Question about Apple iPhone Smartphone
Keypad not working when on a call
I have a incoming call and i accept the call then try to touch the keypad button, and the add a call button and was working earlier just stop don't knowi f i touch the wrong button please help
  • 53 Answers
Try cleaning the screen
Posted on Feb 18, 2009
How to accept a incoming calls
'Green Call icon' if it has keypad or swipe right holding the 'green call icon' on touch screen!
Nov 01, 2016 | GPS
My GTB3410 sometimes the three buttons below the touch is not working alternatively, some times call button is not working at the same the back and end button is working , some times end button is not...
unscrew your phone and remove the keypad. then try pressing the phone without the keypad, if it works very well it means you will have to buy another keypad for your phone.
May 12, 2011 | Cell Phones
Does not overwrite old codes, just keeps accepting new ones. How can I clear all existing codes?
First, I fix this problem after an hour of try.
I conclude that this dorr lock is better that is appear. Is not a 2 codes door lock, it's a 3 codes one.. and the problem you have is the third code not reset. You can put the same code in each third emplacement. you have just to press the program button 3 time for the third code...
I determinate that I put the third code by error the was i program it the firs time.
I guide you...
  1. To program the first code, press the reset button once, then enter your 4-8 digit code on the exterior keypad, then immediately press the middle lock button on the exterior keypad. You will hear a beep. This signals that your code has been accepted.
  2. To program the second code, press the reset button twice , then enter your 4-8 digit code on the exterior keypad, then immediately press the middle lock button on the exterior keypad. You will hear a beep. This signals that your code has been accepted.
  3. To program the third code, press the reset button 3 time, then enter your 4-8 digit code on the exterior keypad, then immediately press the middle lock button on the exterior keypad. You will hear a beep. This signals that your code has been accepted.
Jan 27, 2011 | Weiser Lock POWERBOLT ELEC DEADBOLT
Unit is functioning o.k., but getting green light flashes about every 10 seconds. Batteries and connections are o.k.. Can't find anything in the manual or on Weiser website as to a solution.
reset all code and retry...
Good lock
Good unlock
Dec 31, 2010 | Weiser Lock Powerbolt 1000 Lock
We are trying to reset a security code for our existing weiser lock and it isn't taking the new code entered.
Good lock
Good unlock
Nov 08, 2010 | Weiser Lock Powerbolt 1000 Lock
Have a Rona electronic lock (Weiser) and the key works... will lock electronicly... but do not know the code... I have removed it from the door and replaced, but is there a way to reset the code?
I guide you...
Jan 23, 2010 | Weiser Lock Powerbolt 1000 Lock
Can not program both keypad & remote to operate at the same time
One of your units has reverted from "rolling code" to "billion code" and as you have found they will each work but will not work with each other. The problem is finding out which unit reverted. The most common one is the hand remote but that could be wrong.
Aug 09, 2009 | Sears Craftsman LiftMaster Chamberlain...
Won't accept key input
There might be a problem in ur.....key pad. Did u tried to install the previous battery.......again.....
Jul 14, 2008 | Motorola Mobility SLVR L7 Cellular Phone
Trying to add temporary code to craftsman keypad for Sears garage door opener.
Yes there is you need to press the colored learn button on the motor head and then follow the directions on the keypad. Thanks BB
Jan 31, 2008 | Sears Craftsman LiftMaster Chamberlain...
User Code
You may want to print this out because it is long.
Adding codes
Adding codes is really pretty simple.
First Add a System Manager code:
  • Press the 'additional functions' button to the right of the touch screen.
  • Press the 'system settings' button ON the touch screen.
  • Press the 'system manager settings' button on the touch screen.
  • Press the 'system manager' button on the touch screen and then use the touch screen to enter the system manager's name. Press 'done' when you have finished.
  • Press the 'system manager id' button on the touch screen and use the numeric keypad located to the right of the touch screen to create the id.
  • Press the 'system password' button on the touch screen and enter a numeric password for the system manager. YOU SHOULD MAKE A NOTE OF THE SYSTEM MANAGER ID AND PASSWORD, AS THIS WILL BE NEEDED TO CHANGE SETTINGSLATER.
  • Press 'next' on the touch screen.
  • Press 'email address' to add an email address for the system manager.
  • Press 'contact information' to add an extension to reach the system manager at.
  • Press 'ok' to complete the process.
  • Press 'done'.
Next add user codes:
  • Press 'system settings' button on the touch screen.
  • Press 'department id management' on the touch screen.
  • Press the 'on button' on the touch screen.
  • Press the 'store dept. id / password' button on the touch screen.
  • Press 'store' on the touch screen.
  • Press 'department id' on the touch screen and then enter a numeric code using the keypad.
  • If you want additional security you can also set up a password by pressing 'password' on the touch screen and, using the numeric keypad again, enter the password. The password can be left blank if desired.
  • Additionally you can set an impression limit for that user by pressing 'impression limit' on the touch screen.
  • Press 'ok' on the touch screen to add the user.
  • If you wish to limit impressions then you must press the 'limit impress.' Button on the touch screen.
  • If you want to add more users at this time go back to step 6.
  • Press the 'done' button.
  • Press the 'off' button at the bottom of the touch screen next to 'accept jobs with unknown id.
  • Click 'ok' to complete the process and start using the copier or go back to step 5 to add more users.
After this process users will have to enter a user id to use the machine. At the end of the copying process users should press the 'id' key located at the bottom right of the keypad to logout. The machine will automatically log users out if there has been no activity for a few minutes and this can be changed by pressing 'timer settings' in the additional functions.
While this seems like a lot it actually doesn't take very long to do. There is a far more elegant set of instructions in the 'reference guide' that came with the machine, which includes pictures, and starts on page 4-2.
Nov 07, 2007 | Canon NP 6050 Copier
Apple iPhone Smartphone Logo
93 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
