Question about Jandy Laars Lt 250,000 Btu Heater
The pressure light is blinking red
I had noticed the level of the pool was low and then noted the problem
  • 22 Answers
Turn off skimmer or add water to pool the heater is registering low flow.
Posted on Feb 18, 2009
How to repair burner?
check gas pressure if too low it will soot and overheat correct gas pressure and clean out outside of heat exchange so heat can go up through vent make sure level also if leaning back flame will come forward
Apr 27, 2014 | Raypak 206A Digital ASME Natural Gas IID...
Laars pool heater low pressure
pressure switch fault, on inadeqauate flow to pressure switch
Jun 03, 2013 | Jandy LAARS LX250 - NATURAL GAS, DIGITAL...
My split type 2.5hp carrier express ion shuts off (including the condenser) after five minutes of running, the indicator light blinks during this time...it restarts again after awhile, then shuts off again...
How many times is the light blinking? Also is the light red, yellow or green? The light blinking is telling you exactly what has failed.
(# of RED blinks first)
1 High Pressure Protect
2 Indoor coil freeze protect
3 Low pressure protect
4 Compressor discharge protect
5 Low pressure/Overcurrent protect
6 Indoor-outdoor communication error
8 Hi-Temp protect
10 AC Voltage Low
Each of these has maintenance required steps to resolve the errror. Let me know how many blinks your getting...
Kelly
Apr 25, 2011 | LG Heating & Cooling
Red light in dashbord blinks on/off look like a red hose with a drip.
That's the oil pressure light. Take it to an auto parts store like Napa or AutoZone, and ask the staff to scan your car (they'll do it for free). That will diagnose the specific problem. Odds are that you're a little low on oil.
Feb 28, 2011 | 2002 Mazda 626
My '99 Saturn Sedan is showing the red "Low Oil"
have your oil presure checked at a shop
Dec 28, 2010 | 1999 Saturn SL
1992 honda accord 245,000 miles oil light blinking while idling and once while I was driving the oil level is good. what could be the problem
Oil light relates to oil pressure, not oil level. If engine has not been rebuilt, it is safe to assume that it is nearing the end of its life. Low oil pressure light goes off on increased rpm´s , and hence, pressure goes up. You can extend the life a little bit by switching to heavy oils, such as 20W-50, but eventually it also wont be enough, and will start fouling the plugs. Check the oil level, because extremely low levels of oil can also produce a low pressure warning.
Feb 18, 2010 | 1992 Honda Accord
Heater runs 5-10 minutes then blows the breaker
After raising the water level in the pool I had no results. I bypassed the pressure switch and nothing happened so it was not the switch. Then I turned on the current for a few minutes, this moved something as it works now. So I conclude that the problem came from letting my water level get a little low.
Mar 26, 2009 | Raypak Spapak Electric Spa Heater - Els552...
Oil light blinks and oil is at the max in my 07 dogdge charger
oil light normally blinks for 2 reason. low oil pressure or low oil level. if the level is good and since its a 2007 i would hope that it was getting pressure. so its prolly the sensor. you can either remove the sensor and have someone check it. electrician hopefully. or you can just replace it
Mar 20, 2009 | 2007 Dodge Charger SRT8 Sedan
Jandy Laars Lt 250,000 Btu Heater Logo
186 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Bill Jordan
Ian Kime
Ian Kime
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
