Question about Garmin nuvi 350 GPS Receiver
Having problems acquiring satellites
Im having problems acquiring satellites ive tryed holding the bars on the top left hand corner and it brings up a gps page .any ideas??
  • 4 more comments
  • Anonymous Mar 29, 2008
    The unit won't go into the mainenance mode when I press down on the lower left part of the screen while holding the power button down.
  • dmerc62 Apr 03, 2008
    My Nuvi 350 is not aquiring the satelites either I have done the hard reset and I have gone into the maintenance and it says that there are no error reports but yet I still can't get a signal lock does anyone have anymore suggestions?
  • Mike 2x Apr 27, 2008
    Half way through a trip my Nuvi 360 gave the notice "trouble aquiring satellites. This was two days ago. It happens in my car and outside on the lawn. I tried the one recommendation of clearing all error reports and that didn't work. I'm desparate enough to try freezing it, as one responder suggested.
  • sherri1008 Oct 19, 2008
    no brand of gps will get a signal in my isuzu rodeo. the only time one will acquire is when the positive battery cable is disconnected. we have had it looked at by five gps dealers and a mechanic............can anyone help? i need gps and cant get rid of my truck. ps there are no bells or whistles in my truck.
  • SHARCNET-USA
    SHARCNET-USA May 11, 2010
    Please do NOT put your Nuvi in the freezer! The LIQUID display WILL freeze and possibly crack, damaging the display and costing you more $$ at the repair shop. This satellite reception problem is caused by a defective part on the GPS receiver board. Please see this link to learn more about this problem and learn how to get it repaired.
    http://www.sharc.net/gps_antenna_repair....
    - Jim
  • SHARCNET-USA
    Please see this link for more information about this issue and a resolution.
    - Jim
  • 4 Answers
I experienced the same problem about acquiring satellite signal even when it's a clear sunny day. After 30 mintues, it was still searching! The unit appeared to have "stuck" in this acquiring mode. The following worked for me: 1) open the GPS antenna 2) press the bottom left screen while holding the power button to turn the unit on 3) enter maintenace mode 4) select diagnostics 5) clear error report, do NOT clear any user data 6) restart unit the usual way My GPS 350 was able to acquire satellite signal in less than 1 minute after the above steps were taken.
Posted on Oct 03, 2007
    Problem Solver:
  • 7 Answers
I own & operate the electronics repair company, Westek Electronics in Nashville, TN. We repair & refurbish GPS units among other things. We have repaired many nuvi 350/360 units with this issue.
This issue is typically due to a hardware malfunction and cannot be remedied by software upgrades, resetting, etc.
Do this test:
  1. Strip a ¼” of a wire twist-tie end (the kind found on bread wrappers) bare exposing the fine wire core.
  2. Power up your nuvi 350/360 and confirm that you are not receiving any signal.
  3. While still powered on, insert the bare end of the twist-tie into the center female external antenna jack located on the side of the antenna. If done correctly the external antenna jack will firmly hold the twist-tie in place. You cannot damage the unit by doing this.
  4. If you now have satellite reception then proceed to step 5. If you still do not have any reception then I have no further advice other than to try all of the update/reset procedures. If all else fails return to Garmin for repair.
  5. Once you have established that you have signal using the twist-tie, remove the twist-tie and confirm signal loss.
Your choices to remedy this issue is as follows:
  1. Purchase & use an external antenna.
  2. Return the GPS to Garmin for repair ($175 if its out-of-warranty). Or,
  3. Send your Garmin Nuvi 350/360 to us for repair. We charge $55 (return shipping included) to repair this malfunction. We can also accommodate this repair transaction via eBay in order to provide you with additional reassurance (an addition $5 is added to cover eBay fees, etc. when using this option). Our eBay ID is westek_electronics, feel free to review our feedback ratings. To initiate your repair contact us at westek12@hotmail.com.
Hope this helps.
Posted on Mar 05, 2009
  • Garmin Master
  • 2,130 Answers
This problem is not caused by poor solder joints. It's caused by a defective part. We sent a "marked" defective unit to the repair shop mentioned above and upon its return, disamantled the GPS receiverhaving problems acquiring satellites - 2_bing.gif assembly and made the following evaluation:
1. The shop did NOT replace the defective component causing the initial problem in the 1st place. The defective part was STILL in the circuit.
