Question about Mitsubishi WS-65869 65" Rear Projection Television
All of a sudden our color has gone crazy on our 54" mitsubishi. They look bleeding and when there are words you see two almost as if it is 3D what do you think?
  • 4,234 Answers
If you look closely and the 3 colors are separated, the problem is in the convergence circuit. If you can solder, you should be able to fix this yourself. Realize that there are potentially dangerous high voltages inside the set even when unplugged. If you wish to attempt the repair yourself, let me know and I'll provide additional details and instructions.
Dan
Posted on Feb 18, 2009
Color on tv is distorded
I need to know model and a photo of picture (you can post here) or a better description of the issue--for example;"Picture looks 3d but is not a 3d set" "colors are skewed"
Colors look like this photo
Dec 13, 2012 | Mitsubishi Televison & Video
I have mitsubishi vs-50800 i was watching a movie and the screen just all of a sudden went blury and the color is all mixed up i went to the convergence menu and it wont allow me to move the colors left or...
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video or dead set) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. In some cases the TV will also not show any video. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can get the correct parts, step by step photo instruction guides, and support from www.TvRepairKits.com or click here
May 03, 2011 | Mitsubishi VS-50800 50" Rear Projection...
Color distortion, hazy snowy screen with thin red lines, suddenly happened had perfect pic 24 hours ago
Tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board is dead.The tv convergence board require replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Feb 01, 2011 | Mitsubishi VS-50705 50" Rear Projection...
Mitsubishi WS-65511 volume control has gone crazy. All of a sudden volume went to full blast and now with manually pressing volume button it is either full volume or lowest volume. We have DISH and...
Mitsubishi WS-65511 volume control went crazy after a storm. Now we don't having any volume. None of the controls are working on the front of the panel with the exception of the device control.
Jun 02, 2010 | Mitsubishi WS-65511 65" Rear Projection...
Mitsubishi WS-55511 convergence problem?
No,need to diagnose.It a 100% convergence problems.Convergence problems very easy diagnose.The picture look like 3D,colors lines don't lines up.Fuzzy,out of focus.Convergence controls don't work to lines up any colors cross.The tech is cheating u if he said cost $125 to diagnose.If u know how to solders u could fix this convergence problems about $100.U can buy a convergence kit at Websites Tv repair World.com,Tvrepairkits.com.The shop everythings fix parts and labors only $300.
Mar 16, 2010 | Mitsubishi WS-55511 55" Rear Projection...
My picture is gone crazy
Call a good TV Tech and have him replace the color wheel assembly.
Jul 29, 2009 | RCA HD50LPW175 50" HDTV
Lost picture all color lines are at top of screen
Thats what happened your convergence went out, those parts can be found online for as little as 12.50 a piece. If you are good with solder its an easy fix. I found a guy on craigslist in denver who fixed it for 150
good luck
Feb 11, 2009 | Samsung PCN5425R 54" Rear Projection...
Samsung PCL5415RB 54 Problem
Replace both convergence ICs number STK392-040 You can get replacements at the following link and they will provide free instalation instructions with pics and also give free tech support on line so you can do the repair yourself. Heres the link.
http://servicemanuals.vstore.ca/
May 06, 2008 | Samsung PCL5415RB 54" Rear Projection...
MITSUBISHI WD73727 73" HDTV
the light engine has gone bad..contact mitsubishi consumer relations..all of these sets seem to be failing,,they can't keep enough of the engines working to replace them all
Nov 27, 2007 | Mitsubishi WD73727 73" HDTV
Open Questions:
See all Mitsubishi WS-65869 65" Rear Projection Television Questions
Mitsubishi WS-65869 65" Rear Projection Television Logo
53 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
