Question about Canon PIXMA iP3000 InkJet Photo Printer
I have a canon pixma ip 3000 and i need to empty inktank can u help
    Problem Solver:
  • 13 Answers
Ther is no ink tank it is a counter pre set by canon who decided you can only print so many pages . it is artificial number.
reset your machine by the following should help
read all first
First thing you need to do is print an EEPROM information page, step number 2 below.
Once you have an EEPROM print you can reset the waste ink counter, if needed, which is step number 4 below.
Service Mode: This printer has a service mode for service-related settings and for performing test prints. The operator panel buttons are used to enter the desired service mode.
Service Mode Operations
With the printer powered off, hold down the "Resume Button" and press the "Power Button".
While holding down the "Power Button", release the Resume Button" and press the "Resume Button" twice in succession. Now release the "Power Button".
The indicator will blink in green and remain lit in green.
Select one of the following service mode functions by pressing the “Resume Button” the specified number of times.
1 time = Service test print.
2 times = EEPROM information print.
3 times = EEPROM initialization
4 times = Waste ink counter resetting
5 times = Destination settings
6 times = Print head deep cleaning
Then press the “Power Button” one time to perform selected function.
If you press the "Power Button" two times it will take you out of service mode.
This information is listed above in this thread and many times in other Canon threads in this forum. I simplified Canons wording so I could remember the service mode functions easier.
to fix also :
PIXMA IP 3000 service error 5100
I got service error 5100 after a paper jam sometimes 5 times blinking orange. in my PIXMA IP 3000
to fix it
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
or: and Also;
Unplug unit, hold power and reset button down
THEN plug it in while still holding both buttons down;
Then to step 3 above.
Posted on Feb 21, 2009
A window displays inktank full and the printing is cancelled, when i give the print command ? what sould i do? when showed to an expert ,he told i need to update the firmware. Is this the solution ,if yes...
I suggest a window display "Waste Ink Absorber Full" or "Ink Tank Absorber Full" . It has to be reset.
4 step to Reset waste ink tank counter CANON PIXMA iP 1000
STEP 1:- Disconnect printer from AC power
STEP 2:- Press and HOLD the POWER button, and connect printer to AC power
STEP 3:- release the the POWER button
STEP 4:- Press the POWER button again
If that not work just write on kernel84@abv.bg , and i send you a software to reset your printer.
Jan 18, 2011 | Canon PIXMA iP1000
How do i change or clean the inktank on a canon ip 4300
Canon support has the following tutorial: (copy and paste the following link into your browser)
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=257&modelid=13528
Enter question: "How do I replace or insert an ink tank" > Click "Search" button > View tutorial.
Dec 04, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
Canon pixma ip 3000 error message printer is offline
If the orange lamp blinking only it's the print head is not installed, or it is not properly installed.Open the cover remove the print cartridges then remove the print head and put back it on.If not help the print head is defective and need replace.
If the orange lamp blinking with green alternately it's ASF (cam) sensor error.The problem is in sheet feed unit.
Oct 15, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
I can't install my printer
You can download the driver at this link
http://www.download.com/Canon-IJ-Printer-Driver-Canon-iP1600/3000-2116_4-10555904.html
Jan 10, 2009 | Canon PIXMA iP1600 Printer
Canon PIXMA iP 3000: Suddenly, everything prints hot pink
It sounds like the cyan and yellow cartridges are empty. Try new cartridges.
Dec 09, 2008 | Office Equipment & Supplies
Lost my set up disc for my Canon ip 3000 printer
Sir,
Click this link to get ur software / driver
Thanks
good luck
Nov 26, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Color Inktank
May be time to replace the print heads as a new unit is quite pricey. Refurbished from canon is about $150.00, print heads are about $50.00
link
Apr 05, 2008 | Canon PIXMA iP90 InkJet Printer
Pixma Canon printer 1000
have u switched the printer ON? plz do and the the ink tanks will come in the middle.
Dec 20, 2007 | Canon PIXMA iP4000 InkJet Photo Printer
Canon ip4200 colour magenta
the colors transfer to the printhead by gravity. the felt on the inktank must make intimate contact with the stainless steel filter in the printhead. I have a pixma ip 6000D that I had to replace the printhead inside of two years three times. the bubblejet circuitry in the printhead got burned out. New heads cost from $55 to over a hundred.
Sep 10, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Canon PIXMA iP3000 InkJet Photo Printer Logo
353 people viewed this question
old marine
old marine
