Question about Marshall MG100HDFX 100-Watt Amplifier Head
The guitar lead plug has fallen inside.
When I removed the guitar lead from the plug, it fell apart. One piece came away and the rest has fallen inside. I can't figure out a way to get to the plug.
  • sb99512 Feb 18, 2009
    Thanks. Unfortunately, it is impossible to get access to the jack. I can get the top part of the back off, but all the tubes and things are in the way and I can't see how to get to the jack at all without actually removing all the corners of the amp which are riveted on. I think I need to get this to a shop!
    Hi
    There are no screws on the top - only rivets. The only screws are the ones that attach the back plate with holes in it that covers the top half of the back. This is a 100watt valve amp so maybe it's made a little differently.
  • 4,234 Answers
The safest way to fix this is to take the amp apart to get at the jack. If the jack is a solid black plastic shape, then you should replace the jack completely. Otherwise you should have access from the side of the jack to remove the piece of hte plug that broke off.
Dan
Posted on Feb 18, 2009
  • ABRsvcs Feb 18, 2009
    Usually there are screws on the top that hold the entire unit into the case. If you are comfortable trying that, remove the 2 or 4 screws from the top and the entire amp section should come out the back.
    Dan
Why is there a faint crackle from the amp when I strum?
Assuming that the problem goes away when you plug a differebt guitart into your amp, you have a loose ground somewhere in the guitar.
Aug 09, 2015 | Music
Marshall Repair
If you can see the socket, get a crochet needle that fits inside the socket and pull it back up through the hole. Good luck!
Nov 07, 2013 | Marshall Amplification Marshall MA100C MA...
The socket that the guitar cable plugs into has become unscrewed and fallen into the body of the amp. Is there a simple way of retrieving it from inside easily?
Yes, it should be as straight forward as gaining access inside the amp, locating the jack and putting it back, however make sure it is unplugged from the mains! If you are unsure if you are up to the task you should take it to your local technician as this will be an inexpensive fix
I recently purchased a Fender Classic Player Jaguar Special HH as well as a Fender Super Sonic 22 amplifier. I noticed there is a lot of noise coming from the amp with the jag plugged in, especially on the...
"Noise" is not a very good deescription... is it hum? is it static like? is it a buzz? Hum pickup by the pickups of guitars are common and some pickups are worse. If it is hum move the guitar away from magnetic sources like amps, motors, flourescent lights, dimmers... etc. Sme guitars have grounding problems and touching them varies hum. Also, do NOT let the guitar "hear" the amp as it can feedback at frequencies above your hearing even. Do some "sniffing" by moving the guitar and the orientation around the area seeing if you can find hot spots of noise to avoid.
Sep 20, 2011 | Fender Musical Instruments Corporation...
When I plug my lead into the jack input the guitar just makes a distorted noise a little like when you hold the end on a lead when plugged into an amp. I think maybe the jack inside has bent slightly...
If your unit has a battery, make sure you have fresh batteries. The jack ALSO serves to turn on the battery. If the jack is damaged or you use a TRS cable by mistake, the electronics will not be turned on and the sound will be very weak and distorted.
May 07, 2011 | Epiphone DOT Deluxe Flametop Semi...
There seems to be something wrong with the lead input socket on my guitar...it only seems to work (i.e. get a sound through to the amp) when the jack is wiggled around in the socket on the guitar and even...
Yeah, sounds like a bad connection. If you are handy, you can take the jack out yourself and determine if it is a loose wire or solder connection. If everything looks fine then you should squeeze the connections togather inside the jack itself. Sometimes it just gets pushed apart and does not hit around the male end secure enough.
Nov 30, 2010 | Fender Squier Standard Telecaster Electric...
The input jack on my Marshall MG100FX has fallen into the amp case......how do you access the case to retrieve
I just had this problem and wasn't able to find the solution on line, so, here 'tis.
Take off the six screws on top of the amp cabinet. Unplug the speaker plug from the amp jack.The metal amplifer box can now be pushed out of the back of the cabinet and the input jack remounted. I had to force the box a bit as it was glued in just enough to tack it into place. (I was afraid to force the electronics box out so I took the entire cabinet apart piece by piece until I could see there was nothing left holding it in.) I found that prying it this way and that with a butter knife helped crack the glue.
Dec 16, 2009 | Marshall Mg100dfx 100-Watt Combo Guitar...
Plug-in jack fell inside body of epi dot
jus take the roof bracket off the scratchplate and you can push it back out with some copper wire ! happened to me twice lol
Oct 22, 2009 | Epiphone Dot Electric Guitar
How do i plug my eletric guitar into an amp
Connect a 1/4" instrument cable from the guitar's 1/4" jack to the amp's 1/4" input.
Oct 02, 2009 | Dean Guitars Dean Ml79 Electric Guitar
I have just purchased a Yamaha EG012 and a Yamaha GA-15 Amplifier. I've followed the instructions adn plugged everything in, but when i turn on the amp and adjust the volumes there is just a buzzing noise...
You may have a switch with 2 settings somewhere on your amp - one for active and one for passive. try changing that.
If this doesn't work, make sure you got the guitar in the line input, change the lead for another incase it's faulty, turn the volume up on the guitar to activate the pickups, and rock-out when you find the problem and fix it.
Dec 30, 2008 | Yamaha Electric Guitar
Marshall MG100HDFX 100-Watt Amplifier Head Logo
298 people viewed this question
Top Marshall Music Experts
Michial Gueffroy
matt martin
matt martin
Leonard Jeffrey
Level 1 Expert
Are you a Marshall Music Expert? Answer questions, earn points and help others
