Question about Kenmore 98702 Stacked Washer/Dryer
Screws fall off panel inside dryer
This has happened twice to me since 2005 purchase of Kenmore's stackable washer/dryer Model #41794702300. My first clue is an unusual noise followed by the sound of the first loosened screw spinning around with the dryer load. Eventually screws #2 and #3 follow and the dryer stops. The screws are very short and don't appear they could be holding anything in place (if that's their purpose).Why does this keep happening?
  • 15,935 Answers
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 14, 2010
  • 61 Answers
Not sure why this keeps on happening, but I would suggest putting a tiny bit of LocTite on the screws and then replacing them. It really only takes a drop. Give them at least half a day to a day to cure. LocTite WILL STAIN anything it gets on, so be sure to let the stuff dry.
Hope this helps!
Posted on Mar 16, 2009
Replace Kenmore electric stackable washer and dryer model #41794702300
Frigidaire built that unit for Kenmore, so look at new Frigidaire stacked "Laundry Centers."
Aug 29, 2016 | Kenmore Dryers
I have a Frigidaire stacked unit that I bought in 2005. The screws in the dryer drum keep falling out, their are 3 screws I have lost one, one still in and one I found in my clothes. The unit has caught...
Take one of the screws down to your local hardware and buy new ones and lock washers (with teeth on the inside so clothes won't catch on them).
Good Luck
Jun 06, 2009 | Frigidaire FEX831CS Top Load Stacked...
Need to replace the heating element in stackable Kenmore model 417.98702891
Go to and enter 417.98702891. You will be presented with a list of common replacement parts and may be able to view a generic Sears video showing disassembly with identification of various parts.
Mar 11, 2017 | Kenmore Dryers
Kenmore stackable washer dryer. Dryer buzzer is
Just solved this problem for a Kenmore stackable washer dyer! Sorry I don't have the model number. I have a baby on the way and a small house. I was pretty sure I would get no sleep between the baby crying and the baby crying because of that darn buzzer!
The buzzer is attached to the timer with a quick connect post. Access the controls by unscrewing the large panel above the washer door. You will need a square screwdriver or a very small flathead and some vice grips to get it started. The panel will fall forward onto the washer. In mine there was a pouch with an electrical diagram of the unit. To release the controls, two more screws must be removed from the sides of the small panel housing the controls. Once again you need a square screwdriver or a very small flathead and some vice grips to get it started. Once these are out you should be able to lift the control panel up and it will fall forward. Get a small box or stand to put on the washer. This will support the panel as the wires are not that long. On the left side of the timer controls you will see a quick connect post marked with an "H". Disconnect this wire and your problems are solved. Beautiful silence! I put electrical tape on the quick connect wire. Not sure if I needed to as I'm not an electrician. Hope this helps.
Apr 09, 2009 | Dryers
Owners Manual for Sears Kenmore Stackable Washer/Dryer
how do you seperate the stackables for moving
Oct 13, 2008 | Washing Machines
Stackable kenmore model 41794702300
We have had that happen too. You will need to take out what ever has blocked the valve on the drain. Ours was a bobby pin! My model is a bit different but if you follow the drain hose underneath you can find it. Remember you are dealing with lots of water. I think I scooped out the water first and have some towels ready. Or hire somebody to do it for you. I hope that helps.
Sep 03, 2008 | Kenmore 98702 Stacked Washer/Dryer
hi thanks for the question just underneath the dryer on the front theres a panel remove this panel the element is on the right thanks for the question the appliance doc
Mar 12, 2008 | Kenmore 98702 Stacked Washer/Dryer
Plug in for washer on a Kenmore stackable washer/dryer
the washer works off the 220v cord on the back you have other issues with the washer sorry
Jan 03, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 98702 Stacked Washer/Dryer Logo
80 people viewed this question
Sal De
 Brian Main
Brian Main
