Hello, I had to replace the radio in my caravan due to the prior owner having 8 pennies inside of it burned out the boards and made a couple of the pennies black and straight burnt. I went out and found a kenwood for 50 bucks and went to throw it in to find I had to soder wires onto the old wires to make it work, it did have 2 batt wires which I didn't understand why so I sodered 1 and set the other aside along with a couple others I didn't need I left in the old radio adapter. I then went to plug in the antenna after I checked if it worked and the antenna plug was too large. Went back to the store and bought a antenna multi-adapter, had no dodge one on the 5 choices but the chrysler fit so we used that. However the problem I am having is the radio keeps sounding like it is losing reception and soun d will go down and up constantly and at times give me static. I am thinking perhaps I need to find a dodge adapter but I do not know for sure. If anyone can help me that would be greatly appreciated.
SOURCE: Radio/CD player Wiring
Here are the correct factory radio wire colors with definitions.
Car Radio Battery Constant 12v+ Wire: Blue/Yellow
Car Radio Accessory Switched 12v+ Wire: Gray
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: Green
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: Black/Red
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 6 1/2′
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Purple
Right Front Speaker Positive Wire (+): Green
Right Front Speaker Negative Wire (-): Blue
Car Audio Rear Speakers Size: 6 1/2′
Car Audio Rear Speakers Location: Side Panels
Left Rear Speaker Positive Wire (+): Black
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): White
SOURCE: needing wiring diagram for 1991 dodge dynasty le
here is what I found:
http://www.the12volt.com/installbay/stereodetail/715.html
SOURCE: Radio Working But I am not getting any stations
this is an antenna problem, if u have a power antenna it is very likely that u need a new one.
SOURCE: Left side speakers front & rear do not work. Right side works.
Hi there check out my website we have radio diagrams for your vehicle goto http://valueshop.noads.biz/contents/en-us/d180.html and select you model. hope this helps
