Question about Maytag Atlantis MDE7400AY Electric Dryer
I pull the knob on dryer Maytag MDE7400AYW and it won't start.
Hi, we have to almost pull the dryer knob off to get it to start. I looked at the parts diagram but not sure what is the part I should be ordering.
can you help.
Rick
  • sec0909 Mar 14, 2009
    I have the same problem. I have to push it in and turn it to try to get friction and pull up or down or out about 15-30 times each time. It is driving me nuts. Any solutions or parts I can get to fix this?
    President:
  • Maytag Master
  • 2,651 Answers
Yeathe start switch is bultdirrectly into the timer assembly youll need to replace the timer.
Posted on Feb 24, 2009
Aytag ensignia dryer model # is MDE7657BYW
Go for item 5 on this diagram. You can buy it off appliancepartspros.com
Parts for Maytag MDE7657BYW Control Panel Parts
Aug 24, 2014 | Maytag Dryers
My Maytag Atlantis MDE7400AYW does not start when I pull the knob and I cleaned the sensor and connection and pulled the panel and checked the connection on the board the damp indicator light comes on but...
There are a few different scenarios which would cause the dryer not to start. First, make sure you door switch is functional. Second, the white thermal fuse, located on the exhaust housing may be open. Worst case scenario would be a defective timer or motor. Either of these may not be cost-effective to replace.
Mar 06, 2014 | Maytag Atlantis MDG7400AW Gas Dryer
I need service manual for maytag dryer mde7400ayw?
Thats a older model and service manuals for it are no longer published. Thier is generic service manuals available at Lowe's HomeDepot and your local public library. However they only cover basics of all dryers and dont get into paticulars of any one brand. What kind of problems are you having we here can guide you through since some of us have extensive knowledge on the Maytag and other brand dryers having been in the field and serviced them for decades
Aug 16, 2011 | Maytag Dryers
Can not locate the thermal fuse on my dryer, maytag atlantis mde7400ayw
Hi khartley317
You will have to remove the back of your dryer andiIt will be located on the air tube.
I will send you to this webpage to see where it is located and you can purchase your part there Please take time to rate me
http://www.partselect.com/ModelFrames.aspx?ModelID=149441&ModelNum=mde7400ayw&mfgModelNum=&ManufactureID=1&Selected=51031&Position=4&mfg=Maytag&Type=Appliance&Mark=4
Jul 02, 2011 | Dryers
Hi, My Maytag Atlantis MDE7400AYW is making a noise. It is the front of the drum ribbing on the front of the laundry opening. I pull back on it a bit and the rubbing noise stops. I ran it with the...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Mar 19, 2011 | Maytag Atlantis MDE7400AY Electric Dryer
Mde7400ayw wont heat up
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jul 18, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Dryer won't start when knob is pulled.
If you push the knob to the left and it makes a good contact and starts the machine, then replace the timer switch. Write down the Name and Model Number of the machine (usually on or below the door)
take it to a local appliance shop and order a new part. When you recieve the new part UNPLUG the machine and remove the three screws from of the top of the electrical compartment and gently pull o the front open, there is only one plug attached to the switch, remove it and dislodge the old switch, then snap the new switch in place and replace the plug, close the compartment and replace the three screws, plug in the dryer, and try it.
Mar 15, 2009 | Maytag Atlantis MDE6400AY Electric Dryer
Maytag atlantis dryer mde7400ayw won't run
I believe this last one has it right. the timer may be bad or worse, the board could be bad.
Jan 15, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Difficult to start dryer - must pull control **** VERY hard
You will need a new timer. Unplug the machine. The console has four Phillips screws across the top. After removing those, use a tiny screwdriver to remove the large white disc on the timer ****. Behind that is a square clip holding the rest of the **** in place. There should also be one or two 1/4 in screws holding the timer to the console. Grab the sides of the console and rotate the top down toward you. Now you can reach the quick disconnect to the timer and the plastic tab holding the timer in position.
Mar 11, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Removing Timer Knob on Maytag MDE7400AYW dryer
Can anyone help me? I have a Maytag Atlantis that my parents just gave me and my wife. Unfortunately, they accidently removed the model number sticker in the door area. I need to buy a new timer but no one can find which timer to get without the model number. Via the internet, I think I narrowed it down to either the MDE7400AYQ or the MDE7400AYW....but they both look identical to me. Can anyone tell me what the difference between the two is so I can go get the part?
Mar 03, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag Atlantis MDE7400AY Electric Dryer Logo
745 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
