Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer You could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue You might use the system restore to restore your system to an earlier time click start all programs If it is a hardware issue the system restore might not work Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer. Use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System. Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps: 1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue.
If the cursor doesn't move when using the touchpad, make sure the touchpad is turned on. There is a button right above the touchpad with five lit-up dots above it. If the dots are white, the touchpad is enabled -- if they are orange, the touchpad is turned off.
Tach pad is clean and set the tachpad speed in contorl panal
speed is select slow and save in laptop ......................after check 95 % your problem is solve
Could be hardware related BUT from experience it is software related requiring a completed reinstall of your software if your using vista - so backup and save any data you want - reboot and at the HP splash screen hit F11 to enter system recovery - select advanced options - select full recovery - no back up and let it do a completed restore.
