Question about Profile BAJA HA700M Car Audio Amplifier
Amp is shutting off after 10 min of driving!! please help!!
Alright, so i recently installed a Profile HA700M Mono subwoofer amplifier 350 watts RMS x 1 at 2 ohms and a 2 ohm Kicker TCVT102 Sealed truck enclosure with one 10'' CompVT subwoofer. For the first few days everything worked fine, but now im getting no sound out of the sub after about 10 minutes of driving. If i shut my truck off for a few minutes and start it back up, the sub will work again, and then do the same thing. I checked the voltage and i got a reading of 12.75, which i was told was ok. Im also running a much smaller amp to power 2 infinity kappa 63.7i speakers. I have the rca's going from my head unit to the sub amp, then from that amps line out to the speaker amp. The speakers never stop putting out sound... so it cant be a problem with the rca cables i think. The protect light never comes on, and the power light always stays on. I checked and rechecked all my connections, and they all seem fine. I have the sub amp grounded to the passenger side seat bolt, and i did sand away the paint. Before i installed the sub, i had the speaker amp grounded to the same spot and never had any problems. I now have the speaker amp under the drivers side seat, and the sub amp under the passenger seat. This is all installed in a 94 toyota pickup 4 cyl with the 22re engine. Hope thats enough info, if anyone needs more let me know. Thanks. Richie.
  • rraithel Feb 18, 2009
    i thought i should also add that the gain and the bass boost are set at or under 1/2 of the max.
    yes, it happens at all volume levels, and ill check the remote turn on after the problem occurs... i just kinda didnt consider that to be a possible problem since the other amp stays on fine, and the power light on the sub amp is always on. i should also mention that the remote turn on is split to run to both amps. i just bought this amp so im just gonna have to return it i think... thank you.
  • 15,935 Answers
Does it happen at all volume levels?
What is the gain setting on the sub amp?
Have you checked for 12V @ remote turn on after problem occurs?
Sounds as if the remote turn on relay inside the amplifier is losing signal, or has become damaged. If the protection light does not light up, the problem is not thermal, shorting, or high/low voltage.
The amplifier is in need of repair. This is not an end-user fix. Looking at about $50 to repair.
Thanks for using FixYa- a FixYa rating is appreciated!!
Posted on Feb 18, 2009
  • blueextc3221
    blueextc3221 Feb 18, 2009
    some amplifiers must get 8V or more turn-on signal.
    With multiple amplifiers, the remote turn-on should be run from a spdt relay bank so all amplifiers will see the full 12V instead of sharing.
    Good idea to return if under warranty.
What car amp should I get to power my 2 pioneer ts-sw3002s4 sub's. They are 12 shallow mounts 4 ohms each with 400rms each.
Rockford Fosgate R1200-1D Mono subwoofer amplifier - 800 watts RMS x1 at 2 ohm, 1,200 watts RMS x 1 at 1 ohm
Mar 26, 2015 | Pioneer Car Audio & Video
Two questions. 1) can my amplifier over-power this sub; kicker L7 15 inch dual voice coil 1,000 watts RMS wired for 2 ohms? 2) is my amp too small for this sub-woofer? thank you for your time.
No, your not over powering your L7, your underpowering your subwoofer.
Your Kenwood is
500W x 1 at 4ohms [20-200kHz 0.5% THD]
900W x 1 at 2ohms [100Hz 1.1% THD]
Your L7 is:
Max Rec Amplifier Power (WATTS PEAK/RMS)* 2000/1000But its ok for your subwoofer, alteast your not giving it to much stress. But personaly, get another mono amplifier that would match your subwoofers rating.
Apr 08, 2011 | Kenwood KAC-9103D Car Audio Amplifier
If i have a 4 channel 2000 watt amp, can i use 1600 watt wires if i only have 2 subs hooked up to it?
Yes, you will be fine. 4 gauge power wire is sufficient for a couple of reasons, the primary one being that most of the companies that are boasting 2000 watts for a 4 channel amp are off brand "web-retail only" companies, and they severely over rate the power output of their amplifiers. Secondly the supposed 2000 watts is peak power and not rms power. Peak power means how much power that amp can put out during absolue climax of the music or during a tone burst. RMS power is how much that amp will put out continously to your speakers or in this case, your subs. If you look at the spec sheet of that amp, in all actuallity you're probably only getting 200-300 watts rms even bridged.
On a side note, if you really want to push your subs hard, you might want to consider getting a mono block or "class d" amplifier and use that 4 channel amp to push your surround speakers. Class d/mono block amps are specifically designed to push subwoofers and will give you the most efficient power out and the best heat dissipation to withstand the output required to drive subwoofers. You'll get better bass and also more adjustability to tweak the sound levels coming out of your subs. Hope that helps.
Apr 02, 2011 | Car Audio & Video
Amplifier For Powering Sony Xplod xs-l121p5
Pump the brakes!
You need to know the RMS power rating of the sub you are powering.
