Question about Gateway MT6451 Notebook
New laptop lcd display not working
I just bought a Gateway MT6451 with a broken lcd. Ordered a new one, installed it and nothing. So I put the old one back in and that works. So I decide to test the inverter and backlight, both work. I then unlug the broken display backlight but leave the video cable hooked to the bad display, hook the new display's backlight to the inverter. power up... backlight works...so while the laptop is on I unplug the broken lcd video cable and plug it into the new one...it worked. But only till I reboot. I did it like 6 time and it worked that way each time. Oh and the vga and svideo ports work also. Anyone know why its not turning my new lcd on?
  • arj1231 Feb 18, 2009
    I tried the function keys no video at all, no image on screen. I even did the flashlight thing.
    As far a s the model numbers they are suppose to be compatible. both are LTN154X3, but my original read LTN154X3-L03 and the new one is LTN154X3-L0D. I cant figure it out so I ordered a new screen again, but this time I ordered the same serial#, just to be on the safe side. I'll keep trying till my new one arrives. thanks
  • Chris Hingee
    Chris Hingee May 11, 2010
    Boy have you got a strange one.
    Have you tried using the function key that switches between the LCD and the video output?
    Do you see a slight video image on the new LCD when you boot up (ie the backlight didn't switch on)?
    Welcome Back:
    Visited the website for 2 consecutive days.
Check all usb connections i just fixed a emachine that seemed to boot up but no display would show lcd or ext. so i got to looking and one off the usb ports was broke and bent downt into the opening and shorting out when i removed it and turned back on it started booting up as normal
Posted on Apr 01, 2011
    Scholar:
  • 53 Answers
Check the panel to make sure the panels are the same model number there are more then one part number for gateway lcds for your model and if your laptop uses the xga screen and your not replacing with the correct panel then you will get the problem you are seeing now.even thought the inverter and back light are the same the panel are very differant.
Posted on Feb 18, 2009
Broken screen glass
Sounds like a motherboard fault, Faraz. There is no solution to that, you either replace the mobo or buy a new laptop.
Sep 09, 2013 | Gateway Computers & Internet
My Gateway NV52 will not display anything on the screen. it stays black. The notebook powers up, but nothing is shown on the screen. How can i fix this?
First :
Try connect your laptop to other monitor ( crt or lcd ) if it looks normal on the monitor, it means your LCD laptop is broken.
Somestime often open-closed this LCD Laptop, may broken your Flexy data kabel of your LCD laptop.
Anyway Thx
Jun 23, 2011 | Gateway NV5215u Notebook
Problem loading OS on Gateway MT6451, Main File Error
This looks like a corrupted file in the boot section or a virus attack. the only solution is to reinstall the OS. there is no hardware error, if you had any hardware error the display will not be working fine. reinstall the Windows OS.
Please encourage us if this tip was helpful to you.
Apr 02, 2010 | Gateway MT6451 Notebook
Gateway laptop will not charge battery.
I have a new gateway laptop with windows 7 and today it said plugged in not charging 8%. I tried everything and nothing worked so I turned it off and unplugged it and took the battery out and put it back in and it started charging...hopefully this works.
Jan 09, 2010 | Gateway M675 Notebook
How do I take apart my gateway mt6451 laptop to replace the dc jack
Here's a direct link to this laptop's service guide:
http://support.gateway.com/s/Mobile/Q106/Oasis/8511725_Service.pdf
You can make use of this document to take apart your laptop.
Dec 20, 2009 | Gateway MT6451 Notebook
Hi i have a gateway mt6451 and i can not get it to charge
i am having the same problem with my gateway MT6451. I bought a new battery charger but it still does not work.
Nov 20, 2009 | Gateway M350S Notebook
The monitor just goes out. It displays vertical
vertical lines can mean either a connector problem on the lcd itself or on the motherboard connector or a problem with video ram or the chip. Unfortunately none of those are cheap or easy to fix. You can try an external monitor and if that displays normally then the problem is connector or lcd. You can sometimes find a replacement display at fair prices so if that is it then it might be worth fixing. If it is the motherboard then the repair can cost as much as a new replacement laptop.
Sep 25, 2009 | Gateway MT6451 Notebook
MT6451 Display will not work.
Hello
It sounds like your AC cord or the female plugin soldered onto the motherboard has gone bad and will no longer make a connection to charge the battery or power the laptop on.
You would have to try a new power cord to find out which is the problem. If the cord fixes it, then it was just a bad cord (as you said it gets very hot, this maybe a sign of a cheap cord that has gone defective).
If the cord is not to blame, then the female plugin is loose and there is little you can do unless your an expert at soldering.
Post back with anymore questions or comments for additional help. Thank you for choosing Fixya!
Jun 23, 2009 | Gateway M305CRV Notebook
No powerup
Unfortunately, you can't solve this problem. What I have learned as the tech working on a customers gateway mt6451 is that Gateway dropped the ball when they bought a cheap (they spent 5 cents instead of 20 cents) motherboard component that allows the adapter to charge battery and run the notebook without the battery installed, the component seems to have a 1 year if that life. I am surprised they haven't been sued or forced to extend the warranty (like HP had to with their dv8000 series notebooks) althought they would have to replace the motherboard with one that has an improved component on it. How do you sue a company or force them to extend the warranty for a replacement that is made with a better component?
Dec 11, 2008 | Gateway MT6451 Notebook
LCD Replacement
Did the connector from the replacement LCD inverter fit in the socket of the motherboard? When you were replacing the LCD, did you have the battery out of the unit? And finally, have you attempted to start the laptop with the power cord in, but the battery out? I'm not familiar with the mx6931, but can you press the power on button without the trim piece that sits above the keyboard?
Sep 15, 2007 | ASUS F3F Notebook
Gateway MT6451 Notebook Logo
560 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
