Question about Microsoft Xbox 360 Console
My xbox360 has one red ring in the bottom right corner.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 364 Answers
XBOX 360 Red Light error, or Red ring of Death RORD is a very common issue, and can happen anytime. There are different Error numbers related to RoRD, and appears on screen starting with "E".
Red light problem can be fixed! there is a XBOX 360 repair guide available that covers this problem and also all other common XBOX problems. You can get your copy XBOX 360 Repair Guide, you can download it and get help to fix your console. Please feel free to message me if you need further assistance click here
Posted on Dec 26, 2010
    Problem Solver:
  • 5 Answers
If it wont work at all its fried and you need to send it in, but if it does work just has that circle im not sure sorry :(
Posted on Feb 18, 2009
4 Suggested Answers
Quickie
  • 54 Answers
SOURCE: xbox360
The Specific Type of hardware failure can be determined by the error code displayed on the screen.
If the screen is blank or you would like additional information follow the instructions for determining the secondary error code in the section below
E45: Unknown (possibly dashboard update related)
E64: DVD Drive Error.... DVD Timeout, Wrong firmware, dvd is without f/w chip, etc.
E65: DVD Drive Error.... DVD Timeout, Wrong firmware, dvd is without f/w chip, etc. This can also be caused by the tray not being fully closed on boot.
E66: DVD Drive Error: DVD model, or version does not match that of the version expected by the dashboard. OR the firmware version on the drive is older then the firmware version expected by the dashboard. Make sure the DVD drive is of the same version originally included with the console and that it is using either the original firmware included with the console or newer.
E67: Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it
E68: Voltage Error... This error means that the Xbox 360 has insufficent power to function properly. This can be caused by an error in the hard drive or the fans that make them suck up too much power, it can also be caused if you have unnecessary accessories attached to the console like an external fan unit. Attempt to remove unnecessary accessories first, and then necessary components such as the hard drive and USB devices. If you have any case mods you may want to investigate those as well.
E69: Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it
E71: possibly a dashboard update error, Check below in the "Console Reset Codes" for instructions. If that does not work there is no other solution and the console must be sent back to MS for repair.
E72: (not yet known)
E73: General Hardware Error: Ethernet port... this error is caused by a problem with the Ethernet port.
E74: There is a 90% chance it's a scaler chip problem (the "ANA" or "HANA" chip near the AV cable connection) it can also be caused by a faulty AV cable so check that first. In rare cases it is a problem with the GPU.
E76: This error deals with the Ethernet port's controller chip, a dead chip may not cause the error but removing the Ethernet controller chip does, it may also be caused by other Ethernet related problems.
E79: Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it.
According to tmbinc: E79 is the error code if xam.xex could not be started, i.e. probably a file system corruption.
Posted on Dec 12, 2007
  • 37 Answers
SOURCE: quarter of red ring.. bottom right
remove the harddrive then reboot the console
Posted on Jul 14, 2009
  • 5 Answers
SOURCE: it has a red ring on the bottom right corner
http://support.microsoft.com/kb/907534
Posted on Aug 11, 2009
Two rings on xbox360 how to fix
over heated just let it cool down also make sure the xbox is in a well vented area
Oct 24, 2009 | Microsoft Xbox 360 Console
When i turn on my xbox360, a red ring flashes and the bottom right segment stays red and it tells me to contact customer support
Have you tried disconnecting your hard drive to see if this was the issue? Sometimes just reseating the HD after turning it off resolves issues like this.
Hope this helps,
Bill
Sep 03, 2009 | Microsoft Xbox 360 Console
E-74 red light on bottom right corner
sounds like the red ring of death, contact xbox as they give u a 3 year warranty on this, they will pick it up and return it fixed.
Aug 07, 2009 | Microsoft Xbox 360 Console
Quarter of red ring.. bottom right
i'm going thru this same problem right now...remove the harddrive then reboot the console...if it boots up properly then your hard drive is shot...that was what was wrong with mine..i bought a new hard drive and it work great again
Jul 14, 2009 | Microsoft Xbox 360 Console
Xbox360 e74 error
Section 4 is flashing red
- Hardware Failure
Jun 06, 2009 | Microsoft Xbox 360 Console
Exbox 360
You can check out the informative blog post at http://www.fix-xbox360.info/2008/09/11/xbox-360-disc-read-error-e74-error-no-video-problem/
This post describes the E74 error with one red light problem.
hope it helps...
Jan 05, 2009 | Microsoft Xbox 360 Console
One red light bottom right hand corner
hope it helps...
Jul 22, 2008 | Microsoft Xbox 360 Console
Red lights on xbox 360
Which three lights? if its Top Left, Bottom Left, Bottom Right, then you have the infamous "Red Ring of Death." witch means general hardware failure. If you search around on the internet, there are some Xbox360 modding sites that sell kits to repair this kind of problem (if youre brave enough to tackle it).
Luckily Microsoft is aware of this problem and has extended thier warranty to 3yrs (but ONLY if you have this particular problem).
Otherwise you'd have to send it into Microsoft to get it repaired.
Apr 01, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
71 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
