Question about Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Is it ok to use green works on a microfiber cloth to clean hdtv screen?
NO, use distilled water and a microfiber cloth only, or any non abrasive non lint cloth.
Posted on Feb 24, 2009
How do I get streaks off the screen?
I use a brand new microfiber cloth. Mist the cloth with a spray bottle a few times with clean water. And brush the screen lightly with only the microfiber by folding the cloth into a square. If the stain is persistent try a LCD screen cleaning product
Aug 03, 2015 | Sanyo DP42848 LCD TV
What's the best way to clean a tv screen
Mild soap and water with a microfiber cloth with TV off. Then I wipe only water on the cloth to remove any residue then quickly dry with a dry microfiber cloth.
Sep 06, 2014 | Televison & Video
Flat screen
Use distilled water and a microfiber cloth for best results. If the screen is really dirty, use a diluted household cleaner, such as 409, either sprayed or sponged on, then dry with the microfiber cloth.
Jan 23, 2014 | Element ELCHW402 40 in. LCD HDTV
How do I clean my lg screen on my tv properly
Hello
Buy one Bottle of Monster ScreenClean Home & Office Display Cleaner
Make sure your TV screen is completely cooled before cleaning. Have TV turned off for about 30 minutes before cleaning to allow screen to cool off. Unplug TV. Make sure the area where TV is located is well lighted. This will make it easier for you to see if you are leaving any smudges behind when you clean your TV screen. I suggest you get a Monster ScreenClean Display Cleaning Kit, unless you have a couple of clean and quality Microfiber cloths in your home. If so, you can buy the ScreenClean solution separately. Some LCD TVs come with a Microfiber cloth, but they are usually a bit small
Spray Monster ScreenClean to Center of TV
Assuming you are using the Monster brand display cleaner, remove the little plastic cap on top of the bottle pump. Please do not try to go cheap with display cleaning solution when you most likely have a not so cheap TV. The cleaning solution will be much cheaper than having your screen repaired or replaced. The Monster directions state to either spray the ScreenClean solution onto the Microfiber cloth or directly onto display surface. Although the Monster solution is drip resistant, it does trickle sometimes, although very slowly. For that reason, I suggest if you are going to spray your screen directly with the Monster solution, spray toward the center of the TV screen about 8 inches away from the surface. Do not worry, if you forget and spray the solution closer to the frame of the TV, the display cleaning solution is still rather slow in to trickle down your screen. Just use a little caution
Gently rub Microfiber cloth in a circular motion to apply the cleaning solution evenly over entire display. Repeat with dry portion of the Microfiber cloth if the TV screen needs extra polishing. You may get a smudge free cleaning without the dry portion of your cloth if your TV screen was not that dirty
To clean the frame of most LCD and plasma TVs use a clean eye glass cloth dampened with water. Make sure to go in one direction around the frame of the TV. Check manufacturers directions to be certain, but for most the eye glass cloth should be fine. Since it is made to take care of eye glasses, it does not scratch. For certain it works fine on the Samsung Touch of Color TV frames
May 13, 2011 | LG Televison & Video
Cleaning screen for flat screen tv
The only safe way to clean a flat screen is to use a microfiber cloth. Use the cloth alone on the television screen but if there are resistant stains lightly mist the cloth (not the television screen but the microfiber cloth) with water from a spray bottle. Try wiping across the television with the slightly dampened cloth and wiping back over it with a dry microfiber cloth. Even when the screen cleaning kits say they do not contain alcohol and that they are safe if it turns out that there was accidentally a wrong ingredient added to the mixture it is too late to do anything once it has been applied. The screen would just be messed up, and warranties don't cover that.
May 07, 2011 | Televison & Video
How to clean fingerprints from screen
Microfiber is your best solution - it picks up dirt and oils rather than smearing them around which can lead to scratches on you screen. And all you need is a little water - no chemical product needed.
We have an LCD TV monitor and also a flat screen imac - both of which require TLC when cleaning. I've been using microfiber cloths made by a company called Norwex. I use a damp enviro cloth to wash, and then their nifty and amazing microfiber window cloth to dry - it works wonders!
You can't buy them from your local stores, but you can purchase them online - a great site to buy from is www.norwexhealthycleaning.com
Dec 31, 2009 | Vizio VW32L 32 in. LCD HDTV
How do you clean the screen on a panasonic flat screen tv
When I first got mine, I used Windex and a microfiber cloth to clean it.
Now, I use Phillips Screen Cleaning Gel. It does a better job and doesn't leave streaks like the Windex did at times.
Whatever you decide to use, the best thing to do is spray the solution on the microfiber cloth instead of directly on the screen.
Using a microfiber cloth will ensure you're not inadvertently scratching your screen.
Aug 23, 2009 | Panasonic TH-50PX75U Plasma HDTV
Plasma tv scratch
Things You’ll Need:
* Television screen cleaning products
* Cleaning schedule
* Microfiber cleaning cloth
Clean Your HDTV Screen Properly
Step1
Read the warning labels on all your household cleaning products. Even glass cleaners might not be suitable for use on an HDTV screen, so check the manufacturer's warnings before you apply anything to the screen.
Step2
Keep chemical cleaners away from your HDTV on cleaning day. The harsh chemicals found in most common cleaning products will actually cause more harm than good.
Step3
Leave liquid cleaners under your sink when cleaning your HDTV screen. A liquid cleaner, whether it be water or a chemical cleaner, will drip down the screen and work its way into the interior of the TV, causing damage to your HDTV. You will be able to easily recognize when this happens, because your screen will develop smudges.
Step4
Use a cloth to clean the HDTV screen. Ideally, you should use a cloth that is recommended for HDTV screens, computer screens and other electronics. The word "microfiber" may be imprinted on the packaging.
Step5
Wet the microfiber cloth slightly. Just a hint of dampness is all you need. If water runs out of the cloth, then it's too wet and will cause smudges.
Step6
Develop a regular cleaning schedule for your HDTV screen. If you dust the screen daily, or at least several times a week, with your microfiber cloth, no other maintenance should be necessary. Not only will frequent cleanings make caring for your HDTV easier, but they will also enhance your viewing experience.
Step7
Prevent messes by asking family members and guests not to touch the television screen. You should also try to make sure children with sticky fingers do not come in contact with the screen.
Step8
Use a high-end cleaning product if you feel that regular dusting is not sufficient. Top-of-the-line television cleaning products are ideal for use on all HDTV screens, plasma screens, projectors and are safe to use around children and animals.
Aug 11, 2009 | Panasonic TH-42XVS30U 42 in. Plasma HDTV
Cleaning
Buy an cleaning kit with cleaning solution, and clean the display very carefully. If you apply too muck pressure you can damage the LCD display.
See also:
How to Properly Clean your LCD Screen
How to Clean an LCD Screen
How To Clean A Flat Screen Monitor
Dec 28, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Stains on the LCD monitor of Permanent marker
you could try mean green or totally awesome gotta love dollar tree. but be careful if you press too hard you could crack the screen or cause a pooling effect that may or may not go away. Oh or rubbing alc. last resort use liquid lighter fluid on a cloth.
May 22, 2008 | ViewSonic VA720 17" LCD Flat Panel Monitor
Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV Logo
123 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
