Question about Compaq DP 6000 LOGIC BOARD (322735001) Motherboard
Add Memory In Compaq Deskpro 6000 P2 Shuttle PC?
Where is the motherboard located, and how do I get to it to add more memory?  Is it in the monitor?
    Sergeant:
  • 219 Answers
No, it is in the actual box which contains the power button. You'll need to open that box and take a peek inside. You will see something similar (not exactly the same) to what is depicted in this picture. Now, in your particular instance one or two of the slots will be occupied by memory-sticks.
That is where your memory will be inserted to add extra RAM. Now we need to find out what type of memory you have right now, because we will need to match it. Download this utility and install it onto your computer. Afterward open up the area for system-memory (Or RAM) and determine what type of memory you have. Is it DDR, DDR2, or some other type? Once again, we will want to try to match the speed, type, and possibly even the brand to ensure the RAM will work with your system.
Once you have that information head online to this website. Once it loads navigate to Computer Hardware>Memory. On the left select, "Desktop Memory." Afterward use the, "Guided Search" to narrow your search to the type that is in your system, that way you're looking at memory types that your system supports aiding you ever so greatly in your choice.
Now just to clarify. This will increase the system-memory not storage-space. With storage-space I mean a hard-drive which contains all your files, personal data, and the Operating System in your computer. If you want more storage-space we will need to buy you a new hard-drive. This won't be as difficult, we just need to know if you have ATA or SATA. Most likely you have ATA since your computer appears to be oldler, so I would recommend a Seagate ATA hard-drive from this website. Once the website loads navigate to Computer Hardware>Hard Drives. Afterward, on the left under, "Hard Drives" select, "Internal Hard Drives." Afterward on the left under, "Guided Search" select the, "Interface" type, "IDE Ultra ATA100." Afterward make a pick on a hard-drive that has the storage space you're after. (The only seagate doesn't have a lot of space, so the ultimate decision is up to you.)
So get back to us with your choice along with the information on your RAM and hard-drive types and we'll let you know if you made a good decision.
Posted on Feb 18, 2009
Good Morning, Can I add memory to this computer? I read somewhere that you cannot add memory. I believe it was on Compaq's website, but I cannot not find the information anymore for some reason. My...
Yes you can still add memory on your computer. I believe that the memory installed in your computer is one 256MB ddr sdram. Since the motherboard of your computer has 2 memory slots, it can support up to maximum 2 GB memory ( unbuffered PC2700/2100 non-ECC DDR SDRAM memory ). Or 1GB on each slot. Hope this helps.
Oct 04, 2010 | Compaq Presario sr1303wm Computer - AMD...
The board for this appears to have a dead ram slot.If putting ram into second slot the monitor just goes black with line distortions.Remove the Ram and install to first slot everything works ok add a 2nd...
Inspect the memory slot carefully. If there are are bent pins in the slot , you can probably align them with a pointed tip. Otherwise the best option would to replace the motherboard. Because after the process RAM is the fastest component in the computer. Out of experience in repairing the motherboards ,i recommend to replace the motherboard.
Thanks Fixya
Proton
Jun 17, 2010 | HP Compaq Presario SR1720NX (EL435AA) PC...
Inspiron 6000 starts to boot but then shuts down after only 10 seconds. New Battery, power supply measures ok. Caps lite is on.
Try reseating the RAM memory modules, see if any change.
If no change, remove, battery, Drives, Wireless card and RAM, see if the system will run longer or give an error code. If something changes, add 1 RAM module and try again. If the system runs, then add items back one at a time until you determine the faulty item.
If the system issue doesn't change, odds are a motherboard problem. Motherboard are about $100 on Ebay
Dec 06, 2009 | Dell Inspiron 6000 Notebook
RAM increment
yes just pur chase 1 128 MB or 512 MB or 256 MB ram but check first *********** bord ram module
check your old 64 Mb ram if it has 1 notch it is ddr1 or ddr2 if it has 2 notch it iks sdram
then pur chase from shop.
then fix it on secodn slot
Apr 24, 2009 | Compaq Presario 5000 PC Desktop
D845epi Is frozen on Express BIOS Update
hold down the power buttom till the system turn off and wait for some minutes then power back on. this situations happens when you are updating an old bios.
Feb 18, 2009 | Intel D845EPI (INTELKD845EPILPAK10)...
Before you get to that you may want to see what type of memory and much you can upgrade you shuttle. Go to http://www.crucial.com/ and do a scan to see what memory you have in the system and if it worth upgrading. Then go to hp website and get the manual to find the motherboard.
Please rate, Thanks.
Feb 17, 2009 | Compaq (296671-001) for DeskPro 6000 P2...
I want Upgrade my computer memory
You need DDR PC 2700 184pin memory. Your machine will support upto 2g.
You can buy this memory from anywhere at cheap prices.
Hope this helps
Regards
Oct 16, 2008 | Compaq Presario 5000 PC Desktop
I am thinking of adding memory to my Compaq Presario SR111ONX. I was looking for a schematic of the motherboard or a diagram showing the memory slots and how to add it.
Two long slots with tabs on each end... the hold the memory sticks vertical to the board.
Use your finger to gently move the tab away from the memory stick on both sides... after each tab has been moved away pull up firmly on the memory stick...note the position of the slot(s) on the side of the stick that goes into the slot. insert the replacement memory stick in the slot lining it up carefully and push down ... the tabs should go back into place on their own if the memory is seated properly.
Robert
Sep 19, 2008 | Compaq Computers & Internet
How add memory module
http://www.edgetechcorp.com/videos/viewer-memory.asp?video=desktop..this webpage wud help u
Adding memory is a trick - it is located under the panel to the left of the touch pad.
all the best
have a nice day!
tc
Jun 13, 2008 | Compaq Evo N610C Notebook
How do I add more memory to my compaq deskpro en series and how do I know which one to buy?
refer to you manual for type of ram your motherboard support,for brand you can choose from Kingston,Transcend,corsair
May 01, 2008 | Computers & Internet
Compaq DP 6000 LOGIC BOARD (322735001) Motherboard Logo
1,193 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
