Question about Maytag MBF2256H Bottom Freezer Refrigerator
My refrigerator is 2 years old never had any problem, now
Neither the freezer or the refrigerator is working and is very warm inside. used to be very quiet now it makes loud noise and not cooling at all.
If you have a warranty take it back, or call the manufacturer and have them take care of it
Posted on Feb 18, 2009
Have fridge freezer 8 years old , lights work but warm inside and all food defrosted , is it worth getting fixed or shall I get knew one?
My advice would be to go for a new one as the product you are holding is more than 8 years old. Although, obviously new is going to be a little on the expensive side as compared to getting this one fixed but technology has moved a long way in the last 8 years. Thus, your current Freezer is going to consume more electricity and even after being repaired, the performance shall not be optimal. While, the new Refrigerator not only is going to be Lessen your electricity bill but shall be a better choice both in terms of Style, Structure, Optimization and Performance.
Oct 30, 2012 | Refrigerators
GE Profile Side-by-Side Refrigerator - Freezer Warms Up - Motor Gets Loud - Eventually Cools Back Down
Sounds like your thermostat is faulty this should be covered by a warranty This problem eats electricity so will need attention asap
Oct 29, 2012 | GE Profile PSHS6MGZSS Side by Side...
Is it normal for warm air to blow out of the fan at the top of a side by side sub zero. Its over 20 years old and we recently had the compressor replaced on the freezer side.
warm air will blow out from the condenser fan which is in the same area as the compressor.
There should be no warm air inside the freezer of fridge.
Jul 22, 2011 | Sub-Zero 650 / O Bottom Freezer...
2 year old LG refrigertor doesnt cool inside is warm and the bottom freezer doesnt work either. outlet is ok. the light inside the refrigerator works.
Your run capacitor is bad which is the plug attached to your compressor or you have a leak in the system. If your compressor is not running after you put a capacitor on then your compressor is fried. Good luck. Rate me if I helped you!
Aug 27, 2010 | LG LRFD22850 Bottom Freezer Refrigerator...
Refrigerator not working blowing warm air
there is a control board located inside the lower left rear wall near the floor by the compressor end of unit,you will need to replace this board,a sign of this will be if you have heard a clicking sound from there and you have blown out light bulbs in the refrige section,and the temp indicators are out or dark,its easily replaced by unplugging old and plugging new board inside plastic box
Jan 09, 2010 | Refrigerators
GE fridge is warm and broken; the freezer is cold though.
Air circulation problem. Evaporator fan in freezer moves some air to refrig. Either fan is not working or air passages are blocked with ice. If ice found, then a defrost component failure has occurred. Fix what you find.
Sep 19, 2009 | GE Profile PDS20MFS Bottom Freezer...
Frigidaire plht189sska top freezer fridge problem. Freezer is cold, fridge is warm. About a month ago, had the problem of frost build up in freezer, water pooling under veggie bins, warm fridge. ...
If the defrost heating element, defrost timer or evaporater fan weren't working, you'd develop a block of ice on the evaporator. Is the compressor running? If it is, it might have bad valves from the frost buildup scenario. Liquid refrigerant could have gotten to the suction valves. The sealed system should have a five year warranty. Might be time to call a pro
Sep 15, 2009 | Frigidaire PLHT189CSB Stainless Steel Top...
Frost inside freezer door
there is a small electric heater along the door gasket where you see the frost building up, this heater has apparently stopped working. this will also cause the door to pop open due to a poor seal. feel around where the door gasket contacts the refrigerator and it should feel a little warm. if not then a service company can replace those heaters. should not be too expensive.
Jun 28, 2008 | Kenmore 73262 / 73264 / 73269 Top Freezer...
Maytag MBF2256H Bottom Freezer Refrigerator Logo
87 people viewed this question
Top Maytag Refrigerators Experts
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
