When it gets to recovery screen it wont allow me to choose a restore, only option is exit
I assume your System Restore, in System Properties, System Protection isn't enabled/on. Use this procedure to turn on: http://windows.microsoft.com/en-US/windows7/Turn-System-Restore-on-or-off for future use. Also you may want to do a Disk Clean to free-up disk space for future System Restore space, if necessary. Use CCLEANER freeware at: http://www.filehippo.com/download_ccleaner/ This freeware program has some very useful tools, Look at TOOLS, STARTUP, to disable ALL unnessary startup programs to speedup starts and running of your machine.
SOURCE: WILL not resetting to factory settings
You will need to burn a Recovery CD / DVD set from the icon located on the desktop/ In your Acer Home Start utility (The window loading at startup) or from the Start Menu.
Using this disk you will be able to do a System Restore back to original factory setup.
SOURCE: It's performing really slowly. How do I restore
First do a virus scan and delete or quarantine any malware that comes up in the final results of the scan. Reboot the computer and see if it is running normally. If the computer is still not functioning properly you can use "Windows System Restore" to restore your computer's software configuration to an earlier date when it was functioning properly. The "System Restore" program is found under Programs/Accessories/System Tools.
SOURCE: I had a bad virus on my desktop (model M1100) and
if you want to restore it and remove the virus, u need to reprogram your mobile
SOURCE: I forgot my e-recovery password, no recovery disks...
Don't you have created the password Recovery disk early?
If you do, you can sign into safe mode and recover the password.
If you don't have the password reset disk. you have to take use of the 3rd party utility,
Windows Password Recovery 6.0 is highly recommend. It is fast and easy to use.
SOURCE: I need to restore my PC to factory settings but I
The factory settings are normally stored on a ghost (hidden) drive on your pc.
To view this folder, go into the tools menu and select folder options and then into the view tab.
Once there select the option to show hidden files, folders and drives.
This should reveal where your backup files are.
