Question about Vacuums
Replacement battery for a Shark rechargeable sweeper
I need to replace the battery as it does not hold a charge.
    New Friend:
Sure, take a look on amazon for replacement.. here: Finally charging for our multi device world. I hope this was helpful. Cheers
Posted on Dec 16, 2014
  • 32 Answers
You can order a replacement battery by going to their website:
http://www.sharkvac.com/partsearch.aspx?CatID=cxmdqvOilfw%3d
You have to put in your model information to get the right battery.
Posted on Feb 18, 2009
I have a shark cordless sweeper modelv1950 bought about 4 months ago and seems to start well and suddenly stops functioning. I know battery must be changed every 9- to 12 months. I wondering the battery is the problem?
Posted on Jan 14, 2010
Phone Number for Shark is 1-800-798-7398 or you can check out "www.sharkclean.com". I just phoned to get a replacement battery for my Cordless Sweeper - Model # V1725QC. They will also ask you for the DATE CODE that is stamped on the bottom so you get the right battery. Price was $16.95 for the battery and the total is $22.90 (cdn). I should receive the battery in 7-10 business days (so I was told). It is being shipped from Quebec to BC.
Posted on Nov 23, 2013
Keeps stopping even though I have taken it apart and checked for blockages. +
Are you sure your wall charger is working ok? You might just have a bad battery pack in the sweeper if your charger is working. Do you have a friend who knows electronics and has a voltmeter?
If so, have them check the voltage output of the charger at the plug that goes into the sweeper. Verify that the charger is indeed working ok. Then you will need to check the voltage on the battery pack inside the sweeper to see if your battery is good and holding a charge. A mechanical blockage could be something caught in the vacuum fan blade. You should be able to hold the main part of the sweeper up to your ear so you can hear and then pull the sweeper trigger and see if you can hear the motor try to start. Nothing happening may mean a dead battery pack. Regards, Dennis
Aug 15, 2015 | Dyson DC44 Animal Cordless Vacuum Handheld...
I need shark battery for sweeper xbn1917
Contact Shark Vacuum Shortest Wait Best Support
http://gethuman.com/contact/Shark-Vacuum/
Shark Vacuum Customer Phone Number Shortest Wait Best Support
http://gethuman.com/chat/Shark-Vacuum/
1-800-798-7398
press 4. then 5
1-800-798-7395
press 2 for customer service
Also take the battery to a Radio Shack store and they maybe able to order it for you or even have it in stock.
Nov 16, 2014 | Shark 10" Cordless All-Surface Power...
Trying to get batterys for shark rechargable sweeper model #v1725QC 4.8Vdc I'am located in london ontario canada can I get batters locally?
I have a Shark Cordless Sweeper that needs a new battery too. (Model V1725QC 4.8V) I Googled around and finally gave up and phoned the number on the bottom of the Cordless Sweeper. No problem. The lady did ask me for the "DATE CODE" that is stamped in the silver part on the bottom of the sweeper. The number was 4608 (not easy to read). The battery cost is $16.95 and with Shippling the total came to $22.90. I should receive it in about 7-10 business days. It will be coming from Quebec to BC so that is the total Canadian Price. All model info is on the bottom. The Phone number is on the bottom of your Cordless Sweeper in white lettering on the black plastic towards the rear. The Phone Number is 1-800-798-7398. I hope this will help some other people. Just phone them - best to stick with the Shark Company batteries and they are not easy to find otherwise. No fuss, no muss when I called. No problem ... just gotta wait now. You can also try "www.sharkclean.com" ...
Feb 05, 2011 | Vacuums
I need a new charger, not a new battery, for my Shark rechargeable sweeper. Any ideas??
most electronics supply shops like cady shack will be able to match the old charger for another if you take it in with you
Jan 02, 2011 | Vacuums
I have a Shark Euro Sweeper, and it doesn't hold it's charge. I only use it a matter of a few minutes and already the green light turns to orange. I was told it would hold a charge for 30 minutes. So...
I assume you've had the cleaner for a while and your battery is dying. Batteries can only be recharged a finite number of times and they also suffer from "memory loss" due to not being fully discharged before recharging.
Basically, you need a new battery. I'm not sure of your location, so I can't recommend a local supplier, however they are available from the manufacturer's website:
http://www.sharkclean.com/cgi-bin/livew/site.w?location=b2c/parts.w&itemCateg=01&frames=no&target=main&sponsor=000006
I can't give you a price as I don't know your exact model. but it should be about US$15-20. If you call the manufacturer, they may be able to give you details of a local supplier and an RRP.
Hope this helps.
Oct 18, 2010 | Vacuums
Shark model V1700Z The handle broke off at the
Look it up online. I found a place that charges 7.95 for the part & 6.99 shipping. Get the Model # off the bottom. Mine is V1700Z. And look it up that way on Google or Bing. I think it's listed online as EuroPro.
My servers love this little baby, but they keep breaking that little piece. I understand that the rechargible batteries may wear out in a year, but I have yet to have a handle base last that long.
A Bissel sweeper costs more, clogs faster & does not do as nice of a job. so even if I have to replace it 2x a year, it's not a total, loss
Jul 14, 2010 | Euro-Pro Shark Cordless Stick Vacuum...
I charged the sweeper and it does not start anymore. How do I know I need a new battery?
Call Shark. I had a similar problem. They will send you a replacement. They are very nice.
Dec 15, 2008 | Euro-Pro Shark Cordless Stick Vacuum...
Can I buy replacement batteries for Shark Cordless Sweeper
I need a replacement battery for my Shark Stick sweeper model V1911 N. Can't find it on their web site. I guess it is old. Murnieruth
Nov 25, 2008 | Euro-Pro Shark Professional Upright Vacuum...
Vacuums Logo
6,375 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
