Question about Poulan Pro 42CC 2 Cycle Chainsaw, 18"
My Poulan 3500 chain saw will not start
I have checked the carb, the fuel filter, the air filter, put in fresh mixture, checked spark plug, and the fuel cap and all appear fine. Chain saw worked to cut down tree but broke down while cutting limbs. I am using my electric drill to force motor instead of pulling on rope constantly but motor is not starting. I empty the gas tank and put in straight gas and it ran I then added the mixture to it and now nothing. (this is when I am troubleshooting, not when cutting) Any solution to this problem?
  • Thomas F. Schneider May 11, 2010
    Low long did you run it on straight gasoline?  Straight gas=no lub.
    Check the compression. The other possibility is that the passages inside of the carb are partly blocked since it ran on straight fuel and the mixture is heavier(thicker).
3500 poulan runs and secand stop
Posted on Oct 22, 2010
  • 42 Answers
My guess is that one of your fuel lines has a crack or small hole in it. Inspect these and replace if needed. let me know how it goes.
Posted on Mar 07, 2009
Poulan 2375. Just replaced all fuel lines. Only stays running at greater than 1/2 choke. Have never had to adjust carb before. Maybe an air leak around carb? Easy way to check for that? Any suggestions or...
First I would start with the fuel filter, was that replaced too?, then I would make sure you have fresh gas and a new spark plug, Probably what I would suggest next is to pull your carb off and take apart and clean it with carb cleaner, most likely you will find dirt and possible small fragments from rotten fuel lines,partially plugging the inlet screen in carb, also your diaphram could be stretched, wouldn't hurt to pur carb kit in it while it is apart, I have just cleaned them before and been o.k. this should help you out
Apr 21, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
My Poulan 18in 40 cc WildThing ChainSaw Won't Start.
Start with basic tests, drain the fuel tank and fill with fresh fuel oil mix, remove and reolace the fuel filter on the edn of the fuel hose, check the fuel hose up to the carb for leaks, remove the spark plug, rest it on the side of the cylinder ( away from the plug hole ) cramk the engine and check if you have a spark.
Apr 16, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
I have a poulan pp4218avhd chain saw that won't sart. I have cleaned the spark arrestor & the air filter. I have replaced the spark plug with a correct gap and checked that it is getting a spark. I...
I have this saw and really like it. Does the the primer seem to work? Most problems on these saws can be traced back to cracked fuel lines. Either tank to primer, primer to carb, or carb return back to tank. I would recommend it the saw it more than 3 years old to replace all the fuel lines. Total cost about $5. Buy your fuel line at Ace Hardware.
May 05, 2010 | Poulan PP4218AV 18" Chain Saw
Chain saw won't start
Check the fuel filter for plugging (which is common when fuel is left in the machine over winter storage). You should run the carburetor dry after emptying the fuel tank for storage.Hope this helps!
Apr 14, 2010 | Poulan Pro Chain Saw 46cc 20"
Husqvarna 51 died and wont restart
hi
if you have a good compression,a strong enough blue spark and carburetion for the fuel air mixture try priming the engine(put small amount of gas in the spark plug hole)then start the engine.If the engine runs only the gas you put inside the cilinder there is a carburetion problem to find and fix.
let me know regards savumihai71
Apr 13, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Gets hot, sizes up.
Clean carb. Pull apart and soak in carb cleaner. Blow dry with air nozzle. Make sure air filter is clean and plenty of air. Make sure spark plug is not gapped wrong and running to hot. Make sure oil/fuel mixture is accurate
Nov 12, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan 3500 wont start
Try putting in fresh gas. Change spark plug. Clean out air filter.. Check choke for proper operation. Make sure it is getting spark and fuel.. Hope that helps dont know what you have done to the saw.
Jul 06, 2009 | Garden
Saw does not idle and is hard to start. It is a P3314 Poulan
You have gum in your carbeurator.
You can try a carb. cleaner that you add to the gas. I likve one called seafoam. You add one ounce per gallon of fuel.
Also, you must have a good clean spark plug, and a clean air filter. The spark, the fuel, and the air all contribute to an easy start and a good idle. If you havn't changed the spark plug lately do so, same with the air filter.
Jun 24, 2009 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
I havent used the chain saw for a few years and and not sure how to get it started...any help would be appreciated It's a Poulan Micro XX5 Deluxe and i'm looking for a manual...
Check fuel lines for stiffness & cracks'
Replace filter,plug,and fuel mixture.
If your lucky it might run.
If not check spark .
If spark is ok you may need to clean and rebuild carb making note of screw settings.
Also pull muffler and check for carbon build up.
Mar 19, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan Pro 42CC 2 Cycle Chainsaw, 18" Logo
1,319 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
