Question about kawasaki Full Suspension Mountain Bike Men
Try to kick start my kx 250 and it wont turn over it only back fires what can it be
How yo fix a new kick start to my kx 250
Posted on Apr 02, 2010
Rm 250 wont start off kick
Don't know if it is water cooled or not, but it sounds like you may have a problem with oil or water getting into the combustion chamber and fouling the spark plugs. Kicking doesn't produce the amount of rpm that you need to fire up a weakly firing plug. I'd check the plugs condition first and replace if needed, and then figure out why its smoking.
May 02, 2012 | Suzuki Motorcycles
How do i change kickstarter spring on 2000 kx 250 motorcycle
Just remove the right side cover to expose the kick start mechanism. Remove the bolt on the end of the shaft, tow washers and guide then the spring. It has been awhile since I worked on the KX 250, but as I recall, the clutch does not need to be removed in the process of replacing the spring. I could be wrong on that. Below is the kick mechanism on your bike. Please rate my answer. Thanks. tombones49_146.gif
May 29, 2011 | 2003 kawasaki KX 250
Bike wont start
Check the ignition timing.
Feb 10, 2018 | 2003 kawasaki KX 250
Bumps, but wont start on the kickstart.
VALVES need to be adjusted it propbably pops and back fires when running too
Mar 06, 2010 | 2006 kawasaki KX 450 F
Motorbike wont start after running engine kawasaki kx 250 if i ride my bike for 2 minutes or 50 minutes when ishut down the engine it will not start again until i clean the spark plug
possible bad rings allowing excessive oil seep up and wash spark out on next fire. do a compression check, ck for proper spark, and fuel....hope this helps
Sep 13, 2009 | 2003 kawasaki KX 250
992 kx 250 wont crash start just locks up and kickstarter doesnt work it free spins to a point then gets to a hard point 1992 kx 250
Don't know this bike but I've only owned kick start HD'd.They work the same.The free easy crank on the kicker is the cylinder geting to the point of compression.The hard point is when you're there.Use your power and kick it!.Repeat if it don't start get to the hard point and kick it!..Make sure your gas valve is open and key on.Don't give it too much gas.If it don't start it's either Gas or Spark.Good Luck.
Sep 09, 2009 | kawasaki KX 250 F Motorcycles
kawasaki Full Suspension Mountain Bike Men Logo
523 people viewed this question
Top kawasaki Sport & Outdoor - Others Experts
Wayne McNeil
michael
michael
Are you a kawasaki Sport and Outdoor - Other Expert? Answer questions, earn points and help others
