Question about Whirlpool Duet GHW9150P Front Load Washer
No cold water wash
Regardless of the setting I cannot do a cold water wash?
  • chrisjol May 11, 2010
    If that is the case would the washer default to hot water or would the water just not come out,always washes with warm/hot water regardless
    New Friend:
  • 88 Answers
You should check the screens on the water valve it's probably blocked.
Posted on Feb 18, 2009
Cold water setting not working-only hot comes out
The cold cycle begins with hot water to dissolve powder detergent regardless of whether you are using powder or liquid.
Jul 27, 2016 | Whirlpool Washing Machines
Water is cold regardless of the setting
I would check the water tempeture knob with a multimeter, u did check the water outlet hoses to see u are getting hot and cold water from them? Also if ur water inlet valve is bad it may only allow cold water or only hot water?
Feb 26, 2015 | Washing Machines
Cold Fill Washing Machine Does Not Get Hot
Do y7ou have 2 hoses at the back of the machine one for cold water and one connected to the hot water tap of the house. If not then you have a cold water in only. If you have 2 hoses have you connected the hoses into the machine correctly Have you checked to see if your machine has a heating element under the bowl for heating the water. As an appliance shop to verify if you have by the model number of the machine. otherwise you have a cold washing machine and unless you can plumb hot water to it that is all you will have.
May 29, 2013 | Siemens Washing Machines
No cold water regardless of settings
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Nov 05, 2010 | Fisher and Paykel WA37T26G Top Load Washer
Both hot and cold water trckle in regardless of setting no volume
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
http://www.fixya.com/support/r3880845-washing_machine_problems_no_water
http://www.fixya.com/support/r3880533-washing_machine_fix_washing_machine_no
heatman101
Aug 16, 2010 | Maytag Ensignia MAV2757AWW Top Load Washer
Warm water filling up washer, with no hot water hooked up to wash
exactly
it will maintain 60 degrees but cycling hot cold
thermistor
Sep 29, 2009 | Maytag Performa PAV2200
Cold wash/rinse selected, but only hot water is used
I have a Sears front load washer and I also noticed that on a cold wash/cold rinse cycle the machine was drawing hot water.
Laundry detergents require water to be at a certain temperature to aid in disolve. The machine adds sufficient hot water, regardless of the cycle, until that temp is reached. If I was to use a cold water detergent the machine, because it has no way of knowing which detergent I'm using, will still add hot water until that minimum temp is released. I don't know if there are machines available which include detergent type as an option?
Sep 28, 2009 | Kenmore Washing Machines
2 things it can be if your water pipe were you connect the hose too under the sink has a plastic turn handle to switch the water back on then it is most likely that it has sheard inside it undue the screw that holds it on pull the plastic cover off and with pliers turn until you hear the wate rcome through if not then it will be the solenoid inside your washer that has become faulty were the pipe connects to m8
Sep 24, 2007 | Fisher and Paykel GWL11 Top Load Washer
Washer filling up improperly
Well its definately not your water level switch, so that only leaves your water fill valve at the back of the washer, the cold valve is stuck open by debris. hope this helps
May 18, 2007 | Whirlpool LSR5132PQ Top Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
Dan Webster
Dan Webster
Sal De