2. The shop placed a wire jumper between the internal antenna and the external antenna port. This type of modification places a +2.5VDC bias on the internal antenna and essentially shorts the internal antenna to the external antenna (when connected), giving unpredictable results. It also affects the circuit impedance and signal strength. This is not the correct way to resolve this issue.
3. The defective part needs to be replaced with a higher rated part. This type of repair returns the unit to full functionality and allows the unit to properly switch between the internal and external antenna as it was intended to do by design
- Jim
SHARCNET-USA
Comments: I will aso add, as the part deteriorates, it becomes resistive and can eventually short out and shunt the incoming RF signal to ground......EVEN with the jumper procedure performed by the shop mentioned above.
- Jim
SHARCNET-USA
Posted on Feb 17, 2010
I found this on Garmin's FAQs. If the GPS is having issues acquiring satellites on the dash of the vehicle, the problem most likely is due to the coating that the manufacturer applied to the windshield. Some cars are equipped with special windshields that may contain metal in the glass (metal oxide) that prevents the gps from having a clear line of site to the satellites. Windshields with solar ray glass, solar tint, heated or heat reflective windshields, and insulated or Insta-Clear glass may also affect satellite acquisition. If the car has one of these windshields, an external antenna might be required to receive satellite signals. If unsure about whether the vehicle has one these mentioned features, contact the dealer. The other thing you can try is to close and reopen the antenna. Sometimes that wakes up the unit, especially if it was turned on when out of satellite site.
Posted on Aug 31, 2007
We have a Nuvi 350, In a convertible car and open the GPS antenna and turned it on, we even tried the rest button? Still no satellite reception, keeps asking if we moved 100 miles or more, or if we are in a building, both answers are NO.
Posted on Sep 20, 2007
Many people who have the Garmin c330 Street Pilot, and probably on other Garmin Navigators as well, have experienced the satellite problem AFTER they have replaced the battery, which is very easy to do. The reason for satellite acquisition failure is I believe, is that the programming for satellite acquisition is a "volatile memory" so when the old battery is disconnected to install the new battery, the satellite acquisition memory is lost. It can be reprogrammed only at Garmin;s Olathe, Kansas facility and the charge in December 2009 is $79. To preclude this happening, you must not disconnect the old battery until you have connected the new battery. Don't worry, you can have both batteries connected and the voltage will not increase as long as you have the positive and negatives to the correct terminal. Once the new battery is soldered in, then take a tiny pair of clippers and clip the wires of the new battery and remove it. Using that procedure, there is never a voltage loss so the volatile memory is retained. If you have further questions, email me at wayne dot tippin at cox dot net.
Posted on Dec 10, 2009
I know it sounds silly but sometimes when my Nuvi 350 does this, an hour or two in the freezer does the trick.
Posted on Apr 26, 2008
Garmin 1450Lmt is not able to connect satellite
if you are not getting any bars in the top left corner of the screen, turn the device off and press and hold in the lower right hand corner of the screen, while holding the lower corner turn the device on, when you see the screen start to turn on let go of the power button and continue holding the lower right. it should ask you if you want to erase all user date and then you will select yes. be advised this will also erase any saved waypoints/favorites you have.
Sep 05, 2011 | Garmin nuvi 1450 GPS Receiver
Garmin GPS GSMAP 182C Chartplotter will not boot up
If the unit doesn't go further from the reading card. this may indicate that theres a problem in the memory card.
Not being able to a get a signal lock on satellites would indicate a problem either in the software something is wrong or not geting loaded correctly (the memory card) Or a hardware problem.
You may have to take it in for service if you are unable to check the memory card or replace it.
Jun 27, 2008 | Garmin eTrex GPS Receiver
Hi, Just opened a new 1490LMT. Can't get a satelite signal. Small red bar appears on left top corner. Also, I'm in Winnipeg and can't get the GPS to acknowledge Winnipeg. Toronto is on screen.
When travelling with your GPS it may take 20-30 minutes for it to acquire a satellite signal. For it to acquire the signal it should be stationary so when visiting the family or in the hotel leave it on you should get satellite lock.
Hope this helps!
