Question about Dyna-Glo Double Tag-a-long Heater
Where do i find the adapter for a twenty lb tank
  • 181 Answers
Try here http://www.portableheaterparts.com/ they should have what you are looking for
Posted on Mar 23, 2009
Big buddy Heater - 20 lb tanks won't keep pilot lit,
I had the same problem I called tech support and they said to turn the valve on the 20# cylinder on very slowly for the first 1/4 turn then all will be fine. There is an excessive flow check valve that causes restricted flow when the valve is opened quickly----------mine works fine now
Apr 09, 2013 | Mr. Heater Mr Heater Portable Buddy...
My Mr Heater Buddy heater 4000 to 9000 btu unit work fine with 1 lb propane tank but when I connect it to my 20 lb tank with hose it will not stay lit. Acts like there is not enough gas pressure. My 20 lb...
it could be down to the draw off the tank pipe too small or reg is not for a 20lb tank , going to lock out check reg pressure should say on the side , or take hoes and reg off tank , put it back on and turn gas on slowly see if this helps
Jan 30, 2011 | Mr. Heater Mr Heater Portable Buddy...
Torque value on 2500 front brakes
Front caliper mounting bolts 24 ft/lb. support plate 43 ft./lb. hd front caliper adapter bolts 210 ft./lb. ld front adapter bolts 130 ft./lb. caliper banjo bolts 30 ft./lb.
Apr 01, 2010 | 2001 Dodge Ram 2500 Truck
Fire code says I cannot use my regular size gas grill with 20 lb tank, so I want to use with 16.4 oz tank. How do I adapt?
Can't different set up. The 16.4 oz is butane. The bigun is propane, 2 different animals. What fire code would prevent you from using one of the new fangled tanks with the safety device witin?
Feb 26, 2010 | Coleman Roadtrip Grill LXE 9949-750
Propane Tank Size needed for Reddy Heater TB101
Yes it will work but it will heat more efficiently with the 100 lb tank
Jan 05, 2010 | Desa International TB101 Heater
Works on small bottles \low flow on 5lb tank with adapter hose
t urn tank off disconnect from grill make sure knb is in off position reconnect make sure fitting is all the way on tank reconnect and try again if this doesnt work you may need new hose weber has had problems with thier hoses call them and order new one or call bbq galore and ask for 4ft adapter hose 214 696 0030
Aug 17, 2009 | Weber Q Grill
How much sand does it take for a BaquaPure 22 gal. tank?
if the tank is 22" you use 100 lb. 24" 150 lb 26" 200 lb.
50/50 silica sand works best.
Jun 25, 2009 | Sport & Outdoor - Others
20 lb tanks
Yes you can use a 20lb tank to run the heater. I purchased a adaptor hose it hand screws into heater & screws onto tank works fine. Bought the adaptor hose at HD.
Custom Contractor
Jan 01, 2009 | Dyna-Glo Double Tag-a-long Heater
Could not get more then 72hours using 20lb tank on low
HI. propane has 91000 btu's per gallon. 20# bottle has 4. divide btu's of heater by #of gallons for hours of use. I have the same heater and I think the med. setting both burners on is more the 7000 btu's.
Mike
Nov 25, 2008 | Dyna-Glo Double Tag-a-long Heater
Dyna-Glo Double Tag-a-long Heater Logo
148 people viewed this question
Top Dyna-Glo Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Dyna-Glo Heating and Cooling Expert? Answer questions, earn points and help others
