Question about Canon imageRUNNER 5000 Copier
Canon 500IR - Error Code E000602 0004
Can any one assist in a fix
  • Anonymous Apr 03, 2009
    solusion e 000602-0004
  • mukhrija May 10, 2009
    i have the same problem.
    but it still didn't work..
    can you give the other solutions..
    thanks
  • Canon Expert
  • 1,326 Answers
Is your copier a IR-5000 or a IR-550? It dose not really matter - the code means that the hard drive in the copier is not "Booting Up" correctly. Are you a service tech? If so, you can try to reseat the boot rom and clean the contacts with rubbing alcohol. After you turn the copier Off and then back On after you reinstall the boot rom. You can also try to do a HD chk in service mode. You will most likely have to replace the "HD" and have it "Flashed" to your copier configuration. Good Luck....
Posted on Feb 20, 2009
Solution to erro e000007 on ir 2420 copier
What is remedy error code E000007-0000 for canon ... - Fixya
www.fixya.com/.../t14373194-remedy_error_code_e000007_0000_can...
Oct 12, 2007 - ... is remedy error code E000007-0000 for canon imageRUNNER2422/2420 ... Copier canon ir 5065 prolems with eror code e 000808-0002.
Imagerunner 2200 error E000007-0000 - CopyTechNet.com
www.copytechnet.com > ... > Copier Technical Discussion > Canon
Mar 15, 2007 - 4 posts - ‎4 authors canon ir 2200. hi, this machine do not have fixing roller. machine have fixing film assembly. this code is for damaged fixing film, on the end you ... Error Code Canon 3025 E000007-0000
Jan 30, 2013
Error Code The dreaded e000007-0001 error code!
Sep 5, 2011
Error Code Color ImageRUNNER 4060i has code ...
Jun 30, 2011
More results from www.copytechnet.com
Nov 05, 2015 | Office Equipment & Supplies
How do you fix error code e000025-0320 on a canon c7260
You need to clean the Meg toner senser. remove front cover under the toners, second senser from the left.In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On :Canon Printer Support
Feb 27, 2014 | Canon imageRUNNER 5570 Copier
My canon pixma printer is showing error code 2 140 21 while scaanning???
i got this error while trying to scan. my ink cartridges were out of the printer (i was going to get them refilled). i stuck the cartridges back in and the scanner worked again.
Jan 20, 2012 | Office Equipment & Supplies
Error message: Service error 5100 on my Canon MP160 Printer
The main reason of Canon Printer error code 5100 If you receive Canon printer error code 5100 message this means you need to reset the printer. This also signifies that your computer does not recognize the printer. Your printer will show this error code because the LED is blinking. If your PC does not recognized the printer then it will also affect your printing jobs and you will not be able to do any printing work.
When the error code 5100 appears in your Canon multi functional printer then the Printer LED light will blink. This also means that you need to reset your printer. You must fix this error as quickly as possible. For instant technical support please contact Canon Printer Technical Support.
Tips to Resolve Error Code 5100
  • The Canon printer will show error code 5100 to warn the user that there is some problem.
  • In order to fix the problem, you require to opens the top of the printer.
  • In the right side of the printer you need to search for the waste ink absorber pad.
  • The next step is to clean the waste ink absorber compartment with a paper or cloth. This also completes the resetting process of the printer.
  • Inspect the paper feed area of the printer and confirm that there are no obstructions or paper jams in the printer that may be responsible for the error.
Dial our toll-free number +1-800-213-8289 for quick online assistance for resolving technical issues relating to the Canon printers. Our Canon Printer Support Number service is available for fixing technical glitches of our customers. Please get in touch with our tech support team and will receive online remote technical help at highly reasonable charges.
Our Epson printer support technicians are always ready to sort out each and every printer related issue with latest solutions offered to its clients. We are a team of fastest printer tech support solution provider for every issues related to all printers such as Software installation issues, Driver Upgrade, Change Printer ink, Printer Spooler and Paper Jam issues etc. If users are unable to solve this problem, they are welcome to drop us an e-mail and we promise to get back to them in short time span via our professional printer contact details. So, come and join us for tom experience our exceptional level printer solutions to your unexpected and critical issues. And also our Canon printer technical support technicians are always ready to sort out each and every printer technical issues with instant solution. We also provide instant remote support for Brother Printer technical support services for your common printer errors such as Software installation issues, Driver Upgrade, Change Printer ink, Printer Spooler and Paper Jam issues etc.
How to Fix Error Code 5100 in Canon Multi functional Printers
Jul 06, 2011 | Canon PIXMA MP150 All-In-One InkJet...
I have error code showing E007 on Canon iR2016j copier. How can I go ahead to rectify the error. Pl advise necessary assistance
these means that you have trouble with fixing film in fixing assy.So... you need to change fixing foil.
Feb 22, 2011 | Office Equipment & Supplies
CANON IR 3300 HAS ERROR CODE: E000002-0000
OK, but first try to clear the error under service mode, then replace fixing film assy, for EU 240V is FG6-6041.
To clear the error:
* 2 8 *
COPIER
FUNCTION
CLEAR
ERR
OK
Turn off and on ( main switch )
If this dont help - replace fixing film assy.
Dec 02, 2009 | Canon (6981A002AA) for imagerunner 2200,...
E007 CANON iR2016
This code from Fixing Unit like rotation film in fixing unit
check it and white grease i hope problem will solve if none then contact me for future.
Oct 05, 2009 | Sharp AR-M350N Copier
I have a Canon iP1000. it does not want to print.
the error code you have is referring to a printhead temperature sensor or logic board, Go for new printhead.
Regards
Canon Tech
Apr 30, 2009 | Canon PIXMA iP1600 Printer
Canon IP4000 Error Code 5100
It is a carriage error.
Most times this is a serious error that requires a Canon tech to fix it.
Look at the carriage and see if there is something obstructing it's movement. If you recently had a paper jam, there may be some paper stuck in the path.
You should be able to move the carriage freely with the power off.
Let me know.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 20, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Canon imageRUNNER 5000 Copier Logo
990 people viewed this question
old marine
old marine