Mar 10, 2011 | Garmin nuvi 1490T GPS Receiver
Trying to reset my garmin nuvi 350 but per-boot mode is keeps coming up. i hold down the left corner and hold the power button i don't understand why i can't reset it. HELP im going nuts
(G-Brand): Place your finger over the lower left-hand corner of the screen (upper left-hand corner for a 6xx series) and hold it there while pressing the on/off power button. Keep holding your finger there and a window should pop up asking if you want to go into maintenance mode. Select yes. There is an option called "clear user data". Select that option. It will not erase your favorites. It will however, erase any corrupted satellite data and will default you back to some factory settings and to a location of the manufacturer's headquarters in Kansas. This will also force your GPS to collect new satellite data. Your GPS should reboot and it will ask you a couple questions like, timezone, language. Please select the proper settings.
- Jim
SHARCNET-USA
Dec 10, 2009 | Garmin Nuvi 350 Car GPS Receiver
- Jim
SHARCNET-USA
Dec 10, 2009 | Garmin nuvi 200W GPS
Garmin Edge 305 won't acquire satellite signals
If the option of working without GPS receiver enabled is turned off, then it may be a real damage.
Only thing is to check this option.
Jun 20, 2009 | Garmin Edge 305 GPS Receiver
Not acquiring satelites
I've never had this problem but I have heard of a possible solution. On the Option screen where it shows Where to? and View map, press on the satellite bars on the top left corner and hold until you get the GPS screen, leave it for around 10 secs then back up. I hope this helps!
Dec 30, 2008 | Garmin nuvi 200W GPS Receiver
Nuvi 360 cannot acquire sattelite
There are a few things you can try to restore satellite reception.
1. place your finger over the lower left-hand corner of the screen and hold it there
while pressing the on/off power button. Keep holding your finger there and a window should pop up asking if you want to go into maintenance mode. Select yes. There is an option called "clear user data". Select that option. It will not erase your favorites. It will however, erase any corrupted satellite data and will default you back to some factory settings. This will clear some of the memory allowing your Nuvi to collect new satellite data. Your Nuvi should reboot and it will ask you a couple questions like, timezone, language. Please select the proper settings.
Make sure the antenna is up and that you are outside. On the main screen, you will see a satellite bar graph in the upper left-hand corner. Touch the bar graph and you should get a satellite map, showing the satellites. If your Nuvi's receiver is working ok, you should see horizontal hollow bar graphs appear on the right. Eventually they will turn solid blue. This indicates they have downloaded the proper data from the satellite. When you have (4) solid blue horizontal bars (4 satellites), you will see the top panel begin to show improved accuracy and your Nuvi will then work as it should. This entire process make take 30 minutes or less.
If you don't see any bar graphs, your Nuvi may ask you severl minutes later, if you are indoors. If your outside, select no. It will then ask you if you have moved 1000 miles since your last use. Select yes. This will cause your Nuvi to start looking for
satellites, trying to locate your new position.
Now, if you still don't see any bar graphs, then your antenna may have a problem. There is a known issue with the Nuvi antenna where a part has failed, causing the Nuvi to no longer use its internal antenna and it's now always looking for an antenna at the external antenna port (the gold connector on the side of the Nuvi antenna). If you have a piece of small wire, a couple feet long, you can insert that into the center lead of the external antenna jack. Most likely, you'll begin to see bar graphs after a few minutes and your Nuvi will lock.
I haven't been able to identify yet, which part has failed. I am working on that.
However, if the piece of wire works, you can always go on eBay or a retail store and
purchase an external antenna for your Nuvi. They are magnetic and can either stick to your roof or any metal surface within your vehicle.
Here's another way to determine if your antenna has failed and will have to be replaced:
At the main menu, pres on the "wrench" symbol. Then press the "gear" symbol and then press "about". There is a field marked "GPS S/W". There should be a number next to it. It may be "2.9" or "3.0". That is good. That tells you that the main board in the GPS is communcating with the antenna receiver. If you see "0.0" then your antenna is defective and there's no way to repair it other than replace it.
Please let me know if I can be of further assistance to you.
- Jim
Oct 03, 2008 | Garmin nuvi 350 GPS Receiver
Gpsmap 60c can not acquire satellites even when left outside for 15 minutes in a place where it usually has no problem. Problem happened overnight.
Are there any there any satellites listed on the satellite overview page?
What is the GPS SW Version listed by the unit?
0.00?
Mar 12, 2008 | Garmin GPSMAP 60CS GPS Receiver
I cannot acquire satellites signal. What to do ?
Jul 21, 2007 | Garmin nuvi 350 GPS Receiver
Garmin nuvi 350 GPS Receiver Logo
9,228 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
