Question about Vivitek Televison & Video
My 88 year old father purchased a 40" LCD vivitek TV - has Brighthouse as his cable company in FLA. no one has the TV Code for this tv and he has to use 2 remotes and has problems because of his age. Please have someone give me the TV CODE for this TV so that his life is simplier and less stressful. joanvalva@comcast.net To just hold the remote and hit the power/tv button on and off doesn't work.
The problem was not solved - your premium advice person could not find the code for this tv - I had asked him several times how the rate for this service from him was calculated - by the minute what and he never answered me on this - $25.00 later he gave me the same information that I already had - link to the tv maker vivitek web site and a picture of Bright house cable companys remote control directions that my dad already had. I won't use this service again. Joan Valva joanvalva@comcast.net
especially since I asked how my fee was determined for using this service was never answered.
Posted on Feb 18, 2009
  • hemp_luv Jan 27, 2011
    if or when you get a universal remote you will probably notice that there is not vivtek brand, use the Delta brand since they are the parent company also if you have cable or satellite you can use that remote and program it again using delta brand codes...
Where is the vivitek tv code
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Aug 22, 2014 | TimeWarner Cable Time-warner cable...
Looking for the enter code for vivitek tv model # rp51hd41-a a 51" micro display projection tv
your cable or satellite will do just fine. i have a vivitek rp51 and i was told that if i lost my remote i was SOT well i found out that the parent company of vivitek is DELTA and wouldn't you know it i programmed my direct tv remote using the brand delta wich was on the list and it worked... by the way vivitek is not on any list for remote control codes....
Jan 14, 2010 | Vivitek V37655 56" DLP TV
Progamming code for DYNEX t.v. w/ brighthouse cable remote
Do what I did...
Turn on TV
Press TV on the remote(will blink once)
Press and hold setup until tv button blinks twice
Hit 991 tv key will blink twice
Aim remote at tv press power button once
Press the Chan + key over and over until tv shuts off.
Same instructions as the manual
Jun 18, 2009 | Televison & Video
Dear Sirs, I purchased a 42'' DLP Vivitek from Shop NBC in 2006, we just moved and have Comcast Cable. They cannot program the remote as you are not listed with them at all. As I understand some how you...
most cable company remotes have a manual search option for tv codes usually a code listing book with the remote or on or under the remote battery cover see if you can manually search for the code that way however some tvs cannot be programmed to all cable company equipmet
May 13, 2009 | Vivitek Televison & Video
Set-up code for vivitek 30" model LT30PL1-A
There is a search function on the remote that will search for the code. Press TV, hold set up till 2 blinks, then 991. From there press tv then power and repeat till the tv shuts off then press set up again.
This can take a while and doesn't always work. You might check and see if Vivitek has a parent company ie owned by Sony or Panasonic and see if the codes for those work.
Oct 15, 2008 | Vivitek V37835 46 in. LCD Television
Universal cable company remote control codes
brighthouse remote code for panasonic amolifier to adjust volume
Mar 12, 2008 | Televison & Video
Remote control
I've heard Logitech Harmony 680 learning remote works with Olevia 232 model; not sure if it works with your cable.
Feb 26, 2008 | Olevia LT42HVi 42 in. LCD Television
Direct tv recorder and Vivitek V37835 46 in. LCD remote code for controller
IN THE GOOGLE SEARCH ENGINE TYPE VIVITEK V37835 MANUAL. ONCE YOU GET THE MANUAL LOOK IN THE SECTION OF THE MANUAL THAT SAYS SETUP CODES FOR SATTELITE RECEIVERS. FOLLOW THE INSTRUCTIONS FOR PROGRAMMING UR REMOTE. ALSO WANT TO LET YOU KNOW THAT I HAVE DISH SATTELITE AND I USE MY VIVITEK REMOTE NOT THE SATTELITE REMOTE FOR MY PROGRAMMING. MAYBE TRY THIS. IT WORKS FOR ME.
Oct 18, 2007 | Vivitek V37835 46 in. LCD Television
Sharp LC-37D4U 1080i picture problem
have the cable company set the box to 720p whic is the native resolution of the set.this will help with quick signal adjustment
Dec 29, 2006 | Sharp LC-37D4U 37 in. LCD Television
Televison & Video Logo
166 people viewed this question
Top Vivitek Televison & Video Experts
Jim Goldsmith
Jim Goldsmith
matt martin
matt martin
Are you a Vivitek Televison and Video Expert? Answer questions, earn points and help others
