Pioneer DVD-U03S SCSI DVD Drive
Problem for Pioneer DVD-U03S SCSI DVD Drive
DVD-Rom with SCSI interface
By Beresford - usenet poster
I've been looking for a good DVD drive for quite a long time now. But in
austrian stores almost only IDE or E-IDE drives are in stock. Aren't there
any good SCSI drives (Plextor, Panasonic,...)?
Solution #1
posted on Aug 01, 2007
Not Rated)
Cornish
Rank: Apprentice
Rating: 0%, 0 votes
Dear Mr. Slacker, thanks for your reply:
I read what you are saying; however, my drive has not been set to RPC-2
(the jumper has not been removed at all yet), and I still find that (using
the ATI DVD-player software appropriate to my graphics card), if I put in a
region 2 disc, the system (computer/software/dvddrive) rejects it as wrong
region. The Pioneer instruction manual accompanying the drive implies that
the RPC factory setting is "phase 1" (i.e. region 1), NOT 'region-free'.
How is it that the Newsgroup has the impression that the rpc-1 setting is
region-free? Has anyone out there got personal experience with this drive?
Would I need some other software player to be able to access both region 1 &
2 discs? (which obviously I would like to do!)
Was this helpful?
Yes
No
Solution #2
Not Rated)
M0nica L
Rank: Apprentice
Rating: 0%, 0 votes
RPC-1 = region-free
RPC-2 = region-locked
I think once the drive is set to rpc-2 the only way to get it back to
region-free will be a bios upgrade.
to email change dawn to ded in my email address
Was this helpful?
Yes
No
Solution #3
Not Rated)
Horner
Rank: Apprentice
Rating: 0%, 0 votes
Leaving the jumper at mode 1 gives you region free operation *OF THE DRIVE*,
but the associated software or hardware decoder should then be doing the
region check, so if the ATI S/W is set for region 1 then (under normal
circumstances) it will refuse to play a region 2 disk.
Switching the jumper to mode 2 means that the *DRIVE* will do region
checking, and any associated software or hardware decoder is required to
follow the drive. However, having a region free drive means it is much
easier to take advantage of the various utilities that allow the associated
software or hardware decoder to also be region free, and once you change the
jumper to mode 2 there is no going back, it has permanently - and I mean
*PERMANENTLY* - changed the drive to mode 1. Further fiddling will *NOT*
return the drive to mode 1.
John Howells, Wigan, UK
Was this helpful?
Yes
No
Solution #4
Not Rated)
Charlie
Rank: Apprentice
Rating: 0%, 0 votes
I just bought a Pioneer DVD-U03S SCSI DVD rom drive. The RPC jumper is set
at 1 from the factory, which according to the manual is for region 1.
Perplexingly the manual also says 'never return to phase 1 mode (ie region
1) after phase 2 mode is started' (which you do by removing the jumper),
implying that you cannot swap back and forth between regions using the
jumper.
However, you say in your post that leaving the jumper at 1 gives you
region-free operation; this is not my experience however, as the ATI dvd
software returns an error message when you try to play a region 2 disc,
stopping you from doing just that.
I would be very interested to hear what you (or any other owners of this
drive) have to say about getting around this feature.
Greg Morss
Was this helpful?
Yes
No
Solution #5
Not Rated)
kioner
Rank: Apprentice
Rating: 0%, 0 votes
Pioneer 303s (OEM) U03s (Retail) - same drive though - excellent UltraScsi
drive - 6xDVD - 32xCD
As you will see from reading this group, Pioneer drives are considered to be
the best allround drives.
Pioneer have just releases a 10xDVD - 40xCD - looks good - only tray loader
though I think - I prefer the slot type on the 6x.
If you get one - DO NOT REMOVE THE RPC JUMPER - leave it one and the drive
is region free.
Vapor
Was this helpful?
Yes
No
Solution #6
Not Rated)
Jimmy NY
Rank: Apprentice
Rating: 0%, 0 votes
Toshiba & Pioneer make them...
Hitachi, and Panasonic make SCSI DVD-RAM drives too (a bit off topic)
AFAIK there are no IDE DVD-RAM drives
-Tim
Was this helpful?
Yes
No
Popular Solutions for Pioneer DVD-U03S SCSI DVD
Questions and Unsolved Problems for Pioneer DVD-U03S SCSI DVD
Do you recommend Pioneer DVD-U03S SCSI DVD Drive?
Answer
Answer
the program to run my cd rom has simply vanished from my computor
Answer
my dvd player does not have a sounds when playing dvd's in media player
Answer
I have a Toshiba DVD-ROM Drive, Model No. SD-M1102 from an old HP Pavilion 8370 w/ Windows 98 that I... (More)
Answer
Need your resolution to this issue I am facing with my Sony DVD-RW AW-G170A Drive. 1. The drive... (More)
Answer
It changes from one cd to the next but does not repond to "play" button. I cannot... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Pioneer DVD-U03S SCSI DVD...:
Top DVD Drive Experts
Rank: Guru Guru
Solutions: 14889
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more DVD Drive Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
