Question about Dishwashers
No power to dishwasher - no lights, etc.
Control panel not working on Kitchaid KUDP01FL, and bottom of dishwasher full of water....looks like it stopped midcycle and now it's shorted out? thoughts, ideas?
  • Anonymous Feb 18, 2009
    I have the same problem
  • 640 Answers
Check ,,fuse on control board..onthejob
Posted on Feb 18, 2009
Are there any simple steps to try to fix my dishwasher kudp01fl that won't start?
Check and clean filter if blocked this would stop machine working hope this helps
Jun 25, 2015 | Dishwashers
Dishwasher wont finnish rinse cycle
can you provide the make and model number of your dishwasher ..........
If it is wiring fault
check the wiring to the door switch, the wiring between the door and the lower part of the dishwasher, and the wiring to the timer. Repair any broken, burned, brittle, or defective wiring, using the proper appliance-grade wire and connectors.
Oct 19, 2008 | Dishwashers
Dishwasher stops mid cycle
Do the foll. things:
1)Check if there is water on the bottom pan. Remove the panel down on the backside of the machine and look. If it's water there, wipe it well up with a towel or so. 2)if ur dishwasher doesn't starts then: First, check the usual suspects: Make sure the circuit breaker isn’t tripped and that the wires at dishwasher’s power junction box aren’t burnt. If all that checks out, then go right to the control panel area.
Asko dishwashers have had problems with the wiring in the control panel area burning or melting– very messy. While your problem may not be as dramatic as that, the problem may still be visible. You may find burnt or discolored wire terminals or the spades on the start button switch may be burnt– anything burnt or discolored has to be replaced. You can buy any replacement parts you need right here.
Goodluck,
Dont forget to rate me as fixya..
Jan 29, 2008 | Asko 24 in. D3120 Dishwasher
Disherwasher will not work
What you need to do is take the cover off the front by removing the screws on the back of the door, then remove the cable that connects to the control panel. Then power it back on and see if the pump comes on briefly. If it does then the control panel is bad, if it does not then the power transformer is suspect.
Mar 19, 2014 | Whirlpool Dishwashers
Stopped midcycle, water not drained, no lights, no reset, input power good
The most probable thing wrong that made your dishwasher just quit mid cycle and wont now do anything is going to be a blown fuse on the control board. It's a fairly common problem with that brand,so much so i have written a tip about how to check it. Here is the link to that tip,
http://www1.fixya.com/support/r10341846-will
GENE
Oct 06, 2011 | KitchenAid 24 in. KUDP01FL Built-in...
Maytag dishwasher stopped mid cycle with water in bottom. no touch buttons work. Should I start looking for a new one?
I had no lights on my control panel, eventhough power was good.
I replaced the control panel ($265 part), it worked for 2 weeks, then I now have the same problem.
Frustrated, I am probably going to buy new from a different manufacturer.
Whirlpool/maytag does not warranty electronic parts if you do it yourself.
Sep 09, 2010 | Maytag MDB8601AWB Built-in Dishwasher
Hi, I have a KitchenAidDishwasher (Model KUDP01FL). It's worked well for a few years. Yesterday, when we went to turn it on, none of the lights on the buttons were on. WE can't turn it on at all. The...
Kill the power to the unit. Pull the control panel down to access the control board located on the right hand side of the panel. There will be 2 wires coming in to a white plastic clip on fuse located on the side of the control board. It will have a plastic pliable shield over it. Pull the 2 wires and check for continuity across this fuse. If no continuity then go to parts house with model number of unit and ask for thermal fuse for your unit. Replace this fuse following the instructions included in the kit and use all the parts included in the kit.
Apr 11, 2009 | Dishwashers
KitchenAid Dishwasher (KUDP01FL) - electrical problem
Apr 11, 2009 | KitchenAid KUDR01TJ Dishwasher
No power
check the thermal fuse located on electronic control 2 inch square fuse problalby no continuity through it, Replacemant comes with wires attached and instructions for installation
Feb 20, 2008 | KitchenAid KUDR01TJ Dishwasher
Zanussi 21 in. DCE5655 Free-standing Dishwasher
There is water in the bottom panel which has activated the float switch which overrides everything to stop the room the dishwasher is in from flooding. Remove the panel look for the leak. In my case one of the pipes had come off. There will be a lot of water in the panel so try and drain it first, tip the washer forward over some sort of container to catch the water. In my case I got very wet.
Jan 01, 2007 | Zanussi 21 in. DCE5655 Free-standing...
Dishwashers Logo
295 people viewed this question
Top Dishwashers Experts
Mike Cairns
Mike Cairns