Dont exceed the RMS power rating of the sub by more than 25%.
If you see a peak power rating on either the sub or the amp, ignor it, means nothing. Always compare RMS ratings.
Example: a Sony 12" Xplod sub, boasting 1200 watts, will only handle, 350 watts RMS, so the amp you choose to power the sub should be 350 watts RMS as well, and should not exceed more than 25% of the RMS power handling (487.5 watts).
Bottom line, know your RMS numbers, not Peak.
Dec 06, 2009 | Sony Car Audio & Video
Infinity 1211a @ 2 Ohms
Hello monkey_flea, Your subs will share the amp output. And if you are not careful, you'll end up blowing them. The amp puts out 1300 watts RMS at 2ohms, the subs have an RMS power range of from 75-350 watts, and you'll be driving them with 650 watts each. A better power match would be to series the subs to present an 8ohm final load. This will reduce the output power to a level the subs can handle. Or you could buy 2 more 12.1's and connect them series-parallel for a 4ohm load and each sub would still be getting 325 watts RMS, just about the maximum they are rated to handle. Hope this helps.
Jun 03, 2009 | Infinity Reference 1211a Car Audio...
Installing two amps
No, thats what you don't what to do. Even if you have 2 matching amps you don't do that. Every amp puts out different, and for 2 subs, you want to play at the the same time. If your only running 2 10's, I personal would just run the alpine (it's a mono amp made especially for subs) thats plenty for what you have. make sure you bridge them to get the full response. And your other amp i would use for your highs or mids, but run it @ stereo , which is 300 w @ 4 ohms. (Note: 600w @ 2ohms would be bridged and would play in Mono)
Building Competition stereo's is a big hobby of mine.
May 04, 2009 | Alpine MRD-M605 - V12 MONO AMP 600WX1 RMS...
My sub flickers on and off in my truck!!!
could be a number of things loose wires bad ground fuse on its way out or internal problems
Feb 13, 2009 | Profile BAJA HA700M Car Audio Amplifier
Trying to figure out what kind of amp i got amercian pro vs-3507?
The VS3507 Is a class D monoblock.
Your optimum wiring for this amplifier is a 2 Ohm load - so it produces its full potential power of 350W RMS.
To Achieve a 2 ohm load, the most common load is one of the following...
(1) Dual 4 Ohm Voicecoil Subwoofer Wired in Parallel.
(2) 4 Ohm Voicecoil Subwoofers wired in Parallel.
(1) Quad 2 Ohm Voicecoil Subwoofer wired in Parallel/Series.
(1) Single 2 Ohm voicecoil subwoofer.
American Pro VS3507 2000W Car Audio Monoblock Amplifier
American Pro VS3507 Monoblock Amplifier Details
  • Built-In Crossover
  • Variable High/Low Pass Filters
  • Phase Shift Control
  • Subsonic Filter
  • Bass Boost Control
  • Dancing Lights at the Rhythm of Music
  • Protection Circuits
  • Gold Plated Terminals
  • Power & Protection Circuit LED
  • 1 x 250 Watts RMS @ 4 Ohms
  • 1 x 350 Watts RMS @ 2 Ohms Thanks for using FixYa - A FixYa rating is appreciated!!
Jan 29, 2009 | American Pro Car Audio & Video
This will depend on the amplifiers capabilities.
I will give 2 different scenarios.
#1 Stereo configuration
If the amplifier supports an RMS power output close to the RMS input power of the subwoofers then run the amplifier in stereo mode. For example 150 watts RMS X 4 channels driven at 20-20khz. (If you can provide a model # for the subs and the amp your looking at I can help you further with this decision.
Wiring for this is easy and simply involves matching the connectors for 2 of the channels (Front or Rear) to each of the subwoofers.
#2 Mono Bridged mode.
If the amplifier is lower power but mono bridgable you can bridge two Pairs of channels and power each of the subwoofers this way.
Generally speaking a 2 channel bridgable amplifier will be able to at least combine the wattage of each channel into a single monural channel and in many cases its actually higher.
So you would bridge the front 2 channels into a single bridged mode for one subwoofer. and then you could bridge the read 2 channels into another bridged mono channel for your other sub woofer.
For example if you had bridgable amplifier thats 50 watts RMS X 4 you coudl very likely (Generalization based on quality of amplifier) send 150 watts RMS to each subwoofer.
Again I would need to know what amp you're refering to to provide specific wiring instructions. Many Bridging amplifiers either have a single switch that will send them to bridged mode or you would use the positive + terminal from one channel and the negative - terminal from the other channel or a combination of both.
Sep 17, 2008 | Kenwood 12" 4-Ohm Single-Voice-Coil...
Profile BAJA HA700M Car Audio Amplifier Logo
193 people viewed this question
Top Profile Car Audio & Video Experts
xxxxxx xxx
Are you a Profile Car Audio and Video Expert? Answer questions, earn points and help others
