Question about Sony Playstation 3 (PS3) Console
When i turn on there are squigly lines but i hear sound but cannot see display connected through hdmi
  • Anonymous Feb 18, 2009
    the startup screan appears that says sony computer entertanment then that vanishes but the wave stays, the waves keep moveing but nothing else.
    President:
  • 2,653 Answers
Start with a video reset first.
Hold down the power button until you hear two beeps then release immediately. That will change the video back to the default settings. Let me know what happens and we'll go from there.
Posted on Feb 20, 2009
I have a goodmans TV is having issues, sky box works fine through the hdmi but, ps3 no display or sound through the same port, my ps4 gets pic but no sound, both consoles have been tested on other tvs
1.Put your PS3 on standby.
2. Unplug the power lead.
3. Connect HDMI cable to HDMI out on PS3 and HDMI in on TV
4. Connect PS3 so that the red standby light is showing
5. Hold down the On/Off button until you hear a second beep. The PS3 will try and detect the display output settings on your monitor.
Dec 02, 2015 | PS4 Video Game Consoles & Games
Tip
Playstation 3 has sound but not showing picture
It sounds like you have changed your display settings either to HDMI but are not connected with HDMI or you have set the progressive scan to ON and it's not supported by your TV. Try turning off the Playstation 3 and then hold the power button for about 5 seconds, until you hear a second set of beeps. This procedure will reset your display settings, then auto detect your connection, provided you have kept up with the updates. If you have kept up with the updates or aren't sure, you can use the same steps, but you will need to be connected via Composite Cable and not HDMI. If this doesn't work, you may need to send it in for reparis.
on Nov 25, 2013 | Sony Playstation 3 (PS3) Console
Playstation3 problems
Probably changed the display settings. Turn off the Playstation 3 and the hold the power button for about 5 seconds, until you hear a second set of beeps. It sounds like you have changed your display settings either to HDMI but are not connected with HDMI or you have set the progressive scan and it's not supported by your TV. The above procedure will reset your display settings they auto detect your connection, provided you have kept up with the updates. Let me know if this doesn't work for you.
Nov 25, 2013 | Video Game Consoles & Games
I can hear my Ps3's Sound, when the HDMI cables are connected, and it's on the correct HDMI channel, though i can't see anything, the screen is just black. I have tried holding the power down, until i...
Ok, you are actually holding the power button down for too long. Please do the following to sort out the display on your PS3.
Turn the PS3 off into standby (red light on)
Press and hold the power button. It will beep once when you first press it, then beep again about 5 seconds later. Release the power button when you hear the second beep. The display will now reset and it should detect your HDMI display with no problem.
Hope this helps
Dec 23, 2010 | Video Game Consoles & Games
What cables do i need to connect my ps3 to my sony recevier.
do you wan the suround sound to play sound for what the tv is displaying or just the ps3
for just ps3
connect hdmi to ps3 and tv
connect optical to ps3 and suround sound
change video settings to hdmi
change sound settings to optical
it asks to set settings automatically you have tyo doo it manually
if you want to play every thing that tv displays then
connect ps3 to tv with hdmi
connect suround sound with hdmi to tv
(this might not work)
if it dont work then
and your tv should have sound out or something along those lines it should be two phono plugs in the back of the tv connect that to the suround sound
Dec 31, 2009 | Sony HT-DDWG700 Theater System
The viewfinder does not display anything
Hi!
The display is broken. They are not repairable, only replacable. You should contact your local Pentax service center. Small repair shops could do it too, as new displays are available on eBay.
Hope this helps!
Tom
Aug 02, 2009 | Pentax Optio A20 Digital Camera
Squigly lines run across screen cannot take pictures.
If its Canon A75 camera then its problem of defective ccd imager and Canon will repair your camera free of cost.
Click Canon CCD Imager Advisory for details.
Apr 30, 2009 | Canon PowerShot A75 Digital Camera
Video has squigly lines in it at the top of screen ..
Small board called a hyper module bad .....can be rebuilt be
skilled tech or sent for rebuild..........................T.
Jan 10, 2008 | Toshiba 50H13 50" Rear Projection...
Compaq wf 1907 monitor speakers--no sound
No sound from monitor speakers
If the built-in speakers on the monitor do not produce sound, perform each step that follows, testing for sound after each step, until you can hear sound:
  1. Close the software program you are using that is experiencing the sound problems. Test for audio using another software program.
    If the volume is adequate using another software program, the issue is with the computer, not the monitor. If the volume is still low, continue with this procedure.
  2. Check the cable connection. If the monitor-to-computer connection is a VGA cable (usually blue on both ends), an additional audio cable is needed between the monitor and the computer. Check that the audio cable is connected properly.
  3. Try to adjust the volume higher using the monitor front-panel volume button.
  4. Using the buttons on the monitor, navigate through the onscreen display (OSD) menu to find audio or speaker settings and enable the speakers.
  5. Click Start c01292216.gif , Control Panel , and then click Sounds and Audio Devices .
  6. From the Volume tab, check the Device volume, and make sure it is not muted.
  7. From the Audio tab, in the Sound playback field, click the Volume button. Make sure the audio device is not muted and the volume outputs are at adequate levels.
  8. If the monitor-to-computer connection is an HDMI cable, an additional audio cable might be needed, depending on the setup and configuration of the system. To find out whether an additional audio cable is needed, go to
HP and Compaq Desktop PCs - Using HDMI Audio with a Desktop Computer
This document pertains to HP or Compaq PCs with an HDMI (High-Definition Multimedia Interface) connector.
HDMI sends both audio and video through the same connection. If you want to hear audio from an HDMI connection, HDMI audio must be set through Windows . For example, if a computer is connected via HDMI to a monitor or TV and the proper HDMI audio settings are made, both audio and video will be sent to the display device.
Use the following steps to activate HDMI audio on your computer:
    NOTE: If you are setting up your computer for the first time, it may be easier to use a DVI connection or DVI-to-VGA adapter connection for the initial setup. Then, if you want to use an HDMI connection to connect a TV or monitor, activate sound for the HDMI connector using the steps that follow before connecting the HDMI cable to the TV or monitor.
    NOTE: After recovering the computer using the Recovery Manager, repeat this procedure to activate sound for the HDMI connector.
Step 1: Enabling HDMI sound in the BIOS
To hear audio through the HDMI connector to a monitor or display, enable the Onboard Audio setting in the computer BIOS settings by completing the following steps.
    NOTE: If you choose the default BIOS Setup options or upgrade the BIOS, you must repeat this procedure to enable audio for the HDMI connector.
  1. Turn off the computer.
  2. To enter the BIOS, turn on the computer and press the F10 key repeatedly until a BIOS Setup screen opens.
    A BIOS Setup screen opens.
  3. Press the right arrow key on the keyboard to select the Advanced tab.
  4. Press the down arrow key to select Onboard Audio , and then press the Enter key.
    Figure 1: Example of Onboard Audio menu
    An option window opens.
  5. Press the down arrow key to select Enabled , and then press the Enter key.
    Figure 2: Onboard Audio Enabled
  6. Press the F10 key. Select Yes to save the default settings, and then press the Enter key.
  7. The computer restarts. HDMI sound is now enabled.
Jan 03, 2008 | HP Compaq WF1907 Monitor
Ps3 video
Try turning off the system then hold the power bottom until you hear 2 beeps. First beep will be power on. Second beep will be reseting display image.
Aug 16, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
