The Samsung Karaoke PCD-740 is a karaoke system that allows you to play karaoke music on your TV or home theater system. The user manual for this device can be found on the Samsung's website. You can visit the website, navigate to support section and search for the model number "PCD-740" and select the manual.
You can also find the user manual in the CD that came with the device. The manual will provide you with information on how to set up and use your Samsung Karaoke PCD-740, including details on connecting the device to your TV or home theater system, using the remote control, and adjusting the sound settings.
It will also contain information on how to play karaoke CDs, how to use the various features such as key control, echo and delay effect and how to connect external devices such as microphone and other music players.
Please note that the manual may vary depending on the region and the date of purchase, so it's best to check the version number of the manual and download the latest one.
How do I reset my player to factory settings? ... How to make a karaoke songbook file from an external hard drive on a 203G USB After preparing the external ...
Reset the players to factory defaults. *Defaults will ... Why don't I ... Why will my new [model] karaoke player not play SuperCD+G discs? SuperCD+G discs play ...
Supersonic SDAT SC-25 DVD/Karaoke Player Factory reset ...
www.fixya.com > ... > Supersonic SDAT SC-25 DVD/Karaoke Player
Supersonic SDAT SC-25 DVD/Karaoke Player, factory reset button related issues. ......reset my pioneer dv 490v to factory setting here is the link to your manual: ...
If you are experiencing no sound from your Emerson Karaoke machine, here are some steps you can try to troubleshoot the issue:
Check the connections: Ensure that all cables connecting the karaoke machine to the speakers and other audio equipment are securely plugged in and not loose. Also, check the volume levels on the karaoke machine and any connected devices to ensure they are not set to mute or very low levels.
Check the microphone: If you are using a microphone, check to ensure that it is plugged in correctly, and the volume levels are set correctly. Try using a different microphone if available to rule out the possibility of a faulty mic.
Check the speakers: If you are not hearing sound from the speakers, ensure that they are powered on, and the volume levels are set correctly. Try connecting a different set of speakers or headphones to the karaoke machine to see if you can hear sound through them.
Check the karaoke disc: Ensure that the karaoke disc you are using is not scratched or damaged, which may cause issues with the sound. Try using a different karaoke disc to see if the issue persists.
Reset the karaoke machine: Try resetting the karaoke machine to its default settings, which may resolve any issues with the system's software. Refer to the user manual for instructions on how to reset the device.
If none of these steps resolves the issue, it may indicate a hardware problem with the karaoke machine, and it is recommended to seek assistance from a professional technician or the manufacturer's customer support team.
If your player has these functions and your user manual doenst have the instructions its maybe cause your model doesnt support it. you may need to contact the manufacturer for details regarding this.
I cant be certin as I dont own that particular model nor do i have experience with that model. If you have a microphone jack then the chances are it supports it.
In most players with this feature there is a karaoke setting and a button on the remote to access it. in some players you will need to access it through the menu button on the remote or karaoke button. Its different in all players.
Hi, got this info from philips customer service. Was desperately trying to get the karaoke function to work for 2 weeks! Plug in your microphone. Press "KARAOKE" button until you see "MIC OFF" text, and immediately press RIGHT button. It will now shows "MIC ON"! "ECHO", "KEY" options will now shows up when pressing "KARAOKE" button repeatedly. However, microphone sound will not be available on digital output, you'll have to use the audio RCA. Happy singing!
your tv had no problem, use the remote of your karaoke machine and press the system. your karaoke machine was set on PAL change it to NTEC or press N/P
