Question about Great States Corp. 18 In. Scotts Deluxe Reel Mower
Scotts 20" reel mower. Drive wheels will not turn blades any more. Blades turn freely, but will not be driven by wheels.
This is almost certainly a problem with worn pinion gears, which are unfortunately made of plastic. Replacements are just a couple of dollars, but you'll probably want to buy a few for each side in the event this happens again. The Scotts 20" reel mower is manufactured by Great States 1-800-618-7474. You can also find more information at www.reelmowersetc.com and the user manual for this particular mower can be viewed at http://www.reelmowersetc.com/2000-20.pdf.
Posted on Aug 04, 2009
Replacing the pinion gears in each wheel. Which way do the ratchet pawls go?
the pawls are positioned so that when the wheels rotate in a forward direction they lock up the pinion and drive the cutter blades ,
they release when the mower is pulled backwards
as for grease , if it had none then none is what is used
If it had grease then a water resistant bearing grease would be prefered
May 28, 2016 | Scotts 20" Classic Reel Mower
I have a craftsman riding mower i went over some hidden roots now when i turn on the lever to start the blades to cut nothing happens.
You probably bent a blade into the deck. Its possible that something else is wedged in between the blade and deck. You can set the front wheels on a block and look under the deck. With mower off and blade disengaged, see if blades turn freely. Check each blade seprately.
Jun 02, 2014 | managemylife.com
Husqvarna h2201-18 reel mower blades wont turn
I have the same mower and had the same problem. You need to install a new clutches part H2201-18-05. They're located beneath the wheels which you'll need some snap ring pliers to remove.
Sep 03, 2012 | Husqvarna Garden
I have a LT2000 21 HP lawn mower. The mower is brand new, just put gas in it today. I can't get the mower blades to engage without shutting the mower off. I have tried it in neutral, forward, sitting...
Hi, Have you tried to turn the blades by hand ( WITH THE MOTOR OFF ) I suspect there may be some transit packing that you may have missed. The blades should turn freely with the motor off and the blade engaged. There is a blade brake which stops the blades turning when the drive is disengaged which might need adjusting .
Hope this helps.
Dec 30, 2017 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
How do i sharpen cylinder mower blades
I believe you mean to say a 'reel' mower. Normally and old fashoined push (non-engine powered) mower.
Most consumer reel mowers do not need to be sharpened. They do however have a knife bed that occasionally needs to be adjusted. It should have the thickness of a regular piece of notebook paper between the blades and the knife bed. (that is really VERY close) You can buy 'lapping compound' from an automotive parts store, and apply that to the bed knife, and then rotate the blades to provide a precise fit for all blades.
Commercial reel mowers, such as those used on golf course equipment are however sharpened normally once or twice a year. It requireds dismantling, and many courses send their blades to a central location for golf equipment, where they are placed on a computer operated sharpener for precision grinding. This cost several hundreds of dollars just for the grinding.
Nov 12, 2009 | Garden
How to adjust blades to cut evenly?
should be a screw iether side above the blade turn clockwize to close the gap between  the blades both sides should touch the cutting blade on the bottom you have to turn the centre blades by hand to make sure both sides are even but be careful not to catch fingers on the blades while turning
Oct 04, 2009 | Great States Corp. 16 In. Scotts Elite...
Wheels won't engage the reel of the mower.
Pop the cover off the center of the wheel with a small flat-blade screwdriver.
Pry the lock ring off the axle, again with the flat-blade screwdriver.
Lift the wheel off.
The small gear (pinion) lifts off of its axle. You may just need to lubricate the pinion gear and the little bar of metal that it engages. If the pinion is damaged, buy new ones; they're pretty cheap.
When reassembling, the lockring is easily clicked back on with a pair of pliers.
I found some replacements at http://www.reelin.com. The parts number for the pinion gear is 30737-2, 30737-3 (left and right) for the Scotts Classic.
You can find the owner's manual, with part numbers, here:
Jun 17, 2009 | Great States 20" Scotts Classic Push Reel...
Scotts reel mower gear problem
Jun 09, 2009 | Great States 20" Scotts Classic Push Reel...
Reel mower isn't engaging -- blades aren't rotating and cutting
Remove the wheels and check the gears inside.
It sounds like they are worn or sheared and need
renewing
Jun 05, 2009 | Great States Corp. 16 In. Scotts Elite...
Scotts Classic 20" drive gear problem
In addition to lubrication problems, the plastic pinion gears can wear down or deform. This can cuase them not to engage, even if well-lubed.
Jun 05, 2009 | Great States 20" Scotts Classic Push Reel...
Great States Corp. 18 In. Scotts Deluxe Reel Mower Logo
494 people viewed this question
Top Great States Garden Experts
Dennis Key
Dennis Key
Marco De La Fuente...
Dan Apthorp
Are you a Great States Garden Expert? Answer questions, earn points and help others
