wrong disc will refuse to record at the beginning..
The noise and snow shows that your recorder was Recorded an unadjusted RF channel..thus no TV signal was available during recording ..
I assume that your DVD recorder has built in TV tuner in...To correct the problem,first you make an automatic Ch set up ,search the available channels either on the Cable (if you have ) or RF local channels thru Arial Antenna..
than you try to record again by carefully selecting ..you will record TV RF channels successfully. Or you can attach another video source to your Recorder thru the RCA cables on the back panel and by selecting the respective SOURCE in accordance withe cabling you have made than you will record the AV signals available on your Receiver..
If you need more help pls let me know for further advise.
Aug 10, 2011 | Toshiba DVD Recorder
I am using this with Cubase AI 4 and my output is too low and if i try and turn it up, i get too much background noise. What am I doing wrong? Also when i listen while recording it sounds low but find, but...
if you have leopard or snow leopard, it is probably osx. i know for a fact that leopard has issues with usb recording devices, i dont know about snow leopard, tho.
Nov 23, 2010 | Yamaha MW10C 10-Channel USB Mixer
Sharp 36K-S400
Check the tuner input mode it has (air, cable,hrc,irc) with new stations updating to HDTV the demodulation at the tv sometimes looses the color burst sync. I have seen this with more and more tv's with pip tuners , it resets to the default of air ( rabbit ears ) at 75ohms and the low band snow, when you go to the high band (56+) it finds the color sync and resets the vestigial sideband offset, it happens more often if the SAP or CC is also trying to aquire the proper offset. good luck.
Nov 17, 2007 | Sharp 36K-S400 36" TV
Messed up channels.
have the cable company check your cable.thier signals are not comming into your house properly it is weak.good luck.
May 18, 2007 | RCA F19207BC TV
Philips Magnavox 27MS343S 27" TV Logo
60 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
