Question about Electrolux 24 in. EDW5505EPS Stainless Steel Built-in Dishwasher
I have a DX302 and it is not drying at the end of the cycle.
  • wundermac Feb 22, 2009
    not heating water not drying
  • Anonymous Apr 30, 2009
    I have the same problem, not heating and not drying, with my Electrolux DX302.
    I will try the suggested action.
    Thank you.
    Dan
A friend had the same problem and i found that the circuit tracks that go to the relay that controls the element had burnt off. solved by soldering on some new tracks. The problem is quite obvious when you pull the controller apart, burn marks and missing tracks. You just need someone that's handy with a soldering iron.
Posted on Feb 23, 2009
DISHLEX DX302 REPLACE HEATING ELEMENT
Remove the device and then restart again
Jan 25, 2014 | Dishwashers
Electrolux dishwasher DX302 isn't drying the dishes. What might be wrong?
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Aug 27, 2010 | Dishwashers
Dishes are not drying at the end of cycle there is no heat
if its a ss or lg its normal open the door at end of cycle
May 30, 2010 | Dishwashers
User manual for electrolux dishlex DX302
Go to http://www.dishlex.com.au/SupportCentre and then search by the model description DX302WB. I downloaded a pdf file no problem.
Nov 12, 2009 | Electrolux Dishwashers
Dx302 dry joint found what do i solder ?
Putting a small dob of solder on it should work just fine, make sure you get a nice hot even solder. Although if you have some small guage copper wire try to bridge the dry solder joint to the solder track that it shares on the same circuit on the PCB. This should be a much better fix.
Oct 30, 2009 | Electrolux 18 in. ESL4114 Slim-Line...
No heating in dishwasher
Do not plug it into hot water UNPLUG. It needs cold water going through the system.
It may be the heating element or just a loose connection on the computer panel.
If you have any Questions plese do not hesitate to ask
Dec 03, 2008 | Dishwashers
repair the solenoid
Mar 27, 2008 | Dishwashers
Electrolux 24 in. EDW5505EPS Stainless Steel Built-in Dishwasher Logo
365 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Starnley Johnwells
Starnley Johnwells
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
