Question about Whirlpool GS6NBEXR Side by Side Refrigerator
Icemaker froze up and I want to remove it so that can thaw it out
  • 410 Answers
There is 1 screw on the back right hand corner of the icemaker remove this screw then remove the wiring cover that this screw held in place. the icemaker will then slide straight out you will then unplug the icemaker at the wiring harness and be able to completely remove icemaker. thanks for using  fixYa peyton
Posted on Feb 18, 2009
Samsung refrig model rf26xaebp stopped making ice but i still bet water thru the door
The solonoid valve for the ice maker may be faulty or the icemaker may be froze up. Try thawing out the icemaker with a hair dryer. If thats doesn't fix the problem you may have to replace the soloniod or ice maker control. Be sure the arm above thre the ice bin is in the down position. Hope this helps.
Dec 30, 2013 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
Ice maker not making ice , we have water in the dispencer but no ice
Is the icemaker turned on? Did someone bump the on/off lever/switch accidentally?
If not, if you put your fingers in the ice tray, is there water/ice cubes? Unit may be froze up or the waterline may have froze up. Pull your food out and turn off the fridge and let the icemaker and waterline thaw. Speed it up with a hair dryer (caution that you dont melt plastic or wires).
Feb 03, 2013 | Refrigerators
Icemaker not working
Its probably the water tray not filling. On the back of the freezer, there should be a hose that goes into the ice maker - remove the screw that holds the tubing in place, and gently pull out the hose. Let it sit for about an hour - chances are, you stopped using a lot of ice, and the water in the fill line to the ice maker froze. Once that's thawed, water should be able to flow again.
While you're behind the refrigerator, there may be an envelope with instructions for the ice maker - specifically, how to start the cycle. After the water line has thawed, you will want to start a cycle and verify the water is flowing. You should be able to hear it flowing.
Dec 19, 2012 | Admiral 26 cu. ft. Side-By-Side...
Ice maker not getting water to it, I recently replaced the copper line from the wall to the refrig with a flexible stainless steel. The refrig stayed disconnected for a week before replacement now I...
Hello DeWayne,
That hose that connects to where the water comes out as it cycles,the end of it where it goes to the top and enters into the freezer/icemaker is frozen and needs to be removed and thawed,you could take that hose off at the water valve and blow through it if you can not blow through it easily its defiently froze,if once you thaw it it becomes froze again within a couple days up to a couple weeks the water valve where that hose connects to at the bottom is bad and causing it to freeze and that valve should be replaced.
I hope this will help you to get your icemaker working,
Gene
Aug 08, 2011 | Frigidaire FRS3R5EMB Side by Side...
Ice maker and hose from back of fridge to it both frooze up.
Good day,
If the fill tube overfilled the ic maker and is iced itself, it is due to the water valve in the bottom rear leaking slightly after filling the ice maker during a normal cycle. The water valve will have to be replaced. However, it will take time and patience to get it thawed properly.
The ice maker should be removed and set aside to thaw out completely.
As well, the fill tube must be thawed out itself very carefully. Haste makes waste here. A hair dryer can be used but very sparingly since it's possible to start melting things you don't want melted.
Ideally the machine should be shut down but that's your call.
Once the new valve is installed and the machine reassembled it should be fine.
May 22, 2010 | Amana ARS266ZBS Side by Side Refrigerator
Frigidaire icemaker wont fill with water. Side by side model. The icemaker motor is working but water is not filling in to make the ice.
Take a blow dryer and try to thaw the tube out. It may have froze on you. Please leave good thumbs up for my guess Thanks The Raz Shack
Feb 20, 2010 | Freezers
ICEMAKER /WATER
The line in the back of the freezer section is froze up. Remove the ice-maker and use a heat gun or hair dryer to thaw. be careful not to put the heat gun or dryer to close. It wont take long to thaw. BB
Dec 15, 2009 | GE Refrigerators
Whirlpool fridge model WF-NL300 ice maker not working. No water in icemaker. Black water supply tube that fills icemaker was frozed solid with ice. I thawed it in a cup of hot water. Unsure if line could...
Turn ice maker off for 24 hours to thaw out any additional frozen lines.
Make sure that you do have water from source to unit. Water valve grit screen may be clogged with debrie or water valve is bad.
Feb 29, 2008 | Refrigerators
Frigidaire not making any ice...
check inlet tube behind icemaker and make sure its not froze up. If so, it may just need to be thawed out but if it happens again you will need to replace water valve.
Jan 07, 2008 | Frigidaire FRS23KF7AB Side by Side...
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
1,433 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
