Question about Amana ALE230RAW Electric Dryer
Amana electric dryer blowing high limit fuses
I posted the problem a few weeks ago and I was told I might have a blockage but I do not, I took apart the vent from wall and the entire exhaust system in the dryer and found nothing. This time the fuse only lasted 1-2 weeks and in the past it lasted a month or so, would it be the thermostate or the thermostate heater? I have no clue anymore, can you help my model number is lea30aw if you need it thanks
  • dino d Feb 20, 2009
    I just replaced a thermal fuse and it blew in less than a week. I believe that the high limit thermostat must be bad and probably the operating thermostat is bad too. I don't believe the thermostat heater is the problem causing blown thermal fuses. (I have an LE8457W)
2 Suggested Answers
SOURCE: blowing high limit fuses
I HAVE A AMANA LEA30AW DRYER I KEEP BLOWING THERMAL FUSE THE HEAT ELEMENT TEST GOOD AND THE VENTING IS CLEARD WHAT COULD CAUE IT TO BLOW
Posted on Mar 18, 2011
Electric dryer getting way too hot
3-5 ACCESS TO THE BLOWER WHEEL OR THERMOSTATS
To get to the blower wheel, remove the back of the dryer.
The blower wheel is under the bottom of the lint screen duct to your left, as you look at the back of the dryer.
The operating thermostats are at the blower wheel outlet.
In electric models, the hi-temperature cutout thermostat is mounted to the heat riser.
3-6 TEMPERATURE CONTROLS AND HI-TEMP SAFETIES
These clothes dryer machines use operating thermostats to control the temperature inside the drum, and hi-limit thermostats to prevent overheating of the dryer drum.. Many machines also have extra temperature controls, such as bias thermostats and heaters, hi-temperature cutoffs, and thermal fuses.
Bias thermostats are just like regular operating thermostats, except that they are mounted inside a bias heater. When the bias heater is energized, it generates a small amount of heat, which causes the operating thermostat to open sooner, keeping the dryer drum cooler inside. Thus a bias heater allows a single operating thermostat to act like both a hi-temp and a lo-temp operating thermostat.
A thermal fuse is found on the blower outlet, right next to the operating thermostat(s.) This fuse will blow when too high a temperature is sensed at the outlet; usually when one of the operating thermostats has failed. If it blows, the motor may not start, or you may get no heat (no voltage to the burner.)
A thermal cut-off is mounted on the clothes dryer heater box. It is a back-up for the hi-limit thermostat. Whenever you replace it, you should replace the hi-limit thermostat, too. A high-temperature condition causes it to open, an overheated grounded heat element may also cause it to open.
Dec 01, 2013 | Kenmore Elite HE4 Electric Dryer
DLE330RAW amana dryer running too hot
The control thermostat on the blower housing is the one you need to change if it is getting too hot. It is taking too long to shut off the element. The only other thing it could be is a blocked vent making it overheat. The fuse is set for 350f the limit on the element is a 250 f one. I suspect the 250 f limit on the element is doing the drying not the control stat. Hence you getting overheat but not hot enough to blow the fuse.
Apr 13, 2013 | Amana DLE330RAW Electric Dryer
Dryer had built up lint,blew fuse,now will blow fuse after cleaning and replacing vent hose
if its heated electrically, not by gas,then it sounds like the heating element has shorted to the case and this would blow the breaker
Jul 28, 2010 | Amana NDE2335AY Electric Dryer
Hi, I have a Kenmore Elite electric dryer model#
If your fuse is blown could be that your operating thermastat is not shuting off as soon as it should. Try replacing the fuse and the operating thermastat. The fuse would probaly blow before the hi limit.
Jul 16, 2010 | Kenmore 62802 Electric Dryer
Dryer has no heat
Most of the time the no heat is caused by a high temperature limit fuse blowing due to a lack of air flow. The part is not expensive, but tracing it down in the particular dryer may be difficult. To give more direction I'd need more information. I am familiar with Speed Queen, Whirlpool and their renamed counterparts (some Hotpoint, Kenmore, etc.)
Oct 25, 2009 | Amana DLE330RAW Electric Dryer
Blowing high limit fuses
Check the blower wheel attached to your motor.
It may be free-wheeling causing too high a temp thet is blowing the fuses.
Feb 22, 2009 | Amana ALE230RAW Electric Dryer
Maytag Dryer will not start again
Check list:
clear vent pipe
dryer clean of lint
blower wheel tight
drum turns freely
fuse tight against heater.
Wires not shorted on high limit mounted above heater
electric bill paid.
Feb 07, 2009 | Maytag PYE2300AY Electric Dryer
My dryer stopped working, using a multimeter I determined that the thermal fuse was open. I unclogged all the ducts then ordered a high limit thermal kit. After changing the fuse, it blew-up on the first cycle. It turns out that even though the high limit checked ok, it was defective. After changing both the fuse and the thermostat(included in the kit $25), the dryer worked correctly.
Feb 05, 2009 | Amana ALE230RAW Electric Dryer
Hotpoint NVL333EY Electric dryer blows thermal fuse
I had the same thing happen, I replaced the thermal cutoff and made sure no lint build up. It lasted a week then blew again. I then replaced it again and got to thinking why it would blow. I then took apart the exaust inside the dryer running fron the drum to the motor and right before the motor was a build up of lint ane particals that was almost like compressed sawdust which was blocking half of the line. I cleaned this out and it seemed to work much better.
Jan 04, 2008 | Hotpoint NVL333EY Electric Dryer
Amana ALE230RAW Electric Dryer Logo
162 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you an Amana Dryer Expert? Answer questions, earn points and help others
